Has anyone used K-Seal?
https://www.mazdarotaryparts.com/59612- ... TER-SEALER
I have a (presumably) slow coolant leak that I cannot find. The coolant needs about 500ml top up every 6 weeks or so. Can't see any stains on my drive and I can't find any evidence of a leak underneath or in the engine bay.
So, has anyone tried this? MRP seem to have done some rotary specific testing and deem it compatible.
- Been thanked: 108 times
Re: Has anyone used K-Seal?
I think its great stuff for your symptoms above id put in a couple of teaspoons.
Sim issue on amates audi a4 1.8 t...losing 500ml every thousand miles...hunted and hunted for the leak no joy..kseal rescued it.
Sealed up my holed rad on track day and fixed a cracked head on a vx220 infront of my very eyes that i tracked the next day.
Mondeodog towcar.
Mondeodog towcar.
- Been thanked: 220 times
DON’T USE IT
It not only seals the leak for a short period, but it also blocks the water galleries
We use it on bus and truck cooling systems as a temporary stop gap until we can fix it properly but when the engines are stripped down we find the water galleries and hoses are congested causing poor circulation.
Couple of teaspoonful fine not the whole bottle.
Kseal is like marmite....
Mondeodog towcar.
Mondeodog towcar.
Don't know that I'd be adding Marmite to my FL22...
i had a water seal failure on mine put a bottle in and it lasted 2 years till low compression forced a rebuild at RR
great stuff highly recommended
- Has thanked: 93 times
- Been thanked: 165 times
The alternatives are.
1) Put up with the coolant useage
2) Strip and re-build your engine
Faced with the above you are probably better off trying it and if it dies at sometime anyway you then have option 2.
- ChrisHolmes (Fri Nov 16, 2018 12:03 pm)
- Has thanked: 12 times
- Been thanked: 104 times
Topping up every six odd weeks seems a small price to pay when your topping up oil on a weekly basics, haha
The problem is that the cooling system relies on pressure to function.
If even a tiny leak is reducing the working pressure then this could cause serious issues.
I would do a UV trace to pinpoint the leak and focus on the permanent repair but if this wasn't possible in the short term then a small amount of K-Seal might achieve some level of protection without causing further problems.
Used it on the Alfa 147 and drove it for about 6 months before I sold it
Still showing as Taxed and tested 18 months on so guessing its still going strong lol
- Been thanked: 50 times
i used it to seal a cracked block (about 6 inched long between core plugs) on my suzuki offroader...it was thrashed mercilessly and overheated often and was still dry 2 years later,i sold it 18 months back and its now been exported to norway,and no one has mentioned a water leak yet.it the best sealer ive ever used.
- RX-8: 13B 6-port
- Has thanked: 20 times
Mate if you are going to purchase k-seal I got it it in 1 stop motorfactors in Sligo so im sure you can pick it up local enough to you, it was 20 notes.
Hayward stage 2 Port,Full RB Exhaust, RB L-Flywheel,Michelin Pilot Super Sport,Bola B1, Aero Kit,Light weight Pulleys,More To Come
- Been thanked: 18 times
It's a temporary fix, that is all.
As with lots of temp fixes, you can create extra work by having to flush the living he'll out of everything when you get round to repairing properly later down the line.
Of all the coolant temp fixes, k seal appears to get the best reviews.
In the world of engines, especially rotary, nothing is "permanent" and "temporary" can be just as long...
I've never known a K-Seal "repair" to fail down the line. It either works or it doesn't.
If it doesn't work with a small does then adding more won't make it work and will cause you more grief in other areas.
