Hey all,
I have done many searches regarding the oil Gunk and all I seem to find is the ones regarding the dipstick.
I first noticed it via the dipstick then done lots of reading on here which made me feel for at ease.
But today I went to top up the oil and noticed a similar gunk foam all down the filler pipe. Is this the same as the dipstick situation or has my problem evolved and got worse?
I will upload a picture shortly.
https://photos.app.goo.gl/PrC6F3Ed1v4tarqB6
Oil Gunk Help
- Been thanked: 109 times
Re: Oil Gunk Help
'Mayonnaise' on the dipstick,and even inside the oil filler cap,is nothing particularly to worry about,especially at this time of year
As long as the coolant level isn't noticeably dropping,and the car is otherwise running well,no need to be concerned.
Re: Oil Gunk Help
Thanks for the reply. Was worried as couldn't find much mentioning the filler neck.
Cheers
Cheers
Re: Oil Gunk Help
It does imply that your oil is not getting up to temperature, which isn't good for engine life.
Probably caused by lots of cold starts and short journeys.
You might like to try The MouseMat mod this time of year
viewtopic.php?f=30&t=53888
Re: Oil Gunk Help
Hi and Liddon21 and (Dave - I assume you meant it implies his oil is NOT getting up to temperature?)
- RobinPZ72 (Mon Feb 04, 2019 8:41 am)
- Has thanked: 49 times
- Been thanked: 20 times
Re: Oil Gunk Help
I was scared to question that!!!
How old is the oil and do you know what was put in?
- Has thanked: 93 times
- Been thanked: 165 times
Re: Oil Gunk Help
I have always had mayonaise in the filler nexk and on the underside of the oil cap on my 05 231.
That is despite 3 different engine configurations and two rebuilds. I put it down to the fact that it is not driven regulary (can be standing for two to three weeks without use). It is thrashed when it is driven though! (after allowing a suitable time to heat up)
Our R3 has never had any mayo whatsoever and that can stand unused for a couple of days. The oil breather arrangement is totally different on the R3 so maybe that has a bearing as well.
Re: Oil Gunk Help
It would be worth checking the front grill directly below the number plate. The diamond-shaped holes should be blocked off by a blanking plate the Mazda added to stop the outside of the engine getting chilled. Some misinformed owners remove this plate "to assist cooling" and/or "to increase power" and it just causes increased thermal stress on the block and more mayo in the oil.
The airflow to the radiator is through the mouth opening below the grill, so you have to consider this if you lower the number plate.
- RX-8: Import
- Colour: Black Cherry
- Been thanked: 119 times
Re: Oil Gunk Help
Interestingly (or not) my JDM hasn't got this blanking sheet fitted. Not something I've removed. ......but I only have 1 oil cooler so that maybe evens it up
Black Cherry Mica
