oil light after track day
One the last two track sessions that I've done when I get the car back to the pits / paddock area the oil light has come on once the car is stationary. No problems when on track or cooling down lap only when the car is stationary and I'm letting it cool a bit.
When I check the oil it is full and no problems when I restart once cooled down.
Any suggestions to the cause or how to prevent it in the future?
Fairly new to ownership (and track days) so any advice appreciated.
Re: oil light after track day
Happens sometimes. Try cleaning the oil level sensor plug and go from there.
- Mhd (Sun Sep 17, 2017 9:21 pm)
............or would it be because there isn't enough Oil in the car when going out on Track
Take the love hearts out of your eyes Nigel
- GreySilver Beast (Tue Sep 12, 2017 9:21 pm)
Some time since my original post as haven't done any track days until today at JDM, but cleaning the oil sensor seems to have done the job.
Many thanks Nick
Many thanks Nick
- These users thanked the author Mhd for the post:
- 13Black (Sat Jun 02, 2018 9:27 pm)
- Been thanked: 93 times
Same thing happened to me twice today at Combe, checked oil level and 3/4 full. Looks like I’ll be crawling under the car again tomorrow
Kamikaze
Too many to list.
Too many to list.
Me too so I ignored it as I can see pressure on the gauge and it went out by itself.
- Founder Member
- Has thanked: 12 times
Not an altogether strange occurence at track days, the oil light does ocassionally come on but provided pressure is OK I have found you can ignore it as just a mechanical blip. Well leastways that is my experience over eleven years of tracking the car.
- Been thanked: 328 times
Warpcoil pointed out that the oil level sensors as they age can give a false reading of low level if they get hot and you then stop and restart
happens to me now fairly regularly if I stop for fuel the low light is on for a bit afterwards and I know the level is fine
however to replace the sensor its a sump off job
Better to be over active than under active
Mine used to do it when I trundled around the pits after a session.
Not quite after track day....
But this morning after a couple of beeps on the motorway came down the slip road and had to brake heavy to a standstill as car in front decided to swap lanes (nothing scary /twitchy just heavy breaking). Oil waning light pops on as I am waiting at idle and stays on, was due for fuel so detours to garage forecourt. Stops engine (light still on at this point) and restarts light goes out. Anyway filled her up and checks oil – still on ¾ mark.
So is this likely to be the same scenario as above and probably nothing to worry about just keep an eye on it?
- Been thanked: 35 times
Probably. Pretty much every time I did Brands Hatch (before I had my bigger sump installed) I used to go out, do 3 laps, then at the start of the 4th lap I'd brake hard on the approach to Paddock Hill and the oil light would come on. Regular as clockwork. I check the oil between sessions so I knew it was OK, I just put it down as a quirk of the car. The only time mine has ever come on during road driving was when I was actually low on oil, which is encouraging.
Once it comes on does it stay on until engine is switched off?
Yep. It's meant to encourage you to stop the car and check the oil level at the earliest opportunity, so it won't go out until then
- bigpete8 (Wed Jul 18, 2018 12:52 pm)
I guess its possible the oil pickup was momentarily starved of oil due to the braking (was also going downhill)
The oil level light isn't connected directly to the sensor.
The sensor is connected to the PCM which makes a judgement, based on a programmed algorithm, to determine if the actual level is low, given the pattern of outputs from the sensor.
The algorithm "assumes" that normal road driving dynamics would apply, so anything way outside those is likely to make it trigger a bit earlier.
Thankfully, they didn't choose to make the "low level warning" trigger limp mode
FYI the two fuel tank level sensors are also connected in a similar way, so the PCM can (try and) figure out how much fuel is actually in the tank.
OTOH the coolant level warning light is driven directly from the sensor, with no connection to the PCM.
- bigpete8 (Thu Jul 19, 2018 10:20 am) • ChrisHolmes (Thu Jul 19, 2018 10:22 pm)
That clarifies things slightly if it is an oil level light rather than an oil pressure light.
As oil level was fine I am even less worried..
- Been thanked: 22 times
Very interesting, thanks. I find that my oil light will come on after a bit of hard drivin' and the oil level is between the first and second blobs. I usually avoid this by checking and filling frequently enough!warpc0il wrote: ↑Thu Jul 19, 2018 10:11 amThe oil level light isn't connected directly to the sensor.
