Rhombus rotary
bigpete8
Has thanked: 150 times
Been thanked: 162 times
Rhombus rotary
Post by bigpete8 »
Allows applications where revs above 9k are needed... 🤔
https://www.popularmechanics.com/cars/c ... ry-engine/
Has thanked: 444 times
Been thanked: 2087 times
Re: Rhombus rotary
Just imagine the mess a touch of pre-ignition would make of that thing :shock:
Humane-Hobgoblin
RX-8: 13B 4-port
Has thanked: 33 times
Been thanked: 56 times
Re: Rhombus rotary
Post by Humane-Hobgoblin »
I’d be quite happy to use that above 9k rpm...
RenesisRaceBuggy
Has thanked: 30 times
Been thanked: 92 times
Re: Rhombus rotary
Post by RenesisRaceBuggy »
That's going to have insane seal and chamber wear issues, given the tips are taking all the loads. There's also going to be a crankcase full of fuel and air mixture...
geofftl1000r
Colour: Metropolitan Grey
Has thanked: 75 times
Been thanked: 34 times
Re: Rhombus rotary
Post by geofftl1000r »
Twice as many seals and what looks like little end bearings to lube.
Could you actually make this amount of metal spin to 3 times what a Rotor can do? It looks like rotor rpm matches crank/eshaft rpm.
Does it brap?
40th Anniversary RX8
