Driveway access
- Has thanked: 63 times
Driveway access
Not sure if this right section so feel free to move if required.
I have 2 problems with in and out access of my driveway. My driveway is a steep slope (slopes up from the house) and i park sideways on, across front of house. I will try my best to explain
Issue 1 - Getting out - So, the car is parked parallel with the front of the house and to get out of the driveway i need to swing the front hard round to the left to access the drop kerb. (The drop kerb width is much narrower than what is normal these days) The issue I have is as i swing round (hard left) and as i approach the summit of the driveway there is a brick post on the right side. At the sloped angle upwards I am in it is very difficult to judge how close I am to the brick post. I need to stay as wide as i can (near to the brick post) otherwise i miss the drop kerb, and i cant get out.
My question is - Is there anything I can attach to, or next to the the brick post that will allow me to get as near as I can without impacting?? (front parking sensors apart)
Issue 2 - Getting In - (and In addition to the above problem but in reverse), I live in a dark and narrow road and always reverse in (left hand down). I need to stay as near to the parked car on the road on my near side (my works van normally) to allow room to swing in without impacting the wall opposite. Getting in is fine during day, however at night it is very difficult to see the edge of the parked vehicle when relying on reverse lights of the RX8 for my only illumination.
My question is - Is there anyway of enhancing/improving the reverse lights on my RX8?? or as its my works van normally, is there anything that I can attach to the front bumper corner of my works van that will help highlight it in this situation?
Hopefully this makes a little sense
Nb : Long term plan is to widen drop kerb.
- Been thanked: 109 times
Re: Driveway access
The brick post you mention,is it a gatepost? If not,or if you don't have gates,and the post is on your property,why not just get rid of it
Re: Driveway access
Fair enough,but how about just reversing down your driveway instead of parking parallel that way you won't have to swing left..
- Been thanked: 332 times
Re: Driveway access
you could try replacing the 21W reversing light bulbs with some high power LEDs
like this
https://www.ringautomotive.com/en/product/RW382DLED
560 lumens compared to the average output of 300 lumens for a 21E 12 incandescent
halfords should flog them
like this
- RX8Red72 (Sat Jan 12, 2019 8:54 pm)
- Has thanked: 319 times
- Been thanked: 257 times
Re: Driveway access
Time to move house
- These users thanked the author MARKTHOMASBRAND for the post (total 2):
- RX8Red72 (Sat Jan 12, 2019 8:56 pm) • GreySilver Beast (Sat Jan 12, 2019 9:27 pm)
Re: Driveway access
Leave the works van parked on the road,and park your '8 as I suggested earlier..
Re: Driveway access
Thanks mate. I'll check them out350matt wrote: ↑Sat Jan 12, 2019 8:20 pmyou could try replacing the 21W reversing light bulbs with some high power LEDs
like this
Re: Driveway access
Looks like Halfords don't do an LED version of the 582 bulb we need
however you can buy a variety from here
https://www.autobulbsdirect.co.uk/582-7 ... led-bulbs/
Re: Driveway access
Don't forget RX8OC members discount
viewtopic.php?f=17&t=17001&p=232788&hil ... bs#p232788
- RX8Red72 (Sun Jan 13, 2019 12:08 am)
Re: Driveway access
Can I just check these bulbs are direct replacement without causing fault codes etc?
Re: Driveway access
No problem with replacing reversing lights.
If they don't work when you replace, try removing, rotating 180* and refitting, as the LED's are polarity sensitive.
Maths says there's a 50:50 chance that it will be wrong first time.
Sods Law says more like 90:10
That's turn the bulb in the holder, before anyone tries silly dance moves
- RX8Red72 (Sun Jan 13, 2019 12:07 am)
Re: Driveway access
I use these: https://www.horizonleds.co.uk/cree-leds ... -3156-cree
I have the 16W version if I remember correctly and it's very bright, makes backing onto a driveway much easier than with halogen bulbs.
Previously owned - Full Bridgeport 231 - Built by Rotary Revs
Now exclusively running BMWs
2018 BMW 118i
2015 BMW 430d GranCoupe
1999 Alpina B10 V8
2018 BMW 118i
1999 Alpina B10 V8
