RX8 Brake Pads
R1DSO
Has thanked: 258 times
Been thanked: 50 times
Re: RX8 Brake Pads
Post by R1DSO »
ChrisHolmes wrote:
Thu Sep 09, 2021 7:44 am
This is most odd as I have never experienced squeaking with 1144 pads. I suggest you remove the pads and Emery their friction surface and the discs.
Thanks Chris. Will be a little while until I’m back and can take the pads off the try sanding them. Just been invited to a day at Silverstone next week - mostly hot laps, but with a chance to take the RX8 out too. Won’t have time to get an emery on them before then, so it’ll be interesting to see if the stresses of track work make the squeal better or worse :-k.
These users thanked the author R1DSO for the post:
ChrisHolmes (Fri Sep 10, 2021 9:56 am)
2009 R3 in sparkling black
Racing Beat REVi ram air duct
K&N panel filter
Suffix C Mazda coils
Magnecor leads
Racing Beat header / mid pipe
RRP engine mounts
Hel braided brake lines
Carbotech XP10 pads / Mintex discs / Motul RBF600
Russell speed bleeders
Michelin Pilot Sport 4S tyres
R-Magic shift knob
Heel/toe pedal mod
1990 Eunos Roadster V-Spec in BRG
Re: RX8 Brake Pads
Kill or cure?
R1DSO
Re: RX8 Brake Pads
Post by R1DSO »
bc-49 wrote:
Thu Sep 09, 2021 12:11 pm
I used to run M1144 on Mintex discs, and they used to squeak quite a bit at low speed after some track use. Might be something to do with that particular combo.
Have recently moved to EBC plain discs and Bluestuff and no squeak so far after 1,200 miles and a track day.
Interesting to hear. I thought Mintex discs were essentially OEM spec iron :-k.
K&N panel filter
Magnecor leads
RRP engine mounts
R-Magic shift knob
Heel/toe pedal mod
R1DSO
Re: RX8 Brake Pads
Post by R1DSO »
New Duke wrote:
Thu Sep 09, 2021 12:35 pm
Lucky sausage. I have Bluestuff pads on plain discs at the moment and find them occasionally squeaky at low speeds when hot. Still my favourite pad so far though, despite not being great when cold. The R90 approval tolerances must be very generous.
I was considering EBC Blue Stuff, but mixed reviews put me off. May give them a try after the 1144s if they’re thay good :thumleft:.
K&N panel filter
Magnecor leads
RRP engine mounts
R-Magic shift knob
Heel/toe pedal mod
R1DSO
Re: RX8 Brake Pads
Post by R1DSO »
warpc0il wrote:
Thu Sep 09, 2021 11:13 pm
Kill or cure?
Lol. Immersion therapy! tbh, the Silverstone track day is an op through my work and the self drive/own car stuff away from the hot laps says “limited speed” (whatever that means), so the new RX-8 brakes may not get as much of a work out as a regular open pit lane event.
K&N panel filter
Magnecor leads
RRP engine mounts
R-Magic shift knob
Heel/toe pedal mod
Re: RX8 Brake Pads
It's a reasonable assumption that Mintex use the same material for all their discs.
We know that some car manufacturers don't all use the same specification of material as other car brands.
Therefore it's likely that the Mintex discs could be "essentially OEM spec iron" as at least one car brand, but it's impossible for it to be the same as every car brand.
I find that Mintex discs wear much quicker than the original Mazda discs on the 8, and are particularly prone to wear with aftermarket aggressive pads. However, that might still be a good combination for braking power, fade resistance and "feel", when driving on-track.
ChrisHolmes (Fri Sep 10, 2021 9:58 am) • R1DSO (Sun Sep 19, 2021 8:53 am)
bc-49
Has thanked: 33 times
Been thanked: 22 times
Re: RX8 Brake Pads
Post by bc-49 »
There are definitely better pads from cold than the Bluestuff, but they’re fine for road use I’d say. After the first decent sized stop on track they kick into a nice operating window, feel good and perform well. A good fit for someone who’s going on track and doesn’t want to be changing pads in between, for a pure road car I’d recommend something else.
The EBC discs seem better made than the Mintex that came off to me, but others’ mileage may vary.
These users thanked the author bc-49 for the post (total 2):
New Duke (Fri Sep 10, 2021 1:32 am) • R1DSO (Sun Sep 19, 2021 8:54 am)
2006 Galaxy Grey 231
Nankang NS-2R | Eibach Pro-Kit Springs | Eibach 20mm Spacers | EBC Discs + Bluestuff Pads | Racing Beat REV8 Catback + High Flow Cat | BHR Ignition | K&N Filter | Koyo Rad | Mishimoto Thermostat | Greddy Sump with ER Lines | Lockwood Grills
Re: RX8 Brake Pads
R1DSO wrote:
Thu Sep 09, 2021 11:15 pm
My track driving style i̶s̶ ̶l̶a̶z̶y̶ works the brakes hard and Bluestuff are the first road legal pad that I haven't been able to overwork and seem to want to do endless laps. More skilled drivers here I'm sure can keep 1144s happy lapping continuously.
