Loss of power 4.5k to 6.5k revs
Davemitch
Has thanked: 16 times
Been thanked: 17 times
Post by Davemitch »
Ok, had this ongoing problem for the last year and cant solve it!
As title, I have a poss of power 4.5k to 6.5k revs, power is perfect either side of this, surges on both ends of revs. Its had a replacement engine ( 7s both rotors) where everything was taken from donor car and put in to mine, had standard wheels back on, its decat, and coils replaced as well.
When hitting 4.5k revs and upwards, there is a definite smell of oil which makes me think a vacuum leak or oil leak on pressure somewhere? I just don't know where to look!?
When replacing engine, engine was known to be working very well and compression tested by Dean (member on here) and ssv and everything was all transplanted over together.
Please someone give me hope Haha
Durham, North East.
S1 RX8 231bhp
Build Thread: viewtopic.php?f=104&t=75018
HypoThermia
Re: Loss of power 4.5k to 6.5k revs
Post by HypoThermia »
Someone more knowledgeable will be along in a moment, however that rev range is associated with the second port opening up. Possibly a problem with the fuel injectors being blocked?
And still three gears left...
MarkG M3CP
RX-8: Kuro
Has thanked: 9 times
Been thanked: 10 times
Post by MarkG M3CP »
Sounds like a solenoid - similar to what happened the the Car Throttle car?
Current: '07 Kuro, M5 Competition
Gone: '06 VR 231, M3 Competition Package
Davemitch
Post by Davemitch »
HypoThermia wrote:
Fri Aug 23, 2019 11:44 am
Fuel injectors were also swapped from the known working engine too, I thought this as well, it's the smell of oil that really makes me think :-k
Durham, North East.
S1 RX8 231bhp
Davemitch
Post by Davemitch »
I'm even swaying towards fuel pump now maybe?
Durham, North East.
S1 RX8 231bhp
Davemitch
Post by Davemitch »
MarkG M3CP wrote:
Fri Aug 23, 2019 11:53 am
I'll take a look at the video now, just not sure with the oil smell too :-k
Durham, North East.
S1 RX8 231bhp
MarkG M3CP
RX-8: Kuro
More smell than a regular decat or premix?
That’s what prevents me going decat!
Paul_13
Has thanked: 34 times
Been thanked: 40 times
Post by Paul_13 »
I'd check the injector wiring. having the plugs going to the wrong injectors will cause a similar issue. Also the VDI and Aux ports open around this rpm.
You need to check the solenoid vac lines from the back of the inlet manifold to the VDI/SSV actuators. Also check the Aux port motor.
Might be worth buying a vac pump test kit.
If you get a minute have a look at my build thread on mazda rotary club forum, i detailed a lot of this.
http://mazdarotaryclub.com/forum/index. ... =84712.555
These users thanked the author Paul_13 for the post:
Davemitch (Fri Aug 23, 2019 12:06 pm)
Davemitch
Post by Davemitch »
MarkG M3CP wrote:
Fri Aug 23, 2019 12:01 pm
Oh it's always stank of fuel, first mod I did was decat lol but over 4.5k revs and stinks of oil now and it's only done that since this problem in new engine :(
Durham, North East.
S1 RX8 231bhp
MarkG M3CP
RX-8: Kuro
Ha!
And have you had the upper inlet manifold off yet to check for contamination all the way through? Sounds like it could be a pressure (or lack of it) issue - vacuum wise.
Again, I think the three solenoids play a part.
Annoyingly I binned a load of spares recently but you can pick up an entire upper manifold for £20 ish.
Davemitch
Post by Davemitch »
MarkG M3CP wrote:
Fri Aug 23, 2019 12:22 pm
Ha!
What's annoying is the perfect running engine was completely put in including the manifolds as well. I'm swaying to these solenoid I think too :-k
Durham, North East.
S1 RX8 231bhp
BigPete
Has thanked: 174 times
Been thanked: 174 times
Post by BigPete »
The air valve on the side of the intake opens between those revs, so either the solenoid or it’s stuck. Try moving it by hand first and if it moves easily then it’s the solenoid at fault
Bigpete
Davemitch
Post by Davemitch »
Had a play with Torque app and I think this graph best shows the problem. Now changed wheels to standard, intake to standard, ignition is rotary revs d585s, racing beat dual resonated decat and hks single exit. Full engine and ancillaries swapped from mid 7s compression known running perfectly last year, can not for the life of me find this fault :(
Durham, North East.
S1 RX8 231bhp
PaulAV
Has thanked: 173 times
Been thanked: 523 times
Post by PaulAV »
Just had similar problem with a noticeable drop of power above 4k to around 6.5k, there is a small vacuum link pipe under the throttle body /uim that can become dislodged when doing anything near the oil filter, worth checking, also in some cars where you have your service nipples there is a vacuum pipe attached via a T- piece to both nipples, I find a small hole in one recently just past where the pipe pushed on, so I cut about 1/2 inch of pipe off and it was all good.
Has thanked: 29 times
Been thanked: 328 times
Post by 350matt »
agree that it sounds like a faulty solenoid to me
Nerdstrike
Been thanked: 13 times
Post by Nerdstrike »
Just checked my old plots - two fairly standard 231's were pulling in 150-160 g/s through the MAF at WOT and 6k RPM. The peak should be north of 200 g/s give or take. Note Phil B and others' protestations that MAFs are not callibrated w.r.t. each other, but the numbers shouldn't be wildy different without major fettling/porting/boosting.
I know for a fact my car had worse compression than yours and was in the 6's when I took the data. Maybe it'll help you know if you've fixed it.
