RX8 Brake Pads
Django91
Has thanked: 35 times
RX8 Brake Pads
Post by Django91 » Mon Sep 16, 2019 2:54 pm
Hello resident rotor-heads,
Looking for brake pads for fast road, and occasional track use.
This is a topic that divides opinion, how do you choose a good set of pads?
Toby
shroom
Has thanked: 52 times
Been thanked: 388 times
Re: RX8 Brake Pads
Post by shroom » Mon Sep 16, 2019 3:02 pm
Django91 wrote:Hello resident rotor-heads,
Toby
Previous experience, performance, price, availability all factors that will play a part in your choice.
A lot rate the Mintex 1144 if you can get a reputable supplier
Other more mixed on the EBC pads but I find my yellow stuff excellent and easy to source.
Has thanked: 262 times
Been thanked: 565 times
Re: RX8 Brake Pads
Post by Dr. FrankenRex » Mon Sep 16, 2019 3:04 pm
I really enjoyed Hawk HP+ for track.
Ultimately the RX8 is quite over-braked, so most OEM pads will do as long as you have some good, fresh brake fluid.
New Duke
Has thanked: 656 times
Been thanked: 557 times
Re: RX8 Brake Pads
Post by New Duke » Mon Sep 16, 2019 3:06 pm
Yeah, first decide on your budget and go from there. There's hundreds of £££s difference in choice for what you're looking for. Otherwise you're going to get a dozen different answers. It's just like tyres.
Yorindesarin
Has thanked: 24 times
Been thanked: 235 times
Re: RX8 Brake Pads
Post by Yorindesarin » Mon Sep 16, 2019 3:08 pm
I was looking into getting some Mintex 1144s. After contacting Mintex they told me to try a local supplier. The cost came to about £200 quid total for all round which isn't the worst in the world. Otherwise I was considering EBC yellows too.. I'd suggest trying one brand this time round and another brand the next. As long as it meets OEM standard you'll always be braking enough but you may find different amounts of braking hot/cold and dust etc not being to your liking.
jondkent
Colour: Stormy Blue
Has thanked: 56 times
Been thanked: 60 times
Re: RX8 Brake Pads
Post by jondkent » Mon Sep 16, 2019 3:09 pm
The Mintex 1144 are great pads, really good feel and speed reduction. Only problem is they can be very dusty, and can be noisy if you are unlucky.
I tend to use EBC redstuff pads, to day-to-day, leaving the Mintex for track.
Jon
TheJDMStereotype
Has thanked: 121 times
Been thanked: 119 times
Re: RX8 Brake Pads
Post by TheJDMStereotype » Mon Sep 16, 2019 4:47 pm
From my experience I would also recommend EBC yellow stuff
Sent from my SM-G950F using Tapatalk
2009 Sparkling black R3
- Japspeed sport cat
- Petit Racing exhaust
- Mapped
- EBC discs and pads all round
- K&N filters
- Michelin pilotsport 4s tyres
Has thanked: 399 times
Been thanked: 1570 times
Re: RX8 Brake Pads
Post by warpc0il » Mon Sep 16, 2019 5:13 pm
Just one word of warning when buying brake pads, many brands, such as Ferodo, Brembo & EBC are commonly faked.
Some sellers of fake parts have now realised that "too cheap" is a bit of a give-away, so they're asking very nearly as much as legitimate sources.
I've been very happy with the Pagid pads that I bought, in an emergency a couple of years ago, that have done two track days since without issues.
Follow this diy how-to https://www.rx8ownersclub.co.uk/forum/v ... 30&t=48895
as getting simple things wrong can ruin the braking performance, regardless how much you spend on the pads.
Django91
Re: RX8 Brake Pads
Post by Django91 » Mon Sep 16, 2019 8:00 pm
So ideally it wouldnt be too much above standard OEM replacement pads. Very much focused on function and not overkill
Toby
Conan
Been thanked: 708 times
Re: RX8 Brake Pads
Post by Conan » Mon Sep 16, 2019 8:30 pm
Hi and as you have found there are lots of opinions on brake pads.
The OEM pads were actually very, very good, ( The Formula woman race series used them ) all the cheap pads available are not as good as OEM. ( I was surprised by them )
The truth is simple : ( one size does not fit all ) horses for courses
For you and your requirements I would recommend the Mintex 1144,s I had these made for the club the first time around as they were not available in our calliper size. Cheaper than yellow stuff and a better feel although there is not a big difference as both compounds have to comply with E - 90 regulations on cold stopping compliance. ( euro regs )
You should be able to pick a car set up for around £130 to £150
Django91 (Tue Oct 08, 2019 3:08 pm)
xamtex
Been thanked: 105 times
Re: RX8 Brake Pads
Post by xamtex » Tue Sep 17, 2019 2:35 am
another vote for 1144s here,work well hot and cold...road and track days.
dac69er
Been thanked: 5 times
Re: RX8 Brake Pads
Post by dac69er » Tue Sep 17, 2019 10:25 am
i did a trackday on stock discs and pads and never had any complaints. no fade, no funny smells and braking was plenty good enough.
i personally wouldnt worry about anything better unless your wanting to compete or the car was heavily modified.
you would have to be going some to max out the stock brakes on the road!
