Coolant bottle..
- Been thanked: 3 times
Coolant bottle..
Hi folks my coolant bottle is throwing up a fault, plenty of fluid think the sensor is away.. Anyone selling a functional bottle or Is there an aftermarket sensor that can be fitted into the bottle. TIA. Bill
- Has thanked: 105 times
- Been thanked: 46 times
Re: Coolant bottle..
It's as common fault some just unplug it (light will go out then)
And keep.an eye on the tank now and again
- Has thanked: 101 times
- Been thanked: 83 times
If nobody has one they are/were £145 from the stealers .. just do as Daz states, that's the easiest and cheapest fix .. it's not as if you're topping up coolant every five minutes
- Has thanked: 40 times
- Been thanked: 13 times
Please also note that even if you lay your hands on a replacement tank avec sensor, unless your radiator is new or in very good condition, I'd be wary of swapping them out.
I put in a new OEM rad and when the coolant take was taken out, it took part of the rad with it!
Unplug like the boys suggest.
56 Plate PZ in Galaxy Grey!!
- Has thanked: 16 times
- Been thanked: 87 times
Is that the annoying hose on the underside? Mine was fine when I swapped my tank cost me £30 on eBay and no warning light now. Had it off 3 times since for other work and not done any damage.Ninja_Freak wrote:Please also note that even if you lay your hands on a replacement tank avec sensor, unless your radiator is new or in very good condition, I'd be wary of swapping them out.
Lucky you then! Mine had done 100k at the time of the change and yess its that annoying bit at the bottom.
- Been thanked: 229 times
With the OE coolant tank when the sensor fails then a repair is not possible see Coolant sensor
I'm sure we'd all love to know how.
- nightfire10 (Sun Jul 21, 2019 7:13 am)
Wow.. do tell as the Mazda Bulletin states replacement only .. due to the spec being upgraded.. Dealership replaced mine for free.. lucky me
How many you "fixed" so far?
You can replace just the tank and reuse the original sensor on some later cars and on others you have to replace the complete tank.
- Has thanked: 219 times
- Been thanked: 350 times
hi Hossein, this is your opportunity to shine, how do you fix a faulty header tank? i for one would be very pleased to find out,rob.
Maybe fill the coolant system with deuterium loaded water? The extra density might manage to float the damn thing once and for all. If that fails, move up to sulphuric acid, and lastly mercury. I'm sure the waterpump will be fine.
Aside from the sensor failing is it common for the tank to actually spring a leak mine is only on 25K miles after being replaced under warranty but it is getting on for 10 years old now and I am wondering if I should include a replacement tank in my collection of essential spares or just go aluminium.
The problem with (nearly all) aftermarket aluminium coolant tanks is that they don't include all the complex internal chambers that provide the liquid/gas separation, which is a key feature of the oem tank.
- RX-8: Import
- Colour: Black Cherry
- Been thanked: 119 times
.....often wondered what all the sections were for on the insides. Cool.
Black Cherry Mica
