- Been thanked: 547 times
Re: Semmi/Professional Car Garage Equipment. Input/Advice/Recommendation.
leds are the way to go at the moment.
This is what I'm planning to use in my workshop
https://www.easy-lightbulbs.com/light-b ... bt6k50-dt/
- Goobie (Wed Feb 06, 2019 2:58 pm)
Use code EASY12 to get 12% off (over £150) but if you're ordering larger numbers then it's worth giving them a call, as they can often offer a much better deal.
I got 40% off an order worth just over £400.
Yeh, I had a poke at those in Homebase and wasn't impressed.
I suspect that some "home assembly is required" and they hadn't been put together very well, but even the components were cheap-n-nasty.
Sealey do three difference ranges of module workshop systems, not cheap but far better value for money
https://www.sealey.co.uk/category/56371 ... ge-systems
Can sometimes work out cheaper to buy through an outlet like Machine Mart
https://www.machinemart.co.uk/c/modular ... icelowhigh
- RX-8: Evolve
- Has thanked: 30 times
- Been thanked: 27 times
I've been eyeing these up. https://www.ebay.co.uk/itm/Seville-Ultr ... 2244805581
no idea on quality though..suspect budget end.
I'm getting some proper garage space soon, I'm gonna build the bench with a friend!
I've got the homebase one. It's very sturdy and strong. And almost no home assembly is required. It weighs a huge amount (needs four people to lift). I like it. I also have the unit without the top bit. Recommended.
- Goobie (Fri Mar 08, 2019 2:47 pm)
Yes, I have that one. It is heavy, but not 750kg! I could lift one end by myself (just!). So I'm guessing around 250 to 300kg total.
