Car cutting out when changing Gears
- Has thanked: 21 times
- Been thanked: 4 times
Hi guys,
My 8 appears to be cutting out when gears are changed down. The revs are dropping too much by the sounds of it
It hasn't been used for a few weeks and the last time it was used it had a compression test and was revved cold.
Could the comp test have affected anything? I'm due to go to a meet tonight but I doubt I'll be taking this heap at this rate
Thank you.
Thank you.
Re: Car cutting out when changing Gears
I think this is hard to comment on without understanding exactly what you mean.
Does the car idle normally?
If you hold the revs at (say) 4000rpm, then lift off the throttle, will the engine return to a normal idle?
If you are driving along and you lift off the throttle (still in gear) so the car starts to slow down, and then you apply the throttle again, does the car start to accelerate again?
When you change down through the gears the engine shouldn't have enough time to stop. In fact, ideally you should blip the throttle to increase the engine revs when changing down. So I'm not sure what you mean by "the revs are dropping too much".
- Been thanked: 13 times
Is this the "forgot the idle trims" problem? Did it have its battery disconnected recently?
A bad connection on the clutch switch can cause some strange behaviours but some clarity needed on what exactly is happening.
- CheekyWankel (Fri May 31, 2019 11:12 pm)
Could well just be that.Nerdstrike wrote: ↑Fri May 31, 2019 5:09 pmIs this the "forgot the idle trims" problem? Did it have its battery disconnected recently?
Sorry for the bad description, had to go by what my mum text me.
Just clarified with her and the revs just drop to zero when changing down, only happened 4 time so wasn't at every change.
It didn't idle well in traffic and revs dropped to zero. She had to keep them up.
The battery hasn't been touched. Spark plugs have been removed recently.
Could an ECU reset help perhaps? No harm in trying it is there?New Duke wrote: ↑Fri May 31, 2019 6:49 pmCould well just be that.Nerdstrike wrote: ↑Fri May 31, 2019 5:09 pmIs this the "forgot the idle trims" problem? Did it have its battery disconnected recently?
Yes try it, and no it won't do any harm.
- CheekyWankel (Sat Jun 01, 2019 12:47 am)
I did an ECU reset and now the car idles and changes gear without issues. Thank you for all your input my dudes
now if only an ECU reset would sort the rust out too!!
The fact that it needed a PCM* reset indicates that something went wrong, at some point before the stalling became an issue.
Something caused the PCM to start using a configuration that was inappropriate.
Potential causes include;
- corruption of the NVRAM by jump starting
- loose battery connection, or other wiring fault
- bad signals from one of more sensors; IAT, MAF, O2, ESPS, etc
- poorly performing ignition system
- poorly performing fuel injector(s)
It's (almost) impossible to identify which was the culprit in your case, without a Tardis to go back in time, but if it happens again you need to get to the root-cause before you just reset the PCM.
*PCM = Powertrain Control Module, so much more than just an ECU (Engine Control Unit)
- CheekyWankel (Sat Jun 01, 2019 6:23 pm)
Thanks, other than being fiddled with for a comp test I have no idea what it could have been. But yes if I happens I'll take a look into it before trying to sort. Fingers crossed that it'll be fine... For now...
It might just be "one of those things" in which case enjoy while you can
- CheekyWankel (Sat Jun 01, 2019 8:31 pm)
The amount of things this car has done differently for a day or two and then going back to normal is pretty concerning.
I'm pretty sure he's on his last legs, really hope not though love this car so much. Will do anything to keep it going.
- Been thanked: 109 times
Leanne,you have more than one RX8..as far as I know..so you're still good to go
- CheekyWankel (Sat Jun 01, 2019 9:17 pm)
Haha I know but favouritism and all...
Nah they're both great in their own ways of course, and my MX-5 was an absolute dream with today's weather.
He's doing it again.
Will get it hooked up and tested. But I'm starting to come to the end of tether with it's constant issues...
Check if you have a loose battery terminal.
Is this the blue one again?
That'll be the problem then, should have bought a red yellow one
- GreySilver Beast (Mon Jun 10, 2019 2:03 pm) • CheekyWankel (Tue Jun 18, 2019 9:02 am)
someone at work has suggested that I leave the battery disconnected for 4 hours so the car basically resets itself. I'll give that a go and if that doesn't work then I'll turn to my mechanic. Gotta try those janky repairs first!
Ah. I think we probably assumed you had done that when you did your ecu reset. Disconnecting the battery is part of that process. You don't need to disconnect it for 4 hours! It probably happens instantly, but a couple of minutes is fine.
Do a search on here for ecu reset. There is a great guide somewhere on here....
- CheekyWankel (Tue Jun 18, 2019 12:19 pm)
nooooow he tells me
gonna go hunt for that thread now, thank you
- Has thanked: 105 times
- Been thanked: 46 times
- These users thanked the author Dazza44 for the post (total 2):
- PeteH (Tue Jun 18, 2019 1:32 pm) • CheekyWankel (Tue Jun 18, 2019 9:21 pm)
Dazza44 wrote: ↑Tue Jun 18, 2019 12:22 pmhttps://r.tapatalk.com/shareLink?url=ht ... are_type=t
Thank you so much!
