Advice - Traders: Who's Who?
Ball07
Post by Ball07 »
Looking at all the options available out there for me at the moment and I'm very tempted by a few cars. However, can anyone tell me the difference between The Performance Shop and LC Rotary? Are they one and the same or separate? Also, has anyone bought from Kent Rotaries (formally Hexable???).
mi60o0
Has thanked: 91 times
Been thanked: 382 times
Re: Advice - Traders: Who's Who?
Post by mi60o0 »
For above Lc rotary is the same the performance shop is their parts Web page and have separate unit for parts.
Both are lewis company.
Kim is in the parts shop. Is in the old location last time I went.
They move the garage near bluewater is a bigger unit and I done my pops and bangs there and mini map
BatRex 192 stock
Ball07
Post by Ball07 »
Thanks. I've seen an R3 available at Kent Rotaries and they are always popping up with various RX8s for sale. They have told me that Reece (??) has done the servicing on it and could also give his opinion on the car. They said they are separate though??
mi60o0
Post by mi60o0 »
Reece and Kim are the performance shop but Lc are next to blue water
I never dealt with the other one you mention
BatRex 192 stock
Has thanked: 172 times
Been thanked: 781 times
Post by PeteH »
My understanding (which could be wrong):
Kent Rotaries are nothing to do with any other firm. They used to be know as Hextable Rotaries. Hextable's reputation was mixed, although I have no direct experience of them.
LC Rotary have recently changed their name. In fact they now have two names; LC Motorsport (the garage side of things), and The Performance Shop (the parts supply side). LC has a good reputation.
Hextable got a reputation on this forum, because they would sometimes say that LC had done work on a car, but LC would have no knowledge. So if Kent Rotaries are telling you that LC worked on the car then my suggestion would be to check that with LC. And if Kent give you a print out of the compression results, and they are all 7's, it's probably best to get LC to check the compression for you....
Note: I'm not aware of specific comments about Kent, so they may be fine, and they may have turned things around since the Hextable days. But I'd be doing my own checks if it was me, to be sure.
meaningking (Thu Aug 27, 2020 7:44 am)
Has thanked: 572 times
Been thanked: 2429 times
You might get more detailed responses regarding Kent aka Hextable, if this thread was in the Members Only area rather that the public area...
Ball07 (Wed May 15, 2019 12:42 pm)
Juey
RX-8: Import
Colour: Black Cherry
Has thanked: 21 times
Been thanked: 129 times
Post by Juey »
test results are in.....
These users thanked the author Juey for the post:
v-rex (Thu Aug 27, 2020 9:12 am)
Black Cherry Mica
I can explain it to you, but I can't understand it for you.
Ball07
Post by Ball07 »
warpc0il wrote:
Wed May 15, 2019 12:32 pm
Good point, still finding my feet on this forum. Thanks.
Mpv2k3
Has thanked: 233 times
Been thanked: 485 times
Post by Mpv2k3 »
Lewis owns LC Motorsport ( formerly Lc Rotary) and has moved location to near swanscombe (bluewater) and Reece owns the performance shop..... which deals with parts etc. Two separate companies but with connections :thumright:
Mpv2k3
Post by Mpv2k3 »
Ball07 wrote:
Wed May 15, 2019 10:34 am
Yes, I was there the other day chatting with Reece and the guys from Kent rotaries was there. It was mentioned that Reece deals with their services now and rebuilds are left to Lewis at lc Motorsport. I believe there is also a nice R3 for sale at the performance shop in diamond grey
meaningking
Has thanked: 18 times
Been thanked: 5 times
Post by meaningking »
Just wondering if anyone had any more dealings with Kent Rotary (formally Hextable as stated above)?
Mpv2k3
Post by Mpv2k3 »
I believe that TPS (reece) still does their work. I have seen them drop off a few different cars not just Rx8's. Not had any dealings with them myself though.
These users thanked the author Mpv2k3 for the post:
meaningking (Thu Aug 27, 2020 8:22 am)
bc-49
Has thanked: 118 times
Been thanked: 87 times
Post by bc-49 »
I had my car serviced and MOT’d at TPS last week, first time I’ve taken it to them since moving house.
Met Reece, Kim and Josh, all really nice blokes with a good knowledge of the 8. They are diversifying their business, doing MX-5s, Minis amongst other things, in a similar way to RR becoming MAP and working on Mustangs.
Lewis’ separate LC Motorsport page isn’t active anymore, so not sure if he’s still trading?
https://lcmotorsport.com/
These users thanked the author bc-49 for the post (total 3):
meaningking (Thu Aug 27, 2020 10:13 am) • GreySilver Beast (Thu Aug 27, 2020 10:41 am) • v-rex (Thu Aug 27, 2020 11:07 am)
2006 Galaxy Grey 231
Nankang NS-2R | Eibach Pro-Kit Springs | Eibach 20mm Spacers | Mintex 1144 Pads | Racing Beat REV8 Catback + High Flow Cat | BHR Ignition | K&N Filter | Koyo Rad | Mishimoto Thermostat | Greddy Sump with ER Lines | Lockwood Grills
SprintRX8
Has thanked: 9 times
Been thanked: 50 times
Post by SprintRX8 »
PM sent 👍 to Ball07
13BLT Renesis Rotary powered Dolomite Sprint in the making😏.
meaningking
SprintRX8 wrote:
Thu Aug 27, 2020 10:10 am
PM sent 👍 to Ball07
If you have any information I would be glad to hear also. I PM’ed you SprintRX8
Mpv2k3
Post by Mpv2k3 »
bc-49 wrote:
Thu Aug 27, 2020 9:22 am
Lewis is no longer trading.
Mpv2k3 (Thu Aug 27, 2020 6:52 pm)
Mpv2k3
Post by Mpv2k3 »
Oh thats interesting,..... he dropped off the radar as there were some bad customer service issues and I believe some legal claims against them in the end.
As far as I'm aware he is now just a self employed
sparky. Maybe the correct paperwork were never submitted.
These users thanked the author Mpv2k3 for the post (total 2):
bc-49 (Thu Aug 27, 2020 7:35 pm) • Pingping010101 (Sat Aug 29, 2020 10:14 pm)
Return to “RX-8 Discussion”
