Uprated engine mounts?
Hi,
Has anyone here replaced their engine mounts with more harder, uprated ones? Did you notice a dfference in throttle response? I have founds two sets online, which one woud you recommend?
http://essexrotarystore.com/product/bla ... mount-set/
https://h-tune.co.uk/hardrace-uprated-e ... gIUmvD_BwE
PZ Galaxy Grey, D585 coils, uprated MSD leads, Tesco Momentum 99 with Castrol Power 2T pre-mix
- Been thanked: 310 times
Re: Uprated engine mounts?
A harder engine mount will not make a difference to throttle response as such.
People have used lots of different ones and it is also possible to refill old ones to the stiffness you require.
Quite a few people have gone to stiff mounts only to find they can be hard to live with and reverted to something else.
One of the few ( mods ) that people often admit they regretted.
- These users thanked the author Conan for the post:
- Milos_Balunovic (Tue Aug 17, 2021 7:32 am)
- Been thanked: 453 times
Be aware, from experience, the BHR mounts will transmit a lot more vibration into the chassis.
- Been thanked: 4 times
Don't do it, stick with Mazda mounts.
Maybe I should list the things I wouldn't do to the RX8.
Engine mounts
Rear diff mounts
Stage 2 clutch.
I asked for the engine mounts to be replaced only if failed. They were replaced only to find nothing wrong with my originals. The mounts transfer to much vibration into the cabin, especially at 30mph. So around town is unpleasant.
Rear diff mounts I did to try and curtail hopping when launching for Hill Climb starts. It hasn't resolved the issue and the vibrations into the cabin are bad.
The clutch is fitted was a competition clutch stage 2 along with flywheel and counter weight. Flywheel excellent, clutch horrible, standard exedy is much better.
Engine mounts
Rear diff mounts
Stage 2 clutch.
- These users thanked the author Freeman38 for the post:
- Milos_Balunovic (Tue Aug 17, 2021 7:34 am)
Check out these:
https://www.ryanrotaryperformance.com/s ... ine-mounts
A few members have them, and they are without doubt the best looking mounts around. And, being British, and from one of our Traders, you will get exceptional support as well.
What a great idea,Freeman38 wrote: ↑Fri Mar 29, 2019 10:35 amDon't do it, stick with Mazda mounts.
Engine mounts
Rear diff mounts
Stage 2 clutch.
We should have a don’t do it thread
- Has thanked: 18 times
- Been thanked: 78 times
I love my rrp engine mounts, but depends what you want from the car, I haven't noticed much more vibration in the cabin, and the drivetrain feels "tighter", rear Diff mounts in the other hand, I get a nice back massage on decel with those.
- These users thanked the author Eddie_r32 for the post:
- Freeman38 (Sat Mar 30, 2019 7:18 am)
2007 Galaxy grey 231.
- Has thanked: 66 times
I have the BHR mounts on mine. At first the vibration was ridiculous. After about 1k miles they have completely settled now.
RX8 R3 Aurora Blue Mica
- Has thanked: 53 times
- Been thanked: 76 times
Bit of a thread derailment, but axle tramp is usually caused by rear suspension bushings and not diff bushings.
As the wheels begin to accelerate the bushes allow a certain amount of play, so the wheels begin to move but the car does not. As the wheels move to the point the lateral flex is "used up" it transmits a bit of force in to the vertical bushes and shocks. As they compress a bit the contact patch of the tyre reduces due to the current toe and camber of the wheel within the flex. This causes the tyre to lose grip. As the tyre loses grip it begins to return to its normal position because of the bushes. This causes the tyre to regain a larger contact patch and thus more grip, the cycle repeats (very quickly) causing axle tramp.
Likewise, older (and potentially deteriorated bushes) will make this worse, so just replacing the bushes with new Mazda ones would go some to reducing it.
There is no sure-fire way to resolve this issue, however firmer rear suspension bushes have been reported to minimise it and make the process of the rear tyres breaking traction to be smooth rather than sharp, thus resulting in wheelspin rather than axle tramp and a more controllable launch.
DISCLAIMER: I have not done this myself, but did a fair amount of research when I was frequenting Santa Pod drag strip. As I learnt to warm the tyres up, decrease pressures etc. the effect became more pronounced.
