Coolant leak
- RX-8: 13B 6-port
- Has thanked: 20 times
Coolant leak
Just now I though I was sorting a coolant leak by tightening up the radiator drain screw but when doing so the head of the screw came off. I'm looking for the next step suggestions please. little worried on how to get the remainder of the screw out Still not sure where the leak is coming from and pics are the wrong way round
Hayward stage 2 Port,Full RB Exhaust, RB L-Flywheel,Michelin Pilot Super Sport,Bola B1, Aero Kit,Light weight Pulleys,More To Come
- Been thanked: 18 times
Re: Coolant leak
Heat up the end of your screwdriver and push it into the remaining broken off bit. Let the plastic cool and then undo it to get it out. A new plug will be required.
Leak could be from almost anywhere, but I would check the hoses onto the rad first. Check for damage and also check the clips are doing their job.
Could just be the rad itself leaking if it's not the hose connections
- These users thanked the author dac69er for the post:
- Aido 8 (Tue Jul 03, 2018 10:47 pm)
- RX-8: 13B 6-port
Re: Coolant leak
Awesome thanks and yah I have a screw from a donor car
Re: Coolant leak
or an easy-out, but both those options would generally cost money if you dont already have them!
Re: Coolant leak
Just had a coolant leak myself that I couldn’t find. It turned out the expansion tank had become brittle allowing the cap to move under pressure spewing coolant all over the engine bay.
Re: Coolant leak
Did you manage to sort a drain plug - if so where and how much?Aido 8 wrote: ↑Tue Jul 03, 2018 10:06 pmJust now I though I was sorting a coolant leak by tightening up the radiator drain screw but when doing so the head of the screw came off. I'm looking for the next step suggestions please. little worried on how to get the remainder of the screw out Still not sure where the leak is coming from and pics are the wrong way round
Haven't broken mine - YET!
Just wondering whether to buy one in advance....
Re: Coolant leak
Yeah, drain plug is PLASTIC with a very good rubber washer so don't go mad. Even a screwdriver will overdo it.
Not sure what the thread is, but probably drill a small hole and attack it with a screw removal tool or left hand tap.
- Has thanked: 38 times
- Been thanked: 116 times
Re: Coolant leak
If you still need plug I have spare one from my oem rad if you give me all details I can post today as I’m going to the post office to ship ally rad today for a guy who bought from me
LEXUS LS430 4.3 v8 family car
Done exhaust and work wheels
