MOT and 2T Premix
Stevie_P
MOT and 2T Premix
Post by Stevie_P » Tue Jan 03, 2017 3:14 pm
Hi
Tried a quick search but couldn't find the answer to this one.
Can I assume people don't continue to run premix for their MOT?
I would assume this would lead to an emissions fail?
So is the best advice to:
1. Run some cataclean through prior to the MOT
2. Give the car a good run and get everything up to temperature
3. Run no premix for the MOT
4. Keep your fingers crossed...
Any advice would be gratefully received.
Steve
Phil Bate
Has thanked: 35 times
Been thanked: 165 times
Re: MOT and 2T Premix
Post by Phil Bate » Tue Jan 03, 2017 3:27 pm
Premix at the levels we use makes effectively no difference to the emissions - there is no need to skip it for an MOT :thumleft:
Stevie_P
Post by Stevie_P » Tue Jan 03, 2017 4:24 pm
That's the answer I like to hear.
Steve
Has thanked: 399 times
Been thanked: 1558 times
Post by warpc0il » Tue Jan 03, 2017 5:39 pm
:whathesaid: regarding premix
Also make sure climate control, heated seats and heated rear window are all off during emissions test.
Bex (Mon Feb 25, 2019 11:25 am)
Stevie_P
Post by Stevie_P » Mon Mar 06, 2017 4:49 pm
Phil Bate wrote:Premix at the levels we use makes effectively no difference to the emissions - there is no need to skip it for an MOT :thumleft:
Just to finish this thread. Car passed it's MOT on Friday with premix present and correct.
Really pleased. Advisory on the rear drop links but we all know they're made of chocolate correct? :D
Has thanked: 262 times
Been thanked: 565 times
Post by Dr. FrankenRex » Mon Mar 06, 2017 4:55 pm
warpc0il wrote:Also make sure climate control, heated seats and heated rear window are all off during emissions test.
Will that actually make that much of a difference?
Genuine question as I'd never really thought about it
Post by warpc0il » Mon Mar 06, 2017 5:21 pm
Yes, especially at idle these more than double the load on the engine and therefore significantly increase the emissions.
TenToSeven
RX-8: Import
Colour: Nordic Green
Has thanked: 6 times
Been thanked: 5 times
Post by TenToSeven » Mon Mar 06, 2017 5:31 pm
Or buy an import, de-cat it and take advantage of the rules to fly through the emissions regardless ;)
JDM NORDIC GREEN
Running on Nitro+ with Motul 710
Seibon TS bonnet
, rear tints, wind deflectors
Mazdaspeed bumper and skirts
Dimpled & grooved with EBC Redstuff
TEIN S-Tech, 20mm spacers on black stock rims
Toyosports decat & cat-back
Alloy catch tank
Sohn adaptor (in my cupboard)
Glen Mc
Post by Glen Mc » Mon Mar 06, 2017 8:15 pm
Yep mine had a dose of pre mix Saturday and passed the MOT :D
40th White anniversary. Mazda speed replica bodykit/red calipers/strakes/BHR coils/NGk iridium spark plugs/double din install/Essex rotary stage 1 ECU Reflash
Transmission - Red line MT-90
Differential - Red line 75-w90 GL5
Brakes - castrol react performance Dot 4
Engine oil - Shell helix HX5 15w40 mineral
Castrol power 1+ shell v power
245/40/18 michelin pilot sport
dac69er
Post by dac69er » Tue Mar 07, 2017 8:24 am
TenToSeven wrote:Or buy an import, de-cat it and take advantage of the rules to fly through the emissions regardless ;)
i thought if you had an import and there was a uk equivalent, they can just do the same test as they would normally? even if there isnt an equivalent, they do the test based on the age of the vehicle and do a basic cat test. i cant see a decatted RX8 passing that!?
i have 3 other import cars, 2 are from 1990 and 1991 so just need a basic uncatted idle test (which they obviously pass) the other is an engine swapped car from 94 and he always moans at me that it needs a cat. am i missing something?
tekkendp
Forum Guest
Forum Guest
Colour: Stormy Blue
Post by tekkendp » Tue Mar 07, 2017 8:26 am
Just a quick question, Cataclean and pre-mixing - is this a bad thing?
