Which disc brakes have you fitted?
- Has thanked: 24 times
- Been thanked: 18 times
Hi,
As my caliper decided to stick and warp my offside front disc I'll need to replace the front discs shortly. There appear to be lots to choose from from the likes of mtec, mintec, ebc, diamond black etc etc. I'll probably go for slotted discs as I've used those to good effect before, and going to avoid drilled as I have had fractures in ones . So the only question is which manufacture/type?
So I thought it would be interesting to see what discs people have fitted, and maybe why.
Cheers,
Jon
Cheers,
Jon
- Been thanked: 109 times
Re: Which disc brakes have you fitted?
Black Diamond,no question..been on the fronts for over four years - car only does <2000 miles a year - and can't fault them
- Has thanked: 147 times
- Been thanked: 287 times
Yup BD here too, bought them from MRP over two years ago and they are still doing what they should. Mines my daily so they have done circa 20K. Btw mine are drilled and grooved and I've had zero issues
I use MTEC black painted grooved and drilled discs. They look identical to the Black Diamond black painted ones, but are less than half the price. Bought for £200 from the MTEC eBay shop (not their website) for a set of 4 including 4 Brembo pads. Silly money.
I was hesitant, not having used MTEC before, but my neighbour who's a suspension specialist swears by them and I'm very glad I trusted his experience.
MTEC offer a variety of styles/groove depending on preference.
- leeroy69 (Sun Jan 21, 2018 7:40 am)
Evora grooved from Brake Depot. They have been perfect for two years of racing. On a road car you'd want to get some corrosion protection on them. The most impressive thing is that they have almost zero wear, even after going through about six sets of pads.
- Freeman38 (Mon Jan 22, 2018 5:20 pm)
- Been thanked: 12 times
It's always going to be a personal opinion however there's plenty of input so far and it's also nice when people have actually used what they're recommending. (this is why I only suggest or not suggest what I have used) I've had the Brake Depot as mentioned above I got the 40 grove and tbh they where very good especially for the money, I used them with ebc red stuff pads on the road they where noticeably better then what came on the car and worked very well, however while on track I found they over heated pretty quickly. I think my driving style and the fact that red stuff aren't actually for track was the main problem. If I didn't go on track then I would use them again as the dust off them is very low. I now run a BBK (k-sport 8 pots) now with yellow stuff pads it's excellent now and overheating is never an issue now. On my lady's 8 I fitted the ebc grooved (black) disks and yellow stuff pads they're very good on road and track and are an excellent option on a reasonable budget and what I would probably suggest for most.
Brilliant black 192.
Carbon fibre vented bonnet, carbon fibre boot, carbon fibre Mazdaspeed spoiler, carbon fibre eyebrows, carbon fibre strakes, carbon fibre b-pillers, carbon fibre mirrors, K-Sport 8 pots, Japan Racing Wheels, Meister R CRD+, 10w50 fully synthetic, Castrol 2t racing pre mix and sohn Fed. red lined like she should be.
- Has thanked: 84 times
- Been thanked: 20 times
I use the same and I'm very pleased with them. When you say "corrosion protection" are you referring to a product type or just some paint?
Mine rust up while I'm in the car wash, it's insane how fast they go brown.
The swept area will always rust (discolour) very quickly.
It's the area inside and outside that can benefit from rust protective paint - though it has to be VHT - very high temperature.
Some brands come already coated with a corrosion resistive layer that is worn off the swept area during the breaking-in period but remains on the unswept areas.
Stainless Steel can be used for brake discs but it's much more expensive, doesn't wear as well or give the consistent braking performance of (what is basically) cast iron.
I don't care about the wearing surfaces, but on these discs none of the disc is protected at all. It would be better to get some UHT milk paint onto them. I don't care on my track car, but I would on a road car.
Ps. In the 70s and 80s stainless discs were quite common on motorbikes. Unfortunately in the wet they had almost zero friction. Proper brakes use rust-prone iron.
Er, if I just waited for Dave I could save myself some typing!
