Changing your Gearbox oil.
Re: Changing your Gearbox oil.
Can i use the same oil for gearbox and diff?
Thinking about getting 4L Mobilube 1 SHC 75W-90 fully synthetic for gearbox and diff
Life starts @ 6500 rpm
231 Titanium Grey | Greddy SP2++ | Agency Power Pulley | Uprated Coils & Magnecor | AEM CAI (future) | Ings+1 | Tein S Tech | Super White interior and puddle LED light | Axxess Ipod | more bits to come
Wow, that was a quick reply.
Thanks mate
Thanks mate
No probs, being one of the post whores it is my duty
Also, I noticed you havent put your location or RX8 details in your profile, might be worth doing, so questions can be answered quicker.
Mike
03 BMW 320Ci Coupe, 52,020
ex 04 Velocity Red 192, 30,230
Yeah, will do that mate even tho only 3 RX8 arpund where i live
A suggestion (which I did when changing the cat, and will employ when I do the oil on mine). If you have some ramps, you can jack the front of the car up so you can get the ramps under the front wheels. Then lower the car onto the ramps.
Then jack up the rear of the car (also with appropriately positioned axle stands) so the car is level.
This will give you a bit more room to get under the car.
Make it idiot proof, and someone will build a better idiot
I reversed on to the ramps then jacked-up the front and supported with axle stands.
Was thinking of doing it the other way around but;
- my ramps are quite steep and the front bodywork would touch before the wheels.
- with a RWD car it's better to reverse on the ramps as the driven wheels pull themselves up and don't try and push the ramps away as you ascend.
I used a long spirit level on the lower door shuts to confirm it was level.
i have my 6th service coming up. having spoken to the tdealer he mentioned 85/90 for the diff oil?
anyhow, having a look on Opie's site, using the "recommend a product for my car" feature, i am given two choices.
Silkolene BOA 90 LS High Performance Gear And Limited Slip Differential Oil
OR
Motul 90 PA Lubricant limited slip differential (LSD) Extreme pressure
anyone tried any of these. any recommendations. i dont think it makes any difference but it's a 192 version i have (yes, the torqueier one).
should i just be looking for standard, i.e. GL4, or GL5 instead of 75/90 or 85/90 a bit like brake fluids where you just go for DOT ratings?
OR
- Been thanked: 17 times
It should be GL5 and SAE90 according to mazda specs. I was looking at this last night, funnily enough...
I'll be getting the silkolene silktran 75/90 from opie
Ian.
Ian.
And still three gears left...
- Founder Member
- Has thanked: 12 times
^^^^^ What Ian said and just had both diff and gear oil changed today at Romford Mazda using Opie's Silktran 5 Race 75w-90. The new owners seem to have upped their act since last I visited (under the previous ownership)
thanks for confirming Ian.
@ Harrizone - didn't know they were under new ownership. However, Chris mentioned you were in today
- Founder Member
^^^^^^^^^ Probably not since you started visiting Naz, but I bought the car from there 7 years ago.
Let's hope RM remember that the 192 has two drain plugs for the gearbox...
why doesn't opie show this as recommended for the diff when you search for products for your car? is it because it is fully synthetic and mazda recommend mineral?HypoThermia wrote:I'll be getting the silkolene silktran 75/90 from opie
plus the syntran is showing as a gear oil, which i agree can be used in a diff also. however, the Motul 90 is actually showing as a "lubricant limited slip diff extreme pressure", so this should be better as it's specific to diff's no?
There's no mineral vs synthetic issue for the gearbox, only the engine as it burns it's oil.
Also a question for Opie - they are probably using a commercially available car to product mapping database. BTW there now seems to be a product name change - its now Fuchs Titan Race SYN 5 as well.
So long as the oil meets the spec then it should be OK for gearboxes. If the Motul doesn't meet GL4 then it isn't suitable for gearboxes. Any other choice is based on experience or personal preference/colour of the box/how pretty the girl is selling it to you...
Ian.
Ian.
@ Hypo - spoken with opie and they do in fact use a standard lookup chart. the Syn 5 is the better product which they used in their own RX8.
ordering some now.
ordering some now.
Does anyone know the size of washers required for replacing those on the diff? Also the gearbox, since I'm here
Cheers,
Ian.
Cheers,
Ian.
- Founder Member
Yes they are the size Mazda supply.
'Not much help am I dad.'
Er... thanks
When I did the first oil check on mine years ago I searched and a quote from OZ was that there wasn't an equivalent from any of the standard suppliers.
As it's designed to give then I don't take the risk and just get the dealer to order half a dozen Y601-17-361
Excellent reference pics at http://www.5cats.org/rx8/trans_diff_refill/
RX-8 PZ. Grey, EBC discs/yellow pads all round, Kumho V70A race rubber for serious playtimes .... Alpine A610, Blue .... Matra Bagheera 'S', Black .... 'X', Orange .... Bandit motorbike, Black ..... share in OMS Z1100 Hillclimb
"To prepare for a race there is nothing better than a good pheasant, some champagne and a woman" - Jacques Anquetil, 5 times winner Tour De France cycle race
Yeah... I found that page while searching as well. I haven't needed the gearbox crush washers, but suspect I will sooner or later. They don't go back on the car very well once they've been "crushed". You can get the 9956-41-800 washer through the mx5 parts store at about 33p each. I've also got the 23mm/24mm sockets on order so I can take everything apart and then put it back together.
Starting with the fill plug...
Ian.
Ian.
If you're coming up to the Grange for the Essex meet, I'll bring my gearbox/diff re-filler kit which makes it easy to get the oil in cleanly with just a cordless drill.
Thanks for the kind offer Dave, however I've already sourced the parts that I need for the work and I'm just waiting for postie to turn up with the last few bits
Cheers,
Ian.
Cheers,
Ian.
changed gearbox oil today, theres more room to invert the oil pack than when doing the diff, but its still quite tight. and had to jack the car up three times. to drain, fill, drain, tighten
oh well thats that for a few 10s of thousands of miles anyway
