As my car was in for its MOT today (passed OK) while they had it at a local garage I asked for a quote to change the brake fluid - if no problems - £80 is that for real?
Changing brake fluid
- Been thanked: 229 times
Re: Changing brake fluid
Does that include the clutch line? As many don't
Halfwits/Halfrauds do it cheaper, but they only suck the stuff out the top and refill with new, not touching any in the lines at all
£15 for the fluid, with markup, so call it £25. And half an hour of labour at £50 per hour, so £25. So in total I'd say £50 would be fair, but £80 isn't silly. It's an easy job, and saves you £65. Win
That was just the brakes but I had fluid done on a Ford at a Ford dealer they charged me £40 so £80 at an independent seemed a trifle expensive I just thought while they are doing the MOT they could do the fluid but not at £80.
Need to get my trusty brake bleeder on it now, if she isn`t planning a shopping trip!
so it passe MOT testing but the stuff in the lines is still old
(You could do this yourself at home in ten minutes with a turkey baster)
- Has thanked: 694 times
So true, so often in life.
- bigpete8 (Thu Sep 12, 2019 10:36 am)
Some years back a local Ford dealer was doing exactly that, charging for replacing the fluid but they were just changing the fluid in the reservoir ie. not bleeding the system, trading standards set up a sting and caught them out - I bet that is a common practice, how many people get down and check if the bleed valves have been opened.
- Has thanked: 32 times
- Been thanked: 35 times
Do it yourself, it's really, really easy. I can do it and I'm a bloody idiot.
Galaxy Grey PZ number 24.
To be honest I have had the smaller brake cylinder bleed valves on rear drums shear off but never a front caliper, they are usually only seized if they have not been opened for several years.
Although I changed the fluid on my 911 2 years ago and have just done it again, a couple of bleed valves out of the 4 calipers were well tight.
