Hi I need some new discs for my car , I have seen some mtec ones on eBay,do you think they will be ok as the price looks ok,
Any advice welcome and is 290 pounds a good price.
Thanks mark
K sport 356mm discs
Re: K sport 356mm discs
MTEC discs are great, although people like to slag them off.
I'm on Mintex discs at the moment and I miss the MTECs.
K sport 356mm discs
There is also nothing wrong with the OEM Disc's either Mark
- Has thanked: 35 times
- Been thanked: 73 times
Thanks for the reply new juke,my choice is quite limited and expensive,did you track the mtecs if so did the brakes feel the same after some hard work,
- Former Trader
Try DC performance for replacement k sport/D2 disks.
My MTEC discs were OEM size, not your larger size. But yes I used the MTECs for about 25k miles and 5 track days. They were slotted and drilled and black coated. Whereas the Mintex discs I use now are OEM style and smooth, and a definite retrograde step in braking performance.
The MTEC discs did wear down pads much more quickly (like a cheese grater) but they were excellent. Never warped or cracked and had barely worn when I replaced them. They didn't rust bond to the hub either, unlike every uncoated disc I've ever used. They're excellent value for money and I found them well made and solid.
MTEC have a few different options so maybe the pad wear rate will vary depending on which design is chosen.
Happy shopping