Re: RX8 Brake Pads
Post by warpc0il » Tue Sep 17, 2019 10:40 am
One advantage of the OEM pads is that they always fit without jamming or filing down the sides.
That's not be the case with many aftermarket pads that I've fitted, or others have struggled to fit during a trackday lunch stop
bigpete8
Has thanked: 92 times
Been thanked: 97 times
Re: RX8 Brake Pads
Post by bigpete8 » Tue Sep 17, 2019 11:56 am
Mostly... my Mintex OEM spec ones didnt.
Django91
Re: RX8 Brake Pads
Post by Django91 » Tue Sep 17, 2019 12:14 pm
So are these OEM spec Pagid pads or a higher performance pad? I believe Euro car parts do OEM spec pads from Brembo/Pagid, good discounts as well!
Toby
Re: RX8 Brake Pads
Post by warpc0il » Tue Sep 17, 2019 1:50 pm
Just the standard Pagid pads, probably the same as ECP offering.
Get some Ceratek while you're there.
Django91 (Tue Sep 17, 2019 3:08 pm)
New Duke
Re: RX8 Brake Pads
Post by New Duke » Tue Sep 17, 2019 1:52 pm
Toby
Those pads from ECP will be genuine and work fine. As you've probably seen during their numerous sales you can get a full pad set for about £50. Which is a bargain.
Those pads will be plenty on the road and pretty good on track. I used them for both for a few of years. You may find they wear out in a single very hot day on track and fade after a few laps. Or on cooler track days you may see very little wear or fade. They don't last quite as long as more expensive pads under extreme thermal loads (but we're talking: trying to set a fastest lap on a race circuit in 30+ degree heat). Plus at £50 they're so cheap who cares if they don't last as long. For 99% of scenarios they're the business. And anyone who buys more expensive pads but doesn't take the car on track is throwing away money.
I recently swapped to Mintex 1144s (which are better on track for my driving style with very little fade) but they're much more expensive. I usually track it every 2 or 3 months. In your case I'd suggest starting with the OEM euro car parts pads (I liked the Brembo ones, but they're all fine) and see how you get on. You may find them plenty. So much of brake wear is down to driving style. But if you feel later than you want something different then 1144s or Yellow Stuff are good alternatives, but cost more than double. That was why I mentioned budget being a factor earlier.
Django91 (Tue Sep 17, 2019 3:06 pm)
Django91
Re: RX8 Brake Pads
Post by Django91 » Tue Sep 17, 2019 3:08 pm
Toby
Absolutely, I agree with you. I might just buy from ECP for now. Whom do you use to get your Mintex 1144s?
The one part I really want, but struggling to find used is the Racing Beat set of ARB's!
New Duke
Re: RX8 Brake Pads
Post by New Duke » Tue Sep 17, 2019 3:44 pm
I jumped on a club group buy that you must have missed (I don't know if non-members can join in) which made them much more affordable. The other option I'd found was that some eBay sellers sell 1144s in the RX8 size, but that cost more than the group buy.
Yorindesarin
Re: RX8 Brake Pads
Post by Yorindesarin » Tue Sep 17, 2019 3:48 pm
When I contacted mintex they told me to contact Questmeads sales team to enquire about them. Fronts were 105 rears were 70 quid odd. Which is more than the group buy.. But could be less than ebay.
New Duke
Re: RX8 Brake Pads
Post by New Duke » Tue Sep 17, 2019 6:27 pm
And more likely to be the correct compound/not fakes if Mintex referred you to them. With an eBay seller who knows.
Yorindesarin
Re: RX8 Brake Pads
Post by Yorindesarin » Tue Sep 17, 2019 6:40 pm
Yeah exactly. They said Questmead supply to race teams etc so they'd have stock ready to go. I won't be buying them till next summer time probably so... who knows might have a group buy by then. :p
shroom
Re: RX8 Brake Pads
Post by shroom » Tue Sep 17, 2019 6:57 pm
Btw you can get 15% off at EBC with the club so the yellow stuff are £80 for the front...
These users thanked the author shroom for the post (total 2):
New Duke (Tue Sep 17, 2019 7:19 pm) • Devon_Fourie (Wed Sep 18, 2019 9:18 pm)
Conan
Re: RX8 Brake Pads
Post by Conan » Tue Sep 17, 2019 7:15 pm
Quest meads sister company make Mintex pads under licence from Mintex in small batches like the 1144’s
They supply the RX-8 race series with the 1144 pads which is why there is a rotor laser etched so the scrutineers can check easily. The two companies are owned by the same person, brake pads made ground floor and race sales first floor which really made me laugh when Chris Holmes informed everyone the pads had been delivered to the supplier.
The race series gets the pads cheaper than the group buy.
These users thanked the author Conan for the post (total 2):
GreySilver Beast (Tue Sep 17, 2019 8:56 pm) • Django91 (Wed Sep 18, 2019 10:54 am)
Yorindesarin
Re: RX8 Brake Pads
Post by Yorindesarin » Tue Sep 17, 2019 8:16 pm
Ahh interesting to know that Pete!
Return to “RX-8 Discussion”
