Cold Start Issues
Re: Cold Start Issues
PCM reset will be fine. You'd be hard pressed to accidentally change the map
I don't know if they change anything to do with the starting parameters with a FBP map, don't see why they would but could always fire RR an email?
- Been thanked: 328 times
Maybe silly question but if you have a scan tool does it say what temp the coolant sensor is showing?
as its this that has a very strong effect on fuel mixture
if yours is faulty then it can skew the fuelling
- Has thanked: 17 times
- Been thanked: 93 times
Thanks.
Will prob fire Ben an e-mail - better to be safe than sorry.
Huw
Thanks Matt - I'll check in the morning.
The coolent temp needle (yeah, I know ... hardly last word in accuracy) seems to react as I'd expect. No idea if there's 1 sensor for the gauge and another for the ECU, but I'll see what it throws up in the morning.
Huw
there's only the 1 sensor but as you say that gauge is heavily damped and its difficult to say what its reading with it all cold as I suspect if it was -50 the gauge would be on its end stop as it would if it was 10 degrees
Ambient = 8 degrees
Coolent = 8 degrees
IAT = 11 degrees
I'll send Ben an e-mail today and go from there.
Coolent = 8 degrees
IAT = 11 degrees
Huw
the other thing that can have a strong effect is to check for exhaust leaks before the O2 sensor as if this has been experiencing an exhaust leak then it will have been running very rich as the sensor will see the extra air pulled in as fresh / lean fuelling and be adding fuel to compensate.
this can lead to catalyst failure as the extra fuel can re-light inside and melt the catalyst
The best way to find an exhaust leak is to run the engine from cold and feel around the exhaust joints with your bare hands - you'll have about 30 seconds before it all gets too hot and you should feel any escaping gas blowing over your fingers
- Been thanked: 108 times
When it does start cold what's she idling at very start...all mine were about 2k if my memory ok and quickly drop to 1500rpm then slowly settle when warm 850..
Could be map.
Could be map.
Mondeodog towcar.
Mondeodog towcar.
My method for finding exhaust leaks...
Spray WD40 into the inlet manifold, via a vacuum connection, downstream of the MAF, with the engine running.
WD40 produces a dense white smoke that's easy to see, without doing any damage.
- Azimuth (Thu Mar 29, 2018 6:13 pm)
Thanks Matt.350matt wrote: ↑Sun Feb 18, 2018 4:53 pmthe other thing that can have a strong effect is to check for exhaust leaks before the O2 sensor as if this has been experiencing an exhaust leak then it will have been running very rich as the sensor will see the extra air pulled in as fresh / lean fuelling and be adding fuel to compensate.
Surely an exhaust leak would also impact hot starts & running?
I'm fairly sure it's all good, but will double check at the next cold start.
Huw
Idles at 1600-1800, dropping fairly quickly to 1200 or so and down to about 1000 when warm.
Huw
Thanks Dave, will give that a try.
My gut is still on something mapping/fuelling ... but makes sense to eliminate the easy to check along the way.
Huw
That's fine then....no one's messed with it since rebuild...coil leads in particular...leading at bottom trailing on top. Just ideas...Rotary Potato wrote:Idles at 1600-1800, dropping fairly quickly to 1200 or so and down to about 1000 when warm.
Mondeodog towcar.
Mondeodog towcar.
Only time it's been touched since rebuild is by RR themselves for the mapping.
Not to say a lead couldn't have worked itself loose, but on a quick check all looked ok.
Huw
Well I'd just get it to Ben he will sort you out.
Mondeodog towcar.
Mondeodog towcar.
Ideally I'd like to solve this without a 2 1/2 hour trip each way to Leeds ... but yes, it is a nice last resort to have.
Huw
Consulting Ben should be your first resort not your last one!Rotary Potato wrote: ↑Sun Feb 18, 2018 5:34 pmIdeally I'd like to solve this without a 2 1/2 hour trip each way to Leeds ... but yes, it is a nice last resort to have.
Morning Chris.
Consulting Ben is definitely not a last resort. However the 5 hour round trip to Leeds definitely would be!
Huw
Ben has bet me a pint it's battery related and it'll fire straight up with a jump.
He thinks the strain of spinning the engine is meaning the coils don't have enough power to ignite the mixture, partially flooding the engine, hence why it then starts with fuel cut activated.
To avoid "doing a FrankenRex" I'll wait until the weekend when I'll have both daylight and time to help me steer clear of any sparky misadventures.
- These users thanked the author Rotary Potato for the post:
- 13Black (Mon Feb 19, 2018 6:55 pm)
Huw
Is this going to become part of the RX-8 Lexicon?
Along with spring compressor whoopies being called 'Doing a Huw'.
- nightfire10 (Mon Feb 19, 2018 7:30 pm) • Rotary Potato (Mon Feb 19, 2018 7:33 pm)
- Been thanked: 546 times
Had had a spring compressor slip off a spring about 18 months ago. Fortunately when it started to go I started unwinding the compressors. I'd got most of the tension off before it finally let go.
It smacked me in the face and put me on my arse. Apart from some smashed glasses and bit of a black eye I got away with a very close shave.
Huw
To share the stupids ...
Huw
good job you were wearing glasses to be honest
most vision glass is toughened these days so its takes quite a whack to break it
