New D585 coils
New D585 coils
Happy chappy guys :-D the coils finally came and their on and intstalled, turns first turn of key, sounds amazing drives like a ferrari unlike before, lots more pull even from low down the rev range, hoping the fuel econemy will be alot better so going to monitor next till i fill up, also.... the 5 fault codes have now gone bo misfires or lean bank 1 ect like my previous posts, only one i get is a p0137 i think... as i aint got it write down yet i think it was 02 sensor 1 low signal what ever that means but all in all very happy
- Been thanked: 109 times
Re: New D585 coils
Daleevs,as a non member you can't attach pics to your posts..
You'll have to upload them to an imagehosting site,and link to them
Re: New D585 coils
Ahha thats why it aint working, il try photobucket tomoz then thanks for the heads up, its a mad forum this in a good way, it has the same layout as alot of other hobby forums that im into such as shooting but has big restrictions on here unless your a member even though the other forums have the full shabang! Its all good though i did say il join once ive got the coils
- Has thanked: 84 times
- Been thanked: 20 times
Re: New D585 coils
D585s have slightly different timings to the stock coils, so getting your ignition timing remapped can actually make them perform slightly better. As I understand it most people don't actually bother, so it doesn't seem to be vital. Just thought I'd mention it!
Carl Ryan (Ryan Rotary on here) does remote mapping which looks like a great way if you do want to do it.
- Has thanked: 101 times
- Been thanked: 83 times
Re: New D585 coils
Photobucket is no good it's paid application now (unless you joined up) I would use this.. http://tinypic.com/
- MARKTHOMASBRAND (Tue Oct 16, 2018 6:20 pm)
Re: New D585 coils
Just to be clear, the D585 coils use the same ignition timing, in that the spark happens at the same time for combustion, as the original coils.
The difference is that the D585 coils can take longer to reach full charge between discharges, which is known as "dwell" - a term that goes back to when ignition coils were connected via mechanical switches "points" that were opened and closed by a cam. The "dwell angle" of the cam determined how long the points stayed closed (allowing the coil to charge) before they opened and the coil fired the plug(s).
Even with PCM-controlled ignition, the time for the coils to charge is referred to as "the dwell".
Increasing the PCM dwell parameter will ensure that D585 coils are fully charged.
However, the standard dwell will charge the D585 coils more than sufficiently to run the engine happily, and may even give them a slightly easier life.
If you do adjust the dwell then you can't revert back to the original coils, even for fault-finding, without risking burning the coils.
- New Duke (Wed Oct 17, 2018 12:11 am)
Re: New D585 coils
Re: New D585 coils
If they are genuine Lucas then they should be OK but you need to be buying from an appointed Lucas distributor not just from an eBay seller.
You really are safest buying from a trader on here and paying a bit more for the parts that bought cheap can easily cause your engine to fail.
Re: New D585 coils
I won't touch Lucas-branded coils, regardless of the source.
- 13Black (Tue Oct 23, 2018 9:53 am)
