Hi everyone,
As above really sometimes on start up(only when car is cold) I have a wat sounds like a slight misfire(no flashing cel) or anything it just appears to struggle to rev this last no more than 30 seconds then all is good never happens any other times and only every now and again
Mazda rev c coils 9k ago
Magnecor leads
Sparks 8k
Any ideas much appreciated
Dazzq
Occasionally misfire only on start up
- Has thanked: 34 times
- Been thanked: 40 times
Re: Occasionally misfire only on start up
I get the same issue. I'm guessing it's from where the ECU is injecting more fuel to compensate for the cold start and the engine struggles to burn some of it off. Or tired injectors?
I also get a massive misfire symptom when i accidentally turn the engine off cold and start it again. completely drops on one side of the rotors for about 5 seconds. nearly dies but catches itself and smooths out. I'm pretty sure i flooded it!
- Has thanked: 105 times
- Been thanked: 46 times
Hmmm,it's odd as I mentioned it doesn't allways do it even from.cold just occasional on 10 cold starts it may do it 2 or 3 times.
Car runs perfect otherwise
I have done the reset just in case but that changed nothing
- Has thanked: 101 times
- Been thanked: 83 times
How would.i inspect that John or how could I tell of that's the problem.
Pete told me mine was that and it was let it tick over for about 20 minutes without touching the throttle, maybe something else but that needs an expert opinion maybe.
- These users thanked the author acegeezer for the post:
- Dazza44 (Thu Aug 01, 2019 3:42 pm)
- Has thanked: 147 times
- Been thanked: 288 times
What's the story with the CAT?
Mods so far..
BBR 200 PACKAGE
COBRA " RACE " BACK BOX
MEISTER COILOVERS
DROPLINKS
Mods planned..
BBR STAGE 2 SUPERCHARGED
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
Mods so far..
BBR 200 PACKAGE
MEISTER COILOVERS
DROPLINKS
Mods planned..
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
- Ainmhidh (Thu Aug 01, 2019 9:12 pm)
Mine does this as well, although not so much if its cold but if it hasn't been started for a week or so. Again, no engine light and clears up after about 30 seconds. Got RRP mk2 coils, and a high flow cat. I wondered if it could be some kind leaking seal letting water into the rotors, although the coolant doesn't seem to be going down.
Sent from my G8441 using Tapatalk
Any other thoughts/ideas for me to check ?
How long since you did a full battery disconnect and 20 stump reset, from cold?
Sometimes the "learning" process can be corrupted by unusual conditions and reset does the trick.
https://www.rx8ownersclub.co.uk/forum/v ... 25&t=34703
- Has thanked: 265 times
- Been thanked: 359 times
That guy was in the audience of a comedy club in London a year or so ago and was certainly looking a little worse for wear and um, not as well-spoken though, the lady he was with seemed a little more of a handful.