- Milos_Balunovic (Tue Aug 17, 2021 7:35 am)
- Has thanked: 38 times
- Been thanked: 116 times
I have big Pete home made mounts they are perfect and don't break the bank
LEXUS LS430 4.3 v8 family car
Done exhaust and work wheels
My thoughts on engine mounts are included in this
viewtopic.php?f=6&t=78199&hilit=engine+mounts
- Milos_Balunovic (Tue Aug 17, 2021 7:36 am)
I can add my own experience on refurbed Mounts (solid fill) ...
Found when first fitted they substantially increased NVH but after about a few months I think its think a combination of I don't notice it as much and the NVH has decreased.
(in the end you pay your money and take your choice)
- Been thanked: 18 times
i went with some ebay special solid fill mounts and tbh, didnt notice any real difference in vibration or noise.
the mounts i removed were perfectly fine stock items.
go for it for peice of mind as they wont collapse like the stock ones can over time.
However the lack of movement, especially vertical, could cause damage to the body shell, as it's designed to be isolated.
That wouldn't give me "peace of mind"
Saw the vid of Nick's (13Black) and there was still ample movement in the PU jobbers. I wouldn't be worried at all
- Founder Member
- Been thanked: 3 times
Not entirely sure because it was a while ago, but when mine collapsed, Clive at Mazda Rotary Parts provided me with mounts from the auto RX8 as they are apparently a bit more robust. They've now done 10 years with no issues and no additional vibration.
Sent from my SM-G935F using Tapatalk
There once was a man from Essex,
Who was potty over Mazda RXs.
He ordered an 8,
and had to wait,
But when it arrived, said "tis better than sex is".
He ordered an 8,
and had to wait,
- Been thanked: 109 times
I've had the BHR mounts on my R3 since July 2016,and although I've now become totally accustomed to it,they do give an increase in NVH levels - low speed maneuvering,and pulling away in traffic causes reverberation through the door cavities,which is intrusive enough for a number of passengers to have commented on it..
On an upside,they aren't ever going to need replacing again,and since the engine is locked in place more sturdily,there's a small improvement in the car's response to throttle inputs,as the motor's tendency to 'wallow' on the mounts is pretty much eliminated.
They are pricey tho',and the NVH issue may not be welcome to some,so try and experience a car with them fitted before you buy,if you decide on these mounts
- Has thanked: 90 times
Made my own engine mounts with rubber in fill
Thanks Dr FrankenRex2 but mines fully polybushed. Did them all and that was before the diff bushes.Bit of a thread derailment, but axle tramp is usually caused by rear suspension bushings and not diff bushings
That could be the problem, as polybushes are a downgrade, when compared to the oem design.
viewtopic.php?f=6&t=78199&hilit=polybush
- Milos_Balunovic (Tue Aug 17, 2021 7:38 am)
Disagree the polybushes were massive improvement over stock. Like wise when people say the strut brace in the rear is not worth it. Wrong I changed the front and added the rear strut bars before doing ARBs and there was big improvement.warpc0il wrote: ↑Sat Mar 30, 2019 7:19 amThat could be the problem, as polybushes are a downgrade, when compared to the oem design.
Were your OEM bushes knackered? A good portion of mine certainly were when I polybushed my own
Even wooden* bushes would be an improvement over broken bushes, regardless of the original design, but that doesn't detract from the fact that new Mazda RX8 suspension bushes are superior to any off-the-shelf polybush alternative and these polybushes won't provide the combination of compliance in one plane with the rigidity in the other that is a significant factor in the cars handling.
*A friend of a friend fitted home-made wooden bushes in the suspension of his MX5 track car and they lasted nearly two seasons, and may have gone on for longer if the car hadn't been destroyed in a freak accident when the propshaft ripped itself apart. MX5 propshafts aren't known for this sort of failure and it may have been caused by vibration in the rear axle/suspension.
I had new arms fitted on front as part of the recall which have brand new Mazda bushes. I noticed a big difference between them and my polybushed arms which I had to get Mazda UK to honour the garage additional time to press my polybushed out. The front end had lost some of it immediacy and feel.. so I still disagree that Mazda bushes are superior to the Poly Bushes. None of my Mazda bushes were in a bad state when I replaced them in 2013.warpc0il wrote: ↑Sat Mar 30, 2019 10:24 amEven wooden* bushes would be an improvement over broken bushes, regardless of the original design, but that doesn't detract from the fact that new Mazda RX8 suspension bushes are superior to any off-the-shelf polybush alternative and these polybushes won't provide the combination of compliance in one plane with the rigidity in the other that is a significant factor in the cars handling.
- Bigblueknight3k (Sun Mar 31, 2019 3:02 pm)
