Power loss
Re: Power loss
Hi and Alikhan2211. That is the coolant level warning light. Check your coolant level - it is very likely it is completely fine, a common problem is that the float in the coolant tank is sinking because the surface has broken down allowing it to get waterlogged.
If your coolant level is not low you can do any one of these three things:
1 Replace the coolant tank (they are about £130 I think)
2 Unplug the sensor at the side of the coolant tank - the light will not come on again ... check the coolant level regularly.
or
3 Ignore the light ... check the coolant level regularly.
or
- Alikhan2211 (Thu Mar 28, 2019 1:18 pm)
Re: Power loss
If it revs to 9k rpm then it's not a 192.
Given the number of advisories on the last MOT, I'd say she needs some TLC
If they're not all the same size and pressure then this will kill engine power.
What sizes are the tyres?MOT" wrote:Monitor and repair if necessary (advisories):
Offside Rear Brake pipe corroded, covered in grease or other material (1.1.11 (c))
Nearside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c))
Front Subframe mounting prescribed area is corroded but not considered excessive (5.3.6 (a) (i))
Front Integral body structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security floor (6.2.2 (d) (i))
Rear Integral body structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security (6.2.2 (d) (i))
Nearside Integral body structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security outer sill (6.2.2 (d) (i))
Nearside Integral body structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security inner sill (6.2.2 (d) (i))
Offside Integral body structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security outer sill (6.2.2 (d) (i))
Offside Integral body structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security inner sill (6.2.2 (d) (i))
Nearside Rear Integral body structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security wheel arch (6.2.2 (d) (i))
Offside Rear Integral body structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security wheel arch (6.2.2 (d) (i))
Offside Rear Tyre worn close to legal limit/worn on edge (5.2.3 (e))
Offside Front Service brake binding but not excessively (1.2.1 (f))
- Colour: Phantom Blue
- Has thanked: 12 times
Re: Power loss
When I put my full foot down you can feel it lagging
And all tryes are same size
Re: Power loss
According to a quick check on the registration it's a 192.
First things to check would be coils and spark plugs
then check the catalytic convertor
- Been thanked: 451 times
Re: Power loss
How can it get to 9000rpm? The picture you posted (above) shows the redline way below that, so it's a 7,500rpm 192 engine.
Re: Power loss
192s can be rebuilt and remapped to have higher limiters peeps...
Re: Power loss
They can, but that hasn't been mentioned. And if it hasn't had serious porting work done to it then it's going to feel laggy, and lacking in power above 7500rpm, regardless of where the limiter is set. Since the OP is complaining of lack of power when approaching 9000rpm, we have to ask.......
- Has thanked: 319 times
- Been thanked: 257 times
Re: Power loss
If that's Phantom Blue then it needs a wash
- kopite72 (Thu Mar 28, 2019 5:02 pm)
Re: Power loss
DVLA say it's black ! Could be his 2nd carMARKTHOMASBRAND wrote:If that's Phantom Blue then it needs a wash
Re: Power loss
Sorry it is about 7000rpm
But scrap that
My car won’t turn over where do I start
But scrap that
Re: Power loss
But scrap that
But scrap that
- Been thanked: 546 times
Re: Power loss
with the battery, asuming you mean the engine doesnt rotate, rather than it turns over but doesnt start.
- Has thanked: 13 times
- Been thanked: 10 times
Re: Power loss
What's the battery voltage? Even better would be while you try and crank. Does it just click and dash lights go out?
Re: Power loss
It keeps trying the lights go out but it’ll keep trying ?
Re: Power loss
Are you able to check for any obd codes? You can get a cheap Bluetooth reader for under £20
Re: Power loss
I would have to purchase one. At the moment I’m driving myself mad with it
