tick over trouble.
- Has thanked: 219 times
- Been thanked: 350 times
tick over trouble.
hi there, i have started having tickover trouble when fully warmed up. the problem becomes apparent when pulling up at junctions or in a queue.
the tickover drops right down to,at a guess 500 rpm, sometimes it recovers and other times it stalls,what makes it a real pita is that ,with the rotary being so quiet, sometimes i don't notice until it is time to take off again.
so, my question is,does anyone know of any probable causes that may help me to track down the problem, apart from this niggle ,the car is running perfectly,on 585 coils ,premium fuel and new plugs. thanks,rob.
- Been thanked: 550 times
Re: tick over trouble.
plug a elm327 code reader in and install forscan on a laptop, then go to live data and check the clutch and brake switches are working properly.
- Has thanked: 18 times
- Been thanked: 78 times
What intake are you running? Have you pulled the plugs / chucked in ignition checker on to make sure the coils are doing their thing?
- These users thanked the author Eddie_r32 for the post:
- goodeggbob (Wed Jul 10, 2019 8:26 am)
2007 Galaxy grey 231.
James,havingmet me ,you wil know that is way out of my ability. layman terms would be much appreciated,thanks,rob
Is your air con clutch disengaging when it should? You can check this by just taking off the air con belt and seeing if the problem disappears.
thanks Pete,thanks for the no nonsense reply,practical answers are what i need,will give that a try and report back,rob.
i have taken off air con belt and will take it for a good spin tomorrow, although i don,t have the tools to check the ignition,would swapping trailing for leading coils do any harm? thanks rob.
would i be right in assuming that leading coils have to work harder than trailing during normal use?
All four coils are the same (so you can swap them). It might just confuse you though. Better to use spark testers. The coils all work equally hard.
(The trailing coils only burn a small amount of the mixture, but it still needs the same size spark).
- goodeggbob (Sat Jul 06, 2019 9:08 pm)
thanks Pete, i do like these kind of replies,i understood every word of it,thanks,rob.
which leads me to my next quuestion, can anyone point me in the direction of a spark tester, i have seen a set of four by accuspark on ebay,would these be ok,thanks,rob.
- Has thanked: 105 times
- Been thanked: 46 times
There all really the Same Rob so they would be fine.
- These users thanked the author Dazza44 for the post:
- goodeggbob (Sun Jul 07, 2019 8:46 am)
- Been thanked: 3 times
I had the same problem on and off, I noticed it more when tank was full. I decided to get an upgraded fuel pump and that cured it. My car had done 105000 miles and the original pump just was dying. Well worth it. Just another idea for you to look at.
- These users thanked the author SteveTroman for the post:
- goodeggbob (Sun Jul 07, 2019 12:33 pm)
Spark plug testers https://www.carbuildersolutions.com/uk/ ... ark-tester
- goodeggbob (Mon Jul 08, 2019 7:08 am)
- Has thanked: 112 times
Funny that I was just looking in Screwfix too just minutes agoChrisHolmes wrote:Spark plug testers https://www.carbuildersolutions.com/uk/ ... ark-tester
https://www.screwfix.com/p/laser-ht-lea ... pack/61411
Kia-ora!
'09 R3 Aurora Blue Mica
How did you get on Rob?
Kia-ora!
hello, upon inspecting the plugs , i found that rear trailing was black and had not been firing. i will now give the ignition system a good shake down ,and hope i may have found the problem,thanks to all of you for your tips and comments,rob.
- Dazza44 (Tue Jul 09, 2019 9:47 pm)
hi there, i took the car to the shropshire meet last night after changing the offending plug, the car ran perfectly,which ruled out coil trouble.
i will however have the ignition system apart today,simply to give it all a good clean and use my new spark tester,thanks for your comments,rob.
- BigPete (Sat Jul 13, 2019 9:26 am)