Bluestuff just take a couple of mins on the road to have the same instant bite when cold that the 1144 has. So ideally no emergency stops pulling out of your driveway.
bc-49
RX8 Brake Pads
Post by bc-49 »
Worth mentioning as well that M1144 and Bluestuff aren’t technically a direct comparison. The equivalents are:
1144/Yellowstuff
1155/Bluestuff
Would 100% recommend the 1144 over the Yellowstuff for road and/or track.
I would have gone with the 1155 if they were more readily available, but happy with the Blue so far.
ChrisHolmes (Sat Sep 11, 2021 10:07 am) • R1DSO (Sun Sep 19, 2021 8:54 am)
wreeve
Has thanked: 39 times
Been thanked: 15 times
Re: RX8 Brake Pads
Post by wreeve »
I'm a slow road driver so ended up getting the green pads from the dealer. But I am sure I read somewhere that there is a race series that use this pad? or did I dream it?
bc-49
Re: RX8 Brake Pads
Post by bc-49 »
Not sure about green pads from the dealer, but think Yellowstuffs might be used in a few series (not RX-8 specific).
Both the Yellow and Blue are new compounds for 2021 and seem to have good feedback so far.
Conan
Has thanked: 26 times
Been thanked: 310 times
Re: RX8 Brake Pads
Post by Conan »
wreeve wrote:
Fri Sep 10, 2021 1:19 pm
The women’s RX-8 series used the standard OEM pads until at least 3/4 of the way through if not until the end.
I had a set of these originals in a car and was surprised how good they were as an all round pad on the road and track and I’m not the slowest track driver.. I seem to remember these pads had a green tinge to them but should not be confused with EBC green stuff which would be an inferior pad
These users thanked the author Conan for the post:
wreeve (Wed Sep 15, 2021 5:16 pm)
wreeve
Re: RX8 Brake Pads
Post by wreeve »
Dealer OE pads are marked "NISSHINBO INDUSTRIES. INC", are green and marked SUMITOMO on the pad itself.
I also bought the shim kit and you get two packages of grease and nice new shims to use. Result. £100 + vat not outrageous. On par with BMW OE parts.
These users thanked the author wreeve for the post (total 2):
warpc0il (Wed Sep 15, 2021 7:07 pm) • ChrisHolmes (Wed Sep 15, 2021 8:50 pm)
R1DSO
Re: RX8 Brake Pads
Post by R1DSO »
R1DSO wrote:
Thu Sep 09, 2021 11:12 pm
Apologies for slow follow-up on this one. I returned from being overseas with work to a very hectic week. Unfortunately, the work trip to Silverstone was a limited speed self drive lap, so the RX-8 didn’t get to stretch its legs #-o. I did get a few hot laps as a passenger in a Ginetta G40 though, which was a good reminder of how fast you can carry a low-powered, light car through corners with a decent chassis, good brakes and slicks!
I’ve managed to get the RX-8 out on the road for a couple of spirited drives and, interestingly, the brake squeal is getting better. It’s now only happening under heavy braking and, I think, it’s just coming from the front. I’m tempted to keep driving the car to see if the squeal rectifies itself vs going through the hassle of taking off all the pads again :-k. I’ve got an endless list of project car to dos with my Miata, so I’m not wanting for excuses to get my hands dirty!
Although it’s hard to really put the brakes through their paces safely on the road, I’ve noticed a couple more characteristics of this set-up...
Daily driving braking doesn’t feel as progressive as before – it’s not as sensitive with initial pedal movement, but then the bite is harder than my previous pads/discs. At anything more than very light braking, I found it’s taking a little getting used to to avoid being jerky (in traffic etc.).
Under heavy braking, stopping power seems to be up. I’m no expert at this, but it feels like the brake bias has changed slightly. It’s as if the fronts are now out-braking the rears, with slightly more forward momentum coming from the back of the car under very heavy braking. For instance, the car feels ever so slightly squirmy when doing a 70-20mph emergency brake, when I think it stayed a little flatter and more composed before.
I found the above characteristic particularly interesting considering Pete mentioned running 1155s for even more stopping power up front, which I would have thought would increase this brake bias:
Conan wrote:
Wed Sep 18, 2019 1:21 pm
I would also use 55,s fron and 44,s rear at times.
