Bleeding Brake Problem
- Been thanked: 21 times
Re: Bleeding Brake Problem
I blocked both outlets from the master cylinder and the pedal went down about half way then stopped. I'm assuming the master cylinder is ok so the problem is definitely further down.
Hmm! My bet is an abs unit that is full of air. Dunno how you check or sort that though!
The Mazda mechanic said they're a nightmare if not impossible to bleed so not sure what to do.
- Has thanked: 71 times
- Been thanked: 90 times
To bleed an abs unit you need a dealers service tool as it will cycle the valves in a specific way.
There's a way to do it manually with some Bosch units by sending power down certain pins or by fooling the speed sensor of the wheels to cycle the abs but both are a bit of a bodge.
When I used Forscan a couple of years ago to properly code a new key (with just one original) the abs service bleed was a work in progress at the time, not sure what the status of it is now.
- Been thanked: 108 times
Have not changed on an 8 but done 2 1 series BMW abs units bosch 1s as the pressure sensor fails in them...swapped over units connected all pipes...then bleed every port on abs unit by cracking the joint whilst pedal pressure supplying fluid and then each caliper nipples..both cars bled up fine.
Mondeodog towcar.
Mondeodog towcar.
Ok i can give that a go.
What about blocking off the ends of the brake pipes at the caliper side? Saying that, there's still air in the system so that may not work...
Bleed down..so fill reservoir..open mc ports til fluid comes out..slight pedal pressure. Each in turn nip up. Then onto abs unit..again bleed slight pedal pressure open each port inturn til fluid comes out..check reservoir periodically. Never leave a port open.
Then onto calipers..rear longest pipe run first ascending to shortest 1. When ive probs in past with all nipple/ports tight ive done a pedal test periodically.
Prob gonna need some more fluid too.
Good luck.
Good luck.
Mondeodog towcar.
Mondeodog towcar.
Y'know what, i am thinking of giving up and just paying someone else to solve the problem. I've had enough of bleeding the brakes over and over. It's made all the more difficult because i'm ill and it takes a lot of effort just to get out there and do it. I might pop down to Mazda and see what they say. The problem is i'll have to pay to have the car lifted on a trailer there and back so it's gonna be a fair bit just to diagnose let alone repair and to be honest i don't think i trust a normal garage with this car.
So frustrated
So frustrated
- Been thanked: 35 times
If you have a local trusted garage then they can sort this for you. Specialist engine stuff should be left to Mazda or your nearest rotary expert, but brakes are brakes. There's no appreciable difference between the brake setup on an RX-8 and any other modern car that runs discs all round, so take it down to your local friendly garage and they'll see you right
- ChrisHolmes (Fri Jul 27, 2018 1:30 pm)
There's nothing specifically "Mazda" about the brakes and certainly nothing "rotary" that makes them any different to any other car with abs - which is pretty much everything these days.
Have a ring around and see who would be prepared to sort it, including collection on a low-loader/trailer.
Towing, even with an a-frame or dolly isn't an option, not only due to the lack of brakes but because the car must not be towed with the rear wheels on the ground.
Id look for a mobile mechanic mate, come to the house he will have all the tools in his van...prob get you todo to foot work or a have bleeder kit...
Tell him everything that has happened and see if 1 will come out...dont really need to go on a ramp...
Trailer gonna be 100plus..mobile mechanic 40plus so 2.5 labour probably 100.
Mondeodog towcar.
Mondeodog towcar.
Did some googling Milton Keynes Mobile mechanic got 5* google reveiws..could not find a labour rate..
call Stephen Ledster on 07814663519
Id tell him whats happened what you have done and see what he says.
Mondeodog towcar.
Mondeodog towcar.
He'll bleed the brakes for £45-60, i suppose if he can't bleed them then he'll at least tell me what the problem is.
That sounds very resonable to me...and prob half Mazdas hourly rate...its gonna take him an hour at least..what with taking wheels off.
Mondeodog towcar.
Mondeodog towcar.
- Been thanked: 453 times
Sounds a good way forward to me - a very reasonable charge to come out and do it too!
Well done Jon for finding that guy
Does he charge more if you want to watch and take pictures?
- 13Black (Fri Jul 27, 2018 6:50 pm)
Are you in the correct forum Dave?
I just thought I'd ask, for Nigel...
- nightfire10 (Sat Jul 28, 2018 7:13 am)
I was waiting for someone to respond to Dave's comment
- Been thanked: 7 times
You need compressed air for this, but its idiot proof, in the past I have never successfully bled a full system, but now my brakes fly through mot's...... https://www.ebay.co.uk/itm/VOCHE-CAR-VA ... SwvmRa2hjX
try reverse bleeding it. large syringe of fluid open bleed nipple and push fluid backwards.
Push the air back up to the master?
That never occurred to me, anyone done this before?
I used to use this method on bikes
- twin front brakes that have a t-splitter that traps air
- rear brakes where there's little height difference between the reservoir and the caliper.
In both cases it works better than other methods, as long as you have a large enough syringe, e.g.
https://www.ebay.co.uk/itm/Syringe-type ... xyzGlQ8olU
I cannot sleep until I hear that this is all sorted........
- 13Black (Sat Aug 11, 2018 6:44 pm)
Nope, it's still on stands. I've had someone try and bleed the brakes and it's no good. The guy reckons it's master cylinder, i did buy another but it was the wrong one so i returned it. It seems odd that i now have 2 dead master cylinders.