- Been thanked: 547 times
stainless brake disks are still very common on bikes. this is a (BENT) set off of a 2005 Yamaha R6
(and yes i do still have them kicking about in my office, even though i took them off the bike 10 years ago... and sold said bike 5 years ago..)
Slotted and dimpled, Unknown make, with Mintex 1144 pads. Never had fade on track, smooth progressive feel.
- Been thanked: 35 times
OEM-spec discs from MRP have been doing the job for me over the last 2 years and 10k miles. Absolutely no concerns with fast road or track usage, and performance has been excellent. Better to ensure the calipers are working at their best before fitting whatever discs you choose to buy though
- Been thanked: 4 times
Evora grooved and dimpled with Yellow EBC pads.
No issues in 3 years.
●2004 Custom Blue ● Full Body kit and Carbon Fibre Mazdaspeed style Spoiler
● Polybush Full Kit● XYZ Coilovers● Hotchkis Front ARB's
● Pettit ANP Remap and EFIDUDE Logger●D514A Coil Packs Setup
● K&N Panel Filter● Racing Beat CAT Back Exhaust● ToyoSport HiFlo CAT
●Dimpled and Grooved Discs●EBC Yellowstuff pads●HEL Brake/Clutch Lines
●XXR 550 Wheels 8.75J ET36●Nankang NS2-R●R3 Differential
- Been thanked: 3 times
EBC USR grooved with Mintex 1144. Stops quick enough for me.
Brilliant Black PZ, Strakes, red calipers with logo.
- Been thanked: 47 times
As long as you avoid cheap discs then your choice is much less of an influence as the choice of pads.
Grooved discs are better than plain discs as they clean up pads and dispel gasses and water better. The gas issue is much less of an issue than it used to be though due to the make-up of more modern pads.
Avoid drilled discs except from quality manufacturers. The holes really need to be shaped and the gain for normal users is offset by the risk of cracking.
Grooves and holes do wear pads quicker though.
Ian
I had Evora swirl discs on mine and they were perfect as PeteH said - although mine didn't take anywhere near as much punishment as his!
I'm now running Maserati discs, which I have to say don't seem to last as long!
- Been thanked: 7 times
So i couldn't easily get DBA for the RX8. So I fitted mintex discs which look like OEM, no grooves, no holes, fairly cheap but from a known brand. I then found mintex m1155 pads because the ferodo ds2500 or ds3000's are not available.
So far after 9 months and 4 track days, they have been good. No fade on track and work well no matter the UK weather. Wear on the pads is high, they are about 40% used. Discs will likely last 3 sets of pads.
Eicher Premium / Mintex pads - Only been on a few weeks but found them to be great on the road.
(Discs were about 60 quid for front)
- Been thanked: 59 times
Mtec grooved and dimpled with m1144 pads currently.
Thanks, Stu
Mad as anything
Mad as anything
- Colour: Diamond Grey
- Has thanked: 52 times
- Been thanked: 31 times
MAZDA RX8 EBC Ultimax With M1144
EBC Slotted are very good with the Yellow Stuff pads that’s what I have but the Black Diamond are also meant to be good
2009 Sparkling black R3
- Japspeed sport cat
- Petit Racing exhaust
- Mapped
- EBC discs and pads all round
- K&N filters
- Michelin pilotsport 4s tyres
- Mapped
- K&N filters
I'm on MTEC grooved discs with oem brembo pads, the pairing stood up to track use so can't fault it!
Andrew.
09' R3, Sparkling Black ~ RRP Stainless 3" cat + catback ~ RRP Lightweight Pulleys ~ RRP MKII ignition coils & MSD 8.5mm leads
Instagramelonalam: @autogibbon
- Forum Administrator
- Has thanked: 47 times
- Been thanked: 155 times
I have some standard Mintex discs and M1144s to fit this weekend.
- These users thanked the author brix79 for the post:
- 13Black (Fri Oct 19, 2018 12:30 am)
Forum Admin Team
Forum Admin Team
