Sports CAT Fitting question..
nintenjo
Has thanked: 6 times
Post by nintenjo »
I am in the process of fitting a new SS Sports Cat but there are some differences I am confused over..
My old decat was fitted with Spring bolts at the back but then new Cat is threaded at the back and comes with standard bolts + spring washers.
It all fits nicely together but was confused to why it’s different?
Also the front came supplied with a flat triangular gasket which is blowing on first test but I have a round flat type as well so wasn’t sure on people’s preference to use? And if I need any gasket sealant as well?
Feedback welcome as it’s all new to me.
Has thanked: 54 times
Been thanked: 367 times
Re: Sports CAT Fitting question..
Post by PeteH »
The flat triangular gasket is known to blow. They almost all do. The Mazda style circular crush gasket is much better.
The springs are essential. They allow the donut gasket to move (like a ball joint). Without this movement you will put stress on the exhaust (risking eventually cracking it), and the chance of leaks is much higher.
You can get fitting kits on eBay. Check them out. You will be able to find the right gaskets, bolts and springs.
Has thanked: 114 times
Been thanked: 158 times
Post by mrspiller »
Use the circular gasket on the front ,I done as you have on the rear and worked fine , just not too tight as it needs a bit of movement I think
nintenjo
Post by nintenjo »
PeteH wrote:The flat triangular gasket is known to blow. They almost all do. The Mazda style circular crush gasket is much better.
Ok great thanks I’ll swap gaskets over now.
I have a recommended fitting kit off eBay but the actual flange on my Cat is threaded with flat ends you can’t use the bolts which as tapered presumably to fit into a tapered flange (plus they don’t event fit through the threaded holes).
nintenjo
Post by nintenjo »
mrspiller wrote:Use the circular gasket on the front ,I done as you have on the rear and worked fine , just not too tight as it needs a bit of movement I think
Ok thanks I’ll be sure to slacken them a tad as wasn’t sure how tight to go.
Post by mrspiller »
I’d personally take Pete’s advice - much knowledge he has
Has thanked: 53 times
Been thanked: 76 times
Post by Scartlead »
Does the spring option need fitted both sides of a cat/decat? From memory mines only at the cat back join.
nintenjo
Post by nintenjo »
Ok I was being very stupid, it seems my mistake was copying how it was previously fitted.. and I was getting my back and front bolts mixed up.
Turning the bolts round with the proper spring kit made it all work correctly.. thanks all for advise think it’s finally done. (Pending gasket test).
722Adam
Has thanked: 10 times
Post by 722Adam »
KKS sports cat by any chance?
Confused me to start with as well, plus I had to find some new bolts and slightly shorter springs.
Previously owned - Full Bridgeport 231 - Built by Rotary Revs
Now exclusively running BMWs
2018 BMW 118i
2015 BMW 430d GranCoupe
1999 Alpina B10 V8
