Flowing water noise?
- Has thanked: 58 times
- Been thanked: 22 times
First time I've noticed it - started up today and it's like I can hear the coolant running through? Is that normal?
- Been thanked: 310 times
Re: Flowing water noise?
Impossible to tell from your description but it’s normally air in the system that can give a noise.
Keep your eye on the fluid level
I've noticed a trickling water sound several times before. Coolant has always been at the correct level and coolant temperature has always been fine.
I assumed it was the air conditioning system but I really have no idea.
Sent from my SM-G955F using Tapatalk
Well the air con isnt on but yeah, I started it cold, let it sit for a couple minutes, came out and sat inside the car and could hear the gushing of water. Panic immediately set in but looking underneath and on top - no leaks.
It increased with revs too. It's now been sat and just started again and I can def still hear it! Swear I couldnt before..
- Has thanked: 97 times
- Been thanked: 539 times
- Been thanked: 18 times
when i drained and replaced my coolant i had a slight noise every now and then. it was a little bit of air that was trapped in the system.
i just popped the coolant pipe off that goes into the top of the throttle body a few times and it seemed to do the trick.
if it has come from nowhere you most likely have a leak.
Ah. I presume from when I had the pipe off to the throttle body when taking the manifold on top off. easiest way to get the air out of these? I'll try taking the pipe off from the top of the throttle body..
- Been thanked: 2080 times
The only legitimate (not a problem) source of running water sound would be the condensate drain from the ac, and even then only in unusual conditions.
Water/coolant flowing through a closed system shouldn't make a noise unless there's also air where there shouldn't be.
- Been thanked: 35 times
To correct a couple of the statements above, it's more likely the heater matrix than the air con (although they are the same box, they use different coolant loops). If the heater matrix is clogged or has an airlock it will make a sound like running water, and if you blip the throttle you'll probably hear a brief increase in that sound. Might be worth checking whether your heater blows hot air, and if not, it's time to flush the matrix.
- Has thanked: 2567 times
If you top it up at all, unless its just a 1/2 litre or so then use FL22 as that is what the system is filled with.
IIRC the coolant always flows through the heater matrix, even when the heater is "off" or set to cold.
The temperature control determines how much of the incoming air is routed through the matrix.
This is different to many cars where the air always flows through the heater matix and the coolant flow is managed by the heater control.
The advantages of our system are;
- much faster response to changes in set air temperature, as the matrix is always hot.
- the engine doesn't get hit with a chuck of cooled coolant, as it would if the flow was changed.
- there's no coolant flow valve that can leak
However, it does mean that any issue that related to un-bled air in the coolant won't sound any different regardless of what you do with the heater control, since you're only switching the cabin airflow not the coolant routing.
- RX8765 (Tue Mar 05, 2019 6:04 pm) • ChrisHolmes (Tue Mar 05, 2019 6:05 pm)
Thanks Warp, interesting and good to know.
However it does somewhat conflict I think, with what ive done prior to your information. I've bled previous cars such as an mg tf by opening the coolant bottle, maxing the heat and the fans for a bit and that's about it. So I've done the same and I couldnt hear the noise anymore? Coincidence, or maybe the noise will still be there tomorrow.
Fingers crossed its now gone.
If I'm right then it doesn't stop your process working, it just means that you didn't have to "max the heat and the fans for a bit" and it still would have worked.hogesar wrote: ↑Tue Mar 05, 2019 9:12 pmThanks Warp, interesting and good to know.
- hogesar (Wed Mar 06, 2019 7:38 am)
Good news because it appears to be fixed! Now on to my next, potentially more serious issue which i'll post separately..
Dave, you are indeed correct about the way the heating system works. If you have the filters out and the glovebox open with the fans on, you can actually hear the sound of rushing air change as you alter the temperature. Increasing the temperature will drag more air through the heater core, which sounds distinct from air being drawn across the air con evaporator or in from outside. Give it a try some time, it's 5 minutes you'll never get back but i reckon you'll appreciate it
Ok so I appear to be losing coolant. But I cant visibly see a leak, which is obviously not a great diagnosis to begin with.
Anywhere to look?
Anywhere to look?
I should say, anywhere to look that's not obvious or easy to see from the engine bay!
Check the cabin carpet, especially in the passenger footwell, as this is easy to miss.
- Has thanked: 18 times
- Been thanked: 78 times
Have you been topping it up much since the flowing water sound disappeared it could just be air locks being bled out which will drop coolant level
- These users thanked the author Eddie_r32 for the post:
- ChrisHolmes (Sat Mar 09, 2019 8:11 pm)
2007 Galaxy grey 231.
Never top-up above the level mark on the expansion tank, which is only half-way up, otherwise it will just eject the excess and you'll be left wondering where it went.
And never trust the coolant level light - it lies.
Hmm...maybe theres more air locks than I thought. I'll look at it when cold tomorrow morning and top up if necessary but it took a half litre this morning and 250ml the other day.
