Forge Action Day 2019
Saturday 7th September | Castle Combe
Club stand display | Exclusive Club track session | The ever popular drift team displays | Show and Shine competitions & more
£15 per car (Admits the driver and up to 3 Passengers) | Under 17's go FREE! And do not need a ticket.
direnza spacers...
goodeggbob
RX-8: Kuro
Colour: Kuro Black
Has thanked: 219 times
Been thanked: 246 times
Re: direnza spacers...
Post by goodeggbob » Thu May 17, 2018 6:07 pm
hi there ,i fitted 20mm eibachs to my kuro.the standard studs stood out 27mm.with no pockets in wheels i took off 7mm.i found the easiest way was to screw on the supplied nuts first then bring them out to the thickness of the spacer -1mm.use the front face of nut as a guide for a 1mm cutter disc in a sensible 4 inch grinder.that way taking the nut off cleans all the burrs making assembly much easier .with all mating surfaces cleaned including wheel,bolt on the spacer firmly and check across faces of spacers for protruding studswith a ruler ,any little tweeks can be done here while leaving the max length on stud should you change your mind in the future.regards all rob.
huw
Post by huw » Thu May 17, 2018 8:21 pm
feedthegoatxi wrote:
Dazza44 wrote:
Sun Mar 04, 2018 6:14 pm
Better pics
cheers, look great and love the colour of them too...gotta get myself an alloy fuel filler cap as well :thumleft:
I have an unused alloy filler cap if you are interested.
nightfire10
Has thanked: 555 times
Been thanked: 222 times
Post by nightfire10 » Thu May 17, 2018 8:47 pm
Better pics
Hi Huw how much are you after for the fuel cap ?
cheers steve
Hayward's Street/bridgeported rebuild,595's,Tein coilovers with edfc,Racingbeat rear anti roll bar,oil pressure and oil temp gauge pod's,lockwood front and rear grills,Tinted windows,folding tow hook's,595s,connect2
SeeJay
Has thanked: 176 times
Been thanked: 340 times
Post by SeeJay » Fri May 18, 2018 4:13 am
Never mind alloy fuel flaps,how about an alloy fuelcap ImageImage
Sent from my SM-G950F using Tapatalk
These users thanked the author SeeJay for the post:
geofftl1000r (Fri May 18, 2018 9:31 am)
huw
Post by huw » Fri May 18, 2018 7:30 am
nightfire10 wrote:
feedthegoatxi wrote: cheers, look great and love the colour of them too...gotta get myself an alloy fuel filler cap as well :thumleft:
cheers steve
Make me an offer!
Huw
Return to “RX-8 Discussion”
