R3 won’t start Sorted
- Has thanked: 93 times
- Been thanked: 165 times
The Mrs is up in Staffordshire after taking her dad to hospital.
She has gone to start the R3 to come back home and it wont start.
The starter sounds like it is spinning fast enough so not flat battery just wont fire.
Coils (C spec from MRP) magnecore leads and gen plugs all changed within last 6000 miles.
No prior starting issues at all.
I’m driving up there in morning to investigate.
Any ideas?
Cheers
Any ideas?
Cheers
Re: R3 won’t start
Just rang the Mrs and yes it is!
- Been thanked: 109 times
Re: R3 won’t start
Is it flashing?
Re: R3 won’t start
I'm assuming your good lady doesn't have the means to connect to OBD and get the code
Re: R3 won’t start
No CJ but I will have in the morning.
Cheers
- SeeJay (Fri Jul 13, 2018 9:13 pm)
Re: R3 won’t start
Sorry I can't be more helpful,Graham,but as an afterthought,did the car exhibit any unusual symptoms before it was shut down
Re: R3 won’t start
No, nothing at all was running sweat as usual.
Re: R3 won’t start
Looks like it's all on that fault code then,bud.. all praise our temperamental rotary's
Re: R3 won’t start
Oh well.
See what the morning brings.
Thanks for the help.
Re: R3 won’t start
Spinning over and not starting sounds like it's going to be something like P0335/6, related to Eccentric Shaft Position Circuit/Sensor.
Of course, without the code we'd just be shooting ducks in the dark.
- Been thanked: 332 times
Re: R3 won’t start
Or a lack of fuel perhaps?
can you hear the pump prime /run for a few seconds when you 1st key on
what happens if you do the 20 brake pedal stomp?
Re: R3 won’t start
R3s don't have an oil pressure gauge so ESS reset can't be confirmed by a sweep. I'm not 100% if the procedure is even the same.
- Has thanked: 694 times
Re: R3 won’t start
Does that work on the R3? I read on Facebook (unreliable, I know) that it was changed to another method for the S2.
Good thinking on the fuel pump tho.
EDIT: Super Nick beat me to it!
Re: R3 won’t start
Quick but doesn't mean anything I say is accurate
Re: R3 won’t start
You could well be right Pete.
I haven’t established the circumstances that occurred before she parked up yet. She may have moved the car from cold to get her dads car off his driveway.
Re: R3 won’t start
My r3 flooded like a month ago. But only cuz I parked it for half a year w/o touching it. Get some1 else do few jump starts with gas pedal down the bottom and try more with pedal slightly released. It should become a smoke machine after a few tries. Eventually it will start.
Re: R3 won’t start Sorted
It was flooded.
Connected my battery booster for good measure even though the battery was still cranking it over quickly and did the de flood procedure. 15 seconds with full throttle and then tried starting. Had to repeat 3 times but then it came alive with accompanying smoke cloud.
Let it warm through and took for a spin. Was happy to restart from hot and later from cold.
Performance seems as normal.
So not why it flooded. Chris had driven up to her dads a journey of about 60 miles and parked up. 10mins later she moved the R3 so she could get her dads car out.
The R3 then stayed parked up from Wednesday evening until it failed to start on Friday evening.
Never had any issues before and all seems well now.
The strange world of rotaries!
No codes by the way.
Thanks for all the help and advice, muchly appreciated
- Has thanked: 147 times
- Been thanked: 288 times
Why did you get an engine light If she was only flooded?
I didn’t Ian.
The engine light was on when trying to start but went out once started.
Oh sorry Graham, glad it's sorted bud
It was me, when I spoke to Chris and asked her if the EML light was on she said yes which I reported on here, but it was on as it had not started.
Just a bit worried in case it happens again as not sure why it did it
Re: R3 won’t start
Never a true word said in jest lolPeteH wrote:Flooded. There, I said it.
Spot on
