Bleeding Brake Problem
Re: Bleeding Brake Problem
Don't fill the bloody Gunson thing with brake fluid then lol.
Either I'm doing something wrong or right but my Sealey unit has been doing a fine job since 2016 and the lack of dents in my front bumper will attest to that.
This what I bought
£20
£20
Exactly what I've got with a different logo.
Tried both tops using fluid in bottle and 20psi blew straight out from reservoir cap13Black wrote:Exactly what I've got with a different logo.
- Has thanked: 17 times
- Been thanked: 93 times
*cough*
- These users thanked the author Rotary Potato for the post (total 2):
- 13Black (Sat Jul 14, 2018 10:38 pm) • nightfire10 (Sat Jul 14, 2018 10:41 pm)
Huw
The caps provided are the wrong screw type, needs a modified OEM bayonet cap.
I think you'll find mister Spudato that the front bumper is fantastically untouched and my engine still in my engine bay
Hence me after a spare cap13Black wrote:The caps provided are the wrong screw type, needs a modified OEM bayonet cap.
The clue to the problem is "bayonet" , as such a fitting has to go in further to turn and then back off to lock.
In theory you could use a foam seal with sufficient depth to compress and still expand to fill the gap.
I tried with everything I had to hand and failed.
Either to much to allow the bayonet to lock and/or not enough to get anything close to an airtight seal.
Any gap and it's not just air pressure you're loosing, fluid sprays everywhere
What are people -not reading- about this.
I have been successfully using one for well over a year now. No fluid sprayed anywhere. No air in mine or customers brake or clutch lines.
Yes but you have the melons power beaming from your hands
Mazda installed a brilliant device to create fluid pressure without any cap sealing issue. It's called a brake pedal. People like Nick need to be able to bleed brakes single handed, so vacuum or pressure bleed systems are useful. But even my 16 year old can follow "down, up, down, up" instructions. It takes a few minutes. It's quicker than getting my Easibleed out of its box. I just don't get the problem.
- Been thanked: 21 times
I was actually showed a different way to what i would usually do. Pump the brakes then hold down and open and close the bleed screw quick, rinse and repeat a few times then onto the next wheel. The built up pressure spits out any air, nice 'n' quick! This is of course if you have someone to pump the pedal.
Anyone seen a donkey that lost a hind leg?
Replaced the master cylinder, bled the system again and nothing. The pedal still goes to the floor.
Any other ideas?
Any other ideas?
You've either got a massive leak or a massive air lock. A leak should be really easy to find. Any air lock should be easy enough to push through. I think you need another person to give a second opinion on this, because it's possible you are missing something obvious. (Not a criticism. We all do sometimes....).
Random unlikely possibilities are that one of your brake hoses has failed (and is balooning when you press the pedal). Or you have some strange failure of the ABS pump that is bleeding all your pressure (this would be very odd because they are "fail safe" devices).
I guess the pedal is actually pushing the master cylinder? You haven't broken the push rod in some odd way?
- Been thanked: 108 times
A little trick i learnt from my motorbike days when fitting braided hoses...after fitting and bleeding sometime never got a "nice lever" which on a bike with braided hoses is about 4mm play to very firm.
Trick passed onto me was cable tie the lever to the grip and leave over night...
So cars ive used broom / breaker bar to push pedal hard propped with seat and left overnight...and i dont know why this has always resulted in a lovelly firm pedal....
Note i do this without servo action car not running...worth a try...?
Mondeodog towcar.
Mondeodog towcar.
I've done similar using bricks. I always leave the resevoir cap off - while I can't recall, I assume I was told to do it that way.
I was told that constant application of pressure slowly pushes any air to the highest point in the system (the brake fluid resevoir). Whether that's twaddle or not, I couldn't say.
But it helped no end on an old Capri where I upgraded to vented front disks & braided lines. I couldn't get a good feel no matter how much I bled them. Then after 24 hours with the brakes on, a quick bleed at each nipple and they were great.
Huw
Not that i could see, it all went together ok. The pedal did firm up a little when i bled the master cylinder after fitting but it just went straight to the floor again after a couple pumps. I also had a good look round for any leaks and i couldn't see anything. It will be something silly and i'll feel like a twit afterwards
The fact that it's firming up at all and no leaks present would mean that the new brake lines are fitted ok right?
No leaks at the calipers, lines or anywhere underneath that i could see. Also followed the lines in the engine bay and everything looks dry. So now i'm thinking it's either one hell of an airlock or something else is kaput.
I'll give the overnight idea a go, it's gotta be worth a try. It requires little effort after all and i'm all for that
Yep try it, note brake fluid level in reservoir too...if it drops then you know air was in system...cap on off upto you caps have a bleed on them.
Mondeodog towcar.
Mondeodog towcar.
You may hate me for this but you are doing the following the process that Seriousam posted of;
Starting at the further most point in the system
You say.......Down
Assistant.....Confirms Down
You............Open nipple and close again
You say........Up
Assistant......Confirms Up
You say........Down
And repeat
No pumping or releasing of the pedal at all unless the nipple is tightened.
You say.......Down
You say........Up
You say........Down
And repeat
Ashman, are you around tomorrow afternoon? I could come and mutter confused noises at your brakes if you like?
- These users thanked the author Ainmhidh for the post (total 2):
- 13Black (Thu Jul 19, 2018 6:14 pm) • ChrisHolmes (Thu Jul 19, 2018 10:16 pm)
Huw and Boosted. The reservoir is isolated from the hydraulic lines when the pedal is pressed, so I'm not sure that anything can get back to the reservoir when the pedal is pressed. But..... I wonder if that method helps in the short term because it forces the air to go into suspension in the brake fluid (essentially, doing a "soda stream" on it). Perhaps, when the pedal pressure is released, the air then gets released from suspension as bubbles (like taking the "cap off the bottle") and those bubbles can rise to the highest point, which could be the reservoir.
I was sceptical when I read your posts but, on thinking about it, there could be some science in there.
- ChrisHolmes (Thu Jul 19, 2018 10:16 pm)
I haven't actually tried it yet, had some more pressing concerns with one of my cats
I'll be available all weekend mate, well pretty much anytime really. I do need to get the cat down the vets once she comes in though so i may zip out at a moments notice. If i'm not home then i'll not be far. Ideally i need to get it back up on stands so i can get on with it. You still have my address?