I used Cataclean - and I think it's good. Plan on doing this as a fairly regular thing, as I do a lot of town driving.
A redline a day keeps the rebuild away :race:
Live long and redline 8)
acegeezer
Been thanked: 131 times
Post by acegeezer » Tue Mar 07, 2017 9:10 am
I don't premix on the R3 :)
tekkendp
Forum Guest
Forum Guest
Colour: Stormy Blue
Post by tekkendp » Fri Mar 10, 2017 12:45 pm
acegeezer wrote:I don't premix on the R3 :)
Show off!!! ;)
RenesisRaceBuggy
Has thanked: 20 times
Been thanked: 34 times
Post by RenesisRaceBuggy » Fri Mar 10, 2017 1:09 pm
tekkendp wrote:Just a quick question, Cataclean and pre-mixing - is this a bad thing?
I certainly wouldn't want to be using it regularly, the cleaners in it pull the oil off the chamber walls...it's basically shedloads of solvent + paint thinners diluted in petrol. It's not great for the fuel lines, etc, either.
Last edited by RenesisRaceBuggy on Fri Mar 10, 2017 1:11 pm, edited 2 times in total.
acegeezer
Post by acegeezer » Fri Mar 10, 2017 1:11 pm
Ha ha.. I was told by one of our specialists premixing was optional, as the R3 has an additional injector .. and 3 years on with my car my latest compression test showed higher figures on both rotors, so........... ;)
RenesisRaceBuggy
Post by RenesisRaceBuggy » Fri Mar 10, 2017 1:12 pm
It would still help on the R3.
Plan3tBob
Has thanked: 42 times
Post by Plan3tBob » Mon Jul 16, 2018 12:28 pm
Apologies for the nooby question: But can someone please explain what this means? :)
AutoGibbon
Has thanked: 29 times
Been thanked: 25 times
Post by AutoGibbon » Mon Jul 16, 2018 1:04 pm
Afaik, imported RX8's aren't subject to the same stringent emissions requirements as those sold in the UK. Meaning you can remove the catalytic converter in favour of a straight pipe mid section, choke on the fumes/enjoy more free flowing exhaust, and still pass the emissions test when you put it through an MOT.
Andrew.
09' R3, Sparkling Black ~ RRP Stainless 3" cat + catback ~ RRP Lightweight Pulleys ~ RRP MKII ignition coils & MSD 8.5mm leads
Instagramelonalam: @autogibbon
Been thanked: 785 times
Post by PeteH » Mon Jul 16, 2018 1:11 pm
No idea. According to .gov.uk the emission test to import the car, and get it subsequently MOT'd will be identical to if the car was a UK car of the same age:
https://www.gov.uk/government/publicati ... #emissions
"The IVA standard for both spark and combustion ignition emissions is identical to the MOT standard so you can have the vehicle checked at a local MOT station before the inspection."
Post by warpc0il » Mon Jul 16, 2018 1:34 pm
You might get away with it if the car was on a Q plate but that has so many other disadvantages, like resale value and insurance.
Juey
RX-8: Import
Colour: Black Cherry
Been thanked: 100 times
Post by Juey » Mon Jul 16, 2018 1:39 pm
Post 1992 imports get tested the same as the UK equivalent. So a de-cat is still a no no.
Black Cherry Mica
I can explain it to you, but I can't understand it for you.
Bex
Has thanked: 16 times
Been thanked: 31 times
Post by Bex » Mon Feb 25, 2019 11:28 am
id buy one!
i always wanted Q plate car - its unusual, different.
(also , realised im commenting on old posts as im reading through the forum posts for info as my mot is due soon)
Return to “RX-8 Discussion”
