Page 1 of 1
Clutches (5speed vs 6speed)
Posted: Sun Nov 25, 2018 9:30 pm
by Dockie
so it seems that after only 5k miles, the clutch has gone
looking at replacements (mainly the exedy one) there are 2 listed, 5speed and 6speed (192/231 i assume)
besides the price, is there actually any difference in the two?
Re: Clutches (5speed vs 6speed)
Posted: Sun Nov 25, 2018 9:36 pm
by qwakers
yes.
that is all
a 5 speed clutch will not fit a 6 speed or vice versa.
Posted: Sun Nov 25, 2018 9:39 pm
by acegeezer
..erm one is for a 5 speed box and the other a 6
.. what did you think?
.. sorry couldn't resist, only joking though
Posted: Sun Nov 25, 2018 9:53 pm
by Dockie
acegeezer wrote: ↑Sun Nov 25, 2018 9:39 pm
what did you think?
I get that they're listed as such
however i've found in alot of cases its the same thing under a different part number.
Posted: Sun Nov 25, 2018 10:00 pm
by 13Black
Different bolt PCDs and sizes - if you can get one to fit the other then I'll lick your gearbox clean.
Posted: Sun Nov 25, 2018 10:02 pm
by Dockie
13Black wrote: ↑Sun Nov 25, 2018 10:00 pm
Thanks, thats what i was looking for
by warpc0il
I've only even seen RX8 parts listed as different for the 192 and 231 where they're actually different parts.
However the opposite is true, where manufacturers/suppliers list the same part for both models, when they should be different.
For example, listing the same front lambda sensor for the 192/231.
or listing the same oil filter for the S1 & S2(R3)
or the same suspension spring for all models, including standard S1, PZ, 40th Anniversary and R3.
BTW I believe it is possible to fit a 192 clutch to a 231 and vice-versa, if you also change the flywheel as well, plus the counterweight (if none OEM), but there's usually no advantage.
The only exception is if you've highly tuned (e.g. fitted a turbo to) your 192 and need an uprated clutch that's only available in the 231 fitment.
192 clutches don't last long trying to manage the output of a 231.
Posted: Mon Nov 26, 2018 5:51 pm
by Scartlead
Even though a 192 has more torque..apparently
Posted: Mon Nov 26, 2018 5:57 pm
by Bullet5
warpc0il wrote: ↑Sun Nov 25, 2018 10:02 pm
I'm virtually certain this is correct, as when mine disintegrated I had a CC lightweight flywheel (and counterweight) fitted along side a 231 clutch in my 192 Nemesis for that little extra longevity and bite that comes with a larger diameter unit (very marginal, and I'm sure nobody would notice the difference but every little helps).
Posted: Tue Nov 27, 2018 8:58 am
by mrspiller
I fitted a 5 speed 192 box on my 231 ,
