Rasp from engine...help!
Rotaryjon
Forum Guest
Forum Guest
Colour: Metropolitan Grey
Has thanked: 8 times
Post by Rotaryjon »
Hi guys,
Ok so I'm looking for some advice.
My 40th anniversary rex is making a nasty rasp noise when under heavy load (not when just gradually accelerating) I've searched the forum and I'm pretty sure it's not the marbles in a can issue.
Take a look at:
No error lights coming on and no real loss of power.
noise is less noticeable when running shell nitro or BP ultimate. Any other pertrol including Tesco momentum increases the noise sound.
Cleaned the MAF (was a bit dirty) with MAF cleaner (which actually made the noise worse!).
Got new spark plugs coming Monday (just incase).
I think It's had the leads done (blue in colour think racing beats) back when Tony had the car (sorry, can't find my old login details or old thread about my car so made new account).
Anyone come across this before?
Car starts hot and cold without issues. Revs can be a bit rough at startup but only dropping for a split second etc.
Any help would be appreciated.
P.s. I think the old thread on my car was called 'tonys 40th anniversary' or something similar but can't find it (prob been deleted as was old?)
Has thanked: 265 times
Been thanked: 359 times
Re: Rasp from engine...help!
Post by 13Black »
I'd say that's bearing failure I'm afraid.
I do hope I'm wrong though.
Rotaryjon (Mon Feb 18, 2019 7:49 am)
Has thanked: 54 times
Been thanked: 367 times
Post by PeteH »
It's got to be worth checking for loose heat shields, and getting the exhaust off and giving it a shake. I'd say it was exhaust resonance, but Nick's listened to more dead engines than I have.
Rotaryjon (Mon Feb 18, 2019 7:48 am)
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
Thanks for feedback.
I'll try and get under it on Monday (local garage should let me use lifter for a bit).
Just to clarify, the noise isn't the 'packet of crisps' style noise in the video (that's just bits e.g dash cam rattling in the car), it's the deeper rough sound getting louder as rpm increase.
I hope it isn't bearings as that's sadly game over (rebuild would be more than value of car :( )
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
P.s. 67k on clock
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
P.p.s would the fuel type make that much of a difference to engine bearing sound?
Has thanked: 444 times
Been thanked: 2087 times
Some 8s can be rough a noisy on cheap fuel. e.g 95 octane supermarket stuff.
Try some Shell V-Power or Tesco Momentum and see if it makes any difference to yours
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
Hi Dave,
Yes, below is what happens,
Shell v power nitro etc etc = very little sound if anything
BP ultimate = same as shell
Esso premium = noise
Tesco mementun = noise
Any other pertrol 'premium' = worse noise
Noise has got worse since cleaning MAF.
So the answer is....
.... stick with Shell V Power or BP Ultimate and she'll be happy.
Some 8s are just like that, while others don't seem to care.
My 8 isn't noisy on cheap fuel but runs noticeably smoother on 98+
There's no Shell V Power, BP Ultimate or Tesco Momentum in NI ;(
So she usually gets treated to Sainsburys Premium
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
Sadly that's not really an option. Nearest shell and BP is a 40 minutes drive away. Also noise is new (over last few 5 ish months) getting gradually worse (Esso premium didn't used to make any noise).
Rather work out what was causing the noise.
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
@13black, what are the other symptoms of bearing failure?
98of400
Has thanked: 21 times
Been thanked: 47 times
Post by 98of400 »
That's not dissimilar to the noise my 40th is making. Mine is only doing it when the engine is hot i.e. after a long drive or after it's being sitting a jam. Also only when I'm accelerating - as soon as take my foot of the gas it goes.
I checked my cat today, see my post, but ain't sure if it's clogged or not. While under there I did notice the heat shield in front of the cat (not the big shield around the cat), just before the pipe goes up, is rusty and loose, so it could be that resonating when hot and under load.
Our cars will be the same age so yours could be the same underneath. Might be worth checking.
Sent from my Moto G (5S) Plus using Tapatalk
These users thanked the author 98of400 for the post:
Has thanked: 1581 times
Been thanked: 365 times
Post by GreySilver Beast »
Hi Jon & :welcome: to the RX-8OC :thumleft:
Please put your Location here in the Profile Section =D>
Please check out the EVENTS SECTION's :thumleft: - Events Team
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
@98, mine does it when foot is flat down (hot or cold) but only when driving (not parked). Foot off and noise instantly goes.
Easier to reproduce on hills when accelerating.
My cat did go a while ago (got a new one put on). At first I thought a blocked exhaust but I've got no loss of power.
Do you have any power loss?
Try driving car hard at night then pull up and see if you can see any glow from cat (my old man swares by it as a way to confirm a cats blocked).
P.s. mines 2008.
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
@greysilver, not a new member bud, just can't for the love of me remember my old username #-o (and old email address is long dead) and can't find membership email/PayPal payment :roll: (was a loooong time ago though when I joined (back in 2013 ish).
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
P.s. can a mod move this to "RX-8 Discussion"?
Thread moved as requested.
Were you previously an RX8 Owners Club member or did you just have a guest account on the forum, as today?
Has thanked: 318 times
Been thanked: 256 times
Post by MARKTHOMASBRAND »
Rotaryjon wrote:
Sat Feb 16, 2019 10:13 pm
Previous Club Member I'd say Dave :)
:arrow: Is this you ?
Give me a clue...location would be nice :p
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
Not me sadly. Yes, was a member (back when u gave a tax window sticker and a clear plastic credit card). Was based in Sheffield back then.
There was a thread about my car on here at one point. A guy called Tony had it (he swapped it for a Subaru if I remember correctly). Did a thread regarding the changes he had made and I added to it. It was a while ago now so I suspect it's been deleted (?) as I can't find it. (Checked with PayPal but can't go back past 2016)
These users thanked the author MARKTHOMASBRAND for the post (total 5):
PeteH (Sun Feb 17, 2019 10:48 pm) • Rotaryjon (Sun Feb 17, 2019 11:14 pm) • jonathanp (Sun Feb 17, 2019 11:14 pm) • casey (Mon Feb 18, 2019 12:27 am) • New Duke (Sun Jun 16, 2019 11:05 pm)
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
YEEESSSS!
Rotaryjon
Forum Guest
Forum Guest
Post by Rotaryjon »
Sadly it's linked to my old email address so can't reset it.
jonathanp
Post by jonathanp »
I'm in! Thx for your help mark :thumright:
These users thanked the author jonathanp for the post:
MARKTHOMASBRAND (Sun Feb 17, 2019 7:27 pm)
