How much would you advice per tank on a track day Dave ?warpc0il wrote:400ml per tank is already excessive, waaay more than I would use, even on track.
I use 100-125ml per tank for the road and twice that for the track.
I’ve been putting 200 ml per 20 litre jerry can , maybe time to half that then ...........warpc0il wrote:I use 100-125ml per tank for the road and twice that for the track.
I'm also running a sohn adapter, so nice clean 2T being injected and I have the OMP rate tweaked.
Some people run up to 300ml/tank for track time.
That could cause problems with cold starts, as the fuel just isn't volatile enough
Doubt it, ours used to fire first turn of the key even after been stood for months in the depth of winter - and that was with 30-50:1 premix.
strange you mention that. i find that 6+ month old fuel seems to create less engine knock than fresh fuel of the same grade!?warpc0il wrote: ↑Tue Sep 25, 2018 5:46 pmWhile we're on the subject, a bit more related history...
Back in the day I found a gallon can of premixed 2T fuel in the back of the garage, that was at least two years old.
Not wanting to cause any more problems with a temperamental bike, if the stuff had "gone stale", and being too mean to throw it away, I dumped it into the half-filled tank of Pauline's Mk1 Escort.
My justification was that the stuff would get so diluted and the Escort 1300 engine was sufficiently forgiving that it would be okay - hopefully it wouldn't smoke too much...
Next day I took the car out and there was no noticeable smoke but a faint smell of 2T - this being when the only "cats" were small furry creatures that demand feeding every time they return to the house.
While I wouldn't have been that surprised by a little hesitation, the car was actually running smoother and much more lively, like it had been out for a good motorway run (aka Italian decoke) rather than just pottering about in traffic.
By the time of the next refill everything was back to normal and so, a couple of tankfuls later, I tried adding some 2T (a couple of glugs) directly to the tank to see if I could replicate the effect, but this time it made no difference.
Around this time there'd been a rumour going around the paddock that storing fuel in one of the "new plastic" cans, rather than the old steel jerry cans, would somehow boost the power though a chemical/magic effect. Racers will believe anything if they think that it will give them an edge though, thinking back, it's just as likely that the rumour was started by someone who thought that the opposite was true and they were trying to get one over on everyone else.
Anyway, I half-believed that it could have been "the plastic can effect" especially as those early cans could either go very brittle or soften and sag if left full of fuel in the sun - either way there's was something chemical happening.
These days I'm more convinced that the 2T loaded fuel had acted as cleaner/lubricant and had just let the carburettor work better. The effect wasn't reproducible because the problem hadn't had sufficient time in between to be cured again.
Years later I was working with some ex-Royal Engineers on a temporary radio base and saw them add something to the petrol tank of the generator set. Seems that they'd been taught to put a cupful of diesel into every fill of petrol, to keep the generator reliable and responsive to changes in applied load.