K&N panel filter
Magnecor leads
RRP engine mounts
R-Magic shift knob
Heel/toe pedal mod
R1DSO
Re: RX8 Brake Pads
Post by R1DSO »
New Duke wrote:
Fri Sep 10, 2021 1:41 am
A potentially problematic scenario I’ve wondered about with more track-focussed pads... what happens if you’re cruising on the motorway in cold/wet weather, you haven’t used the brakes for a few miles (so they’re completely cold) and you suddenly have to do an emergency stop because of unexpected stationary traffic. Would the stopping power be there when you need it with Bluestuff or 1155 pads?
K&N panel filter
Magnecor leads
RRP engine mounts
R-Magic shift knob
Heel/toe pedal mod
Re: RX8 Brake Pads
R1DSO wrote:
Sun Sep 19, 2021 9:46 am
I can't speak to the 55s but in that scenario with the Bluestuffs you'd be fine. They really only need a minute to warm up, and they stay warm enough just by rolling forward.
If you literally lived on the side of a fast dual carriageway then yeah it might be worth a second thought.
R1DSO (Sun Sep 19, 2021 10:58 am)
R1DSO
Re: RX8 Brake Pads
Post by R1DSO »
New Duke wrote:
Sun Sep 19, 2021 10:01 am
Ah, that’s good to know. Thanks mate :thumleft:. I live in a village, so these could work for me, then :).
K&N panel filter
Magnecor leads
RRP engine mounts
R-Magic shift knob
Heel/toe pedal mod
Re: RX8 Brake Pads
I have never found that 1144s grab as you describe, they should behave like normal pads smooth and progressive, just a little less braking initially if from cold but it’s not really noticeable.
It’s important not to overthink these things.
R1DSO
Re: RX8 Brake Pads
Post by R1DSO »
Finally got round to sorting my brake squeal. Been out the country with work a lot recently and fixing a number of bigger jobs on my MX-5 when free.
I worked out the squeal was coming from the driver’s side front brake. It felt like this disc was getting hotter too, although that could have been heat from my RB header :roll:!
Anyway, I ordered in a set of new OEM sliders and shims and fitted these to the front brakes, along with a new calliper pin to replace the lower driver’s pin that was missing the little brass ring that holds its ribbed rubber sleeve in place.
Worth mentioning that nothing looked untoward when taking the pads off. Wear was normal, but I gave them a light sand down and spray with brake cleaner all the same.
No more brake squeal now and, although I might be imagining it, the brakes feel more progressive and less grabby than before.
I haven’t got round to replacing the sliders and shims on the rear yet… given that the brakes are now working as they should, that job will probably get bumped to the spring.
These users thanked the author R1DSO for the post (total 4):
warpc0il (Tue Nov 16, 2021 7:41 pm) • ChrisHolmes (Tue Nov 16, 2021 11:25 pm) • Phil Bate (Wed Nov 17, 2021 5:43 pm) • v-rex (Sat Nov 20, 2021 11:30 am)
K&N panel filter
Magnecor leads
RRP engine mounts
R-Magic shift knob
Heel/toe pedal mod
v-rex
Has thanked: 515 times
Been thanked: 172 times
Re: RX8 Brake Pads
Post by v-rex »
Sorry quick random question on bluestuff pads. They are R90 and road legal front and back right? I was googling them and someone on a Nissan forum said only the rears were. Am sure it's fine but just checking before I pull the trigger on these. Thx
Re: RX8 Brake Pads
v-rex
Re: RX8 Brake Pads
Post by v-rex »
Thanks! Checked the part numbers
DP51665NDX - front
DP51691NDX - rear
And they are both R90 and road legal for Mazda. Phew.
Re: RX8 Brake Pads
Good on you. They're a fab pad! I hope you like them too.
v-rex
Re: RX8 Brake Pads
Post by v-rex »
New Duke wrote:
Sat Nov 20, 2021 1:20 pm
30405 also speaks highly of them as well as yourself and others. I have Pagid pads (ECP version) on, which I had at Silverstone and although they never faded, they were smoking at the end of some of the sessions. I am going to TPS at some point soon and I'll get them to have a look at the braking system as I was getting some funniness when the brakes were cold, and I don't see why I shouldn't give these a try !! I have a set of pagid pads ( front and rear ) to change back to if there are any issues over the cold winter months, and then I can save the bluestuff for the summer/track next year, but so many speak highly of these I can't see why I should have an issue. I can use the next few months to get them all bedded in for drive limits next year ( probably my first decent high speed event currently in the calendar ).
RenesisRaceBuggy
Has thanked: 30 times
Been thanked: 92 times
Re: RX8 Brake Pads
Post by RenesisRaceBuggy »
I liked the Bluestuff NDX - they feel just like 1144's but with more bite - until the first time I overheated them, they lost all bite after that, even after flatting the surfaces off.
These users thanked the author RenesisRaceBuggy for the post:
v-rex (Sat Nov 20, 2021 10:20 pm)
