Tools, tools, tools (was Thumb Ratchets)
Has thanked: 2572 times
Been thanked: 940 times
Re: Tools, tools, tools (was Thumb Ratchets)
Post by ChrisHolmes »
New Duke wrote:
Tue Jan 04, 2022 4:14 pm
I'm planning on getting a workbench. Mainly for working on lawnmower engines, maybe disassembling a Renesis or two, and general parts testing and fiddling. I currently only have a collapsible woodworking bench and lay bolts out on my garage sofa.
I've found one I like and the size that suits my available space best is 170cm x 75cm. It's got a steel top and can hold 1000kg, which I assume is plenty for a Renesis?
They also do a different one with a load rating of 1500kg which is steel on top of MDF for £150 more. It looks nice but might be overkill?
Any thoughts on whether 170x75 cm is enough space to dismantle a Renesis? That's probably the biggest thing I'll work on. Or should I go deeper?
Just place a sheet of varnished marine ply on top of the steel top which will increase the load capacity and also stop stuff sliding around which I always found an issue with a steel bench.
New Duke
Has thanked: 695 times
Been thanked: 561 times
Post by New Duke »
Thanks a lot gentlemen. V helpful.
pstables
Has thanked: 6 times
Been thanked: 10 times
Post by pstables »
Link to video comparing different workbench tops / finishes;
https://www.youtube.com/watch?v=e3xEeZV ... alWorkshop
May save you a few quid considering plywood / wood prices.
These users thanked the author pstables for the post (total 3):
casey (Mon Jan 10, 2022 11:35 am) • New Duke (Mon Jan 10, 2022 12:08 pm) • ChrisHolmes (Mon Jan 10, 2022 5:52 pm)
Interestingly as I have some spare 18mm MDF I am going to use for a bench top and also some left over hard wax oil so good to see it performs well as a surface treatment.
New Duke
Post by New Duke »
Well now I'm torn between being smart and saving money with MDF or feeling posh and using marine ply :D
First world problems.
I'm going smaller on the workbench. Only 120cm or 150cm wide and 75cm deep. I'm getting a bigger wheel/tyre track to store the 12 spare tyres/wheels that I keep in the garage for our cars. So a smaller workbench means I can get a more serious wheel rack.
18mm MDF sealed or will be fine
Richnzj
Post by Richnzj »
Riga deck plywood would work well
Sent from my SM-G973F using Tapatalk
New Duke
Post by New Duke »
Thanks guys. Order placed on a workbench and new wheel rack. I'll be sure to seal the workbench top. With some better use of space in the garage I've worked out how to retain my sofa bed too. Which I thought I'd have to lose. The garage now has a big TV, sink, toilet, food, bed. It's nicer than my first home :lol:
ChrisHolmes (Tue Jan 11, 2022 4:56 pm)
I just bought these which means that any brand of burr or stone with 3mm shafts plus several sizes of drill can now be held firmly.
nightfire10
Has thanked: 742 times
Been thanked: 284 times
Post by nightfire10 »
just spotted this on fb https://fb.watch/aBcpIW76t6/
nightfire10 wrote:
Mon Jan 17, 2022 2:08 pm
Falls into the Too Good To Be True. I did actually once order one to test the water and after several weeks when I chased delivery the tracker showed as "Delivered" and upon digging deeper this "delivery" was actually a mystery pair of cheap sunglasses that were delivered, I did wonder why I had received them.
I did get my money back though from PayPal.
nightfire10
Yeah this was £99
MightyCondor
Has thanked: 48 times
Been thanked: 60 times
Post by MightyCondor »
It's only been 6 years, but the thumb ratchet that I bought when this thread kicked off really proved invaluable last weekend when I was disassembling my engine bay.
Sent from my IN2013 using Tapatalk
These users thanked the author MightyCondor for the post (total 2):
ChrisHolmes (Tue Jan 18, 2022 9:34 pm) • SeriousSam (Wed Jan 19, 2022 7:38 am)
Has thanked: 442 times
Been thanked: 2087 times
We've just been watching Vintage Voltage (S02E01) where they fitted a Porsche 911 with a Tesla S motor.
I always find the engineering interesting and was particularly pleased when they run the finished car out, and you could see that they have the same make and model 2-post lift as we fitted last year.
GreySilver Beast (Sat Feb 26, 2022 6:21 pm)
mrspiller
Has thanked: 114 times
Been thanked: 158 times
Post by mrspiller »
Vintage voltage is a real eye opener
Amd wallet opener for the customers
Clever guys mind
nightfire10
Yep I enjoy watching it
New Duke
Post by New Duke »
warpc0il wrote:
Sat Feb 26, 2022 6:10 pm
I bought my Twinbusch lift precisely because you rated yours highly Dave. It's been exceptional and while at first I gasped at the price compared to Chinese eBay lifts, now I think it was excellent value.
warpc0il (Sat Feb 26, 2022 8:33 pm)
Watching Ep3 of Vintage Voltage and they're fitting a Tesla small unit into the front of a Mini.
Only problem is it has to go in front to back, which means it has to spin in the opposite direction.
Apparently this isn't an issue for the motor (really???) but the oil pump that keeps the reducing gears lubricated would suck from the bearings and blow into the sump.
They made a neat adaptor plate to fit the oil pump the other way round, which solves that problem, but I think they missed a much more critical issue.
Apart from splitting the cases apart by hammering and levering screwdrivers into the joint, leaving visible damage that's going to compromise the refit, there's also the issue of reversing the torque through that gear train.
They're helical gears so applied torque will be creating a significant side-thrust. The shaft and gear mounts will have been designed and engineered to resist that thrust in one direction for drive, with only a tiny bit the other way for regen.
Now their drive is reversed and so is the side thrust. That big gear has all those high-tensile bolts and big bearing to stop it lifting, while the small gear behind needed little support as it was pushing down.... #-o
Yes, their solution worked, but I wonder how many miles before it destroys itself.
These users thanked the author warpc0il for the post (total 3):
rotatopotato (Wed Mar 02, 2022 4:29 pm) • ChrisHolmes (Wed Mar 02, 2022 5:04 pm) • zippyonline (Sat Mar 26, 2022 9:09 pm)
This just hit my inbox, might be handy for those tight flywheel nuts... :D
https://www.sgs-engineering.com/milwauk ... rench-case
Comes with its own sky hook by the looks of it.
How’s make a spigot bearing puller
New Duke (Sat Apr 09, 2022 9:51 pm)
Price reduction compared to other sellers on Facebook!!
Hilarious!
I'd need some solid chunks of railway sleepers, before you'd get me under a car with one of those :shock:
Don’t worry Dave, at that price no one is going to receive one anyway.
I have reported dozens of these adverts but they persist in Facebook Market Place as it seem totally unregulated or monitored.
I ordered a pressure bleeding kit from Amazon the other day which arrived this morning but the tyre valve adapter was faulty and as expected there also was not a suitable cap to fit the brake master cylinder.
I went onto the Amazon website and whilst filling out the returns details the message "You do not need to return this product" flashed up followed by "Your refund has been sent" so whilst I will need to be inventive to get the kit to work I have received free!
