Driver side seat belt Tensioner
- RX-8: 13B 6-port
- Has thanked: 20 times
- Been thanked: 5 times
Hi guys, Im a little unsure on this on what to replace.
My car was with Mazda for the recalls so I asked them why I had this light on the dash, (pic of something similar below).
They told me it was for the drivers side seat belt tensioner so my question is what do I replace.
The seat belt itself?? as it does not wind up that well anyways, or the little box under the stereo??
The light flashes sometimes but mostly stays on all the time.
Hayward stage 2 Port,Full RB Exhaust, RB L-Flywheel,Michelin Pilot Super Sport,Bola B1, Aero Kit,Light weight Pulleys,More To Come
- Has thanked: 90 times
Re: Driver side seat belt Tensioner
I think i believe it will be the seat belt
- These users thanked the author Bigblueknight3k for the post:
- Aido 8 (Wed Jul 10, 2019 11:19 pm)
As it has a tension device in it yellow plug
Follow the Troubleshooting Guide and it should tell you exactly where the problem is. Could be as simple as a plug disturbed while cleaning or being kicked by a passenger.
https://www.rx8ownersclub.co.uk/forum/v ... 58&t=35629
>> Launch MAZDA Service Materials
Switch from Workshop Manual to Troubleshooting
>> RESTRAINTS
>> RESTRAINTS
- Aido 8 (Wed Jul 10, 2019 11:20 pm)
- RX-8: 13B 6-port
Awesome thanks guys, just one more question, I have 2 from a 04 RX8 but mixed them up and can't tell the passenger side from the driver side or are they the same ??
Check the part numbers on the labels.
One says "LH" the other "RH"
- RX-8: 13B 6-port
That's why I asked, they read the same, so maybe the same ??
But that's not the tensioner, and there is no sensor in the belt (so nothing to throw a code). The tensioner is the bit the belt buckles into (attached to the seat). As Dave says, it would be worth checking the electrical plugs under the seat.
- Aido 8 (Thu Jul 11, 2019 8:28 am)
- Forum Trader
- Has thanked: 174 times
- Been thanked: 172 times
Unplug the yellow connector under your seat and then plug it back in, also make sure the white plug is fully home. This normally happens if someone has move the seat all the way back.
- These users thanked the author Boston Rotary for the post:
- Aido 8 (Thu Jul 11, 2019 8:27 am)
- RX-8: 13B 6-port
OK guys only looked at this now. Mazda said they checked the connections under the seat so I just done it again. So pics below to see if wire looking OK but if its nothing to do with the seat belt what about the buckle it clicks into ??
- Has thanked: 97 times
- Been thanked: 539 times
yellow one is airbag white is pretensioner, seatbelt light/alarm and seat electrics.
- RX-8: 13B 6-port
Yeah but still light on in the dash, where now
The dash light should flash a code, which the Diagnostics will tell you exactly which connection/component has the problem.
The system is very sensitive to resistance, so the connection might need to be disconnected, cleaned and reconnected, sometimes more than once, before it is happy.
- RX-8: 13B 6-port
My code reader is not picking up a code from it.The light flashes when ignition is turned on then goes of for a few seconds and then stays on solid. I have cleaned and refitted yellow and white wires several times now and no joy.
It was Mazda that told me that it was the seat belt tensioner. They said they tried the wires under the seat but it would need more tests as they did not know what the problem was. Anyway I was just talking to a guy that has garage diagnostic tool so we will see what it might say tomorrow.
a elm327 and a copy (free) of forscan will be able to read the code.
The pattern of flashing lights is the code
- RX-8: 13B 6-port
OK the codes, since it is electrical probably beyond me.
