My high beam fuse keeps blowing and no idea why, have changed it twice over the weekend.
Hope that someone can help with this issue and thanks in advance.
Hign beam fuse keeps blowing
Winning Blue 231
Climair Wind Deflectors
Toyo Catback
Gunmetal Rear Lights
Carbon Fibre effect eye lids
Gunmetal Grey RX8 Familia decals
Gunmetal Grey RX8 side decals
Chrome lower front grille
Magnacore leads NGK Spark plugs
Blue interior LEDS
Black side grilles
Racing Beats radiator protectors
Pipercross Panel Filter
Yellow front strut brace
Blue under bonnet covers
Yellow brake calipers
Toyo Catback
Blue interior LEDS
Black side grilles
Re: Hign beam fuse keeps blowing
Like most blown fuse issues, it's probably a positive wire on the lights shorting out to ground occasionally.
Get a multimeter out and probe the positive terminal on the plug and a good ground for continuity, and give the loom a wiggle.
And follow the wiring as far back as you can.
- CookieMonster (Mon Feb 04, 2019 2:19 pm)
The wiring is the most likely but it can also be caused by a failing bulb or bulb-holder, especially if uprated bulbs have been fitted.
Cheap (e.g. ebay) fuses can sometimes be considerably outside the expected amperage tolerance.
Usually they are over-rated e.g. a "15A" fuse doesn't blow until hit with 20+ amps, but sometimes it only takes 12A
I once wasted an afternoon chasing "a short circuit" that turned out to be a duff batch of fuses from Halfrauds
I have got Halfords fuses now wondering if I too have a duff batch.
Thanks mate
Thanks mate
Winning Blue 231
Toyo Catback
Blue interior LEDS
Black side grilles
Toyo Catback
Blue interior LEDS
Black side grilles
