Engine Survey
What was your mileage when you had your engine rebuilt/replaced
Under 20K
10
2%
20-30K
9
2%
30-40K
11
3%
40-50K
27
6%
50-60K
37
8%
60-70K
40
9%
70-80K
33
8%
80-90K
15
3%
90-100K
14
3%
100-110K
1
0%
110-120K
0
No votes
Over 120K
1
0%
No rebuild yet :)
242
55%
Total votes: 440
Janko_D
Forum Guest
Forum Guest
Re: Engine Survey
Post by Janko_D »
62K miles and rebuild with new rotor housings, the old ones were crap, broken apex seal tip. Germany import with fully mazda service history.
upderebels
Forum Guest
Forum Guest
RX-8: Nemesis
Re: Engine Survey
Post by upderebels »
111000k..no rebuid yet..
Kwackers2016
Colour: Stormy Blue
Re: Engine Survey
Post by Kwackers2016 »
14k and still going strong :lol:
AndyBrad
Been thanked: 28 times
Re: Engine Survey
Post by AndyBrad »
None as yet on 39k. However it would be interesting to see a comparison between the R3 and the previous ones to see if the revisions have had any effect?
These users thanked the author AndyBrad for the post:
RX8Pete (Thu Apr 21, 2016 11:44 am)
722Adam
Has thanked: 10 times
Re: Engine Survey
Post by 722Adam »
No evidence of a rebuild on my car, bought in Jan 2016 and currently at 48k miles.
Previously owned - Full Bridgeport 231 - Built by Rotary Revs
Now exclusively running BMWs
2018 BMW 118i
2015 BMW 430d GranCoupe
1999 Alpina B10 V8
And
Forum Guest
Forum Guest
Re: Engine Survey
Post by And »
I have an 07 with 74k on it and is showing signs of wanting some attention
CLOVERLEAF159
Has thanked: 51 times
Been thanked: 20 times
Re: Engine Survey
Post by CLOVERLEAF159 »
2010 R3, 30,000 miles.... no rebuild
Vian
Has thanked: 27 times
Been thanked: 52 times
Re: Engine Survey
Post by Vian »
I've just moved into the top 12 as I hit 80,000 miles.... ;) *
* This is based on a deliberate misunderstanding of how it works....
Mpv2k3
Has thanked: 52 times
Been thanked: 31 times
Re: Engine Survey
Post by Mpv2k3 »
2009 R3 with 43k.......no rebuild
Tariq
Re: Engine Survey
Post by Tariq »
63k no rebuild. No hot starts.
About to fit D595's, new starter, plugs etc. Should bring out more life from her yet.
RX8Pete
Re: Engine Survey
Post by RX8Pete »
No rebuild yet & on 46k 2007 S1. Had the car since 34k & second owner. My work means the drive is a mixture of 3-4 hours solid driving to clients or back home (Mon & Thr) & in between usually less than 15 miles (from/to hotel). Always add 160 ml 2T on each tank fill-up. The car is stock from K&N filter & D585's. Was becoming harder to start (long turnover of 3-5 secs before starting) on original ignition kit but after fitting Nutty's D585 coil kit & new IR heat range sparkers she now starts like she's possessed & feels like a new car. #8yoGrinFactor
Interesting hard data btw...
Done .....: K&ND585 KIT (HERKO HE)CRUISE CONTROL...SOHN TANK...PART LED EXTERIORBONNET STRUTS
WIP.......: Photochromic mirrorKeyfob auto up/down windowsLED interiorPZ type spoiler
Wish list .: Electric passenger seatCobra catbackThrottle body port & polishP/Black trimFull mapAlloys4 Pot brakes20BReverse auto wing mirrors tilt
Everton
Re: Engine Survey
Post by Everton »
Everton wrote:No rebuild yet (that I'm aware of). 55k (bought it at 50k), premixing, D585 coils. Starts on the button hot and cold.
Started to show symptoms of rear stat bearing failure and early signs of low compression (taking longer to start when hot). Rebuilt by RR at 68k :D
Sorted by Rotary Revs | RR D585 Coils | Castrol Power 1 Premix and V-Power Nitro+ :D
Rotary Revs Gold Rebuild and Street Port \:D/
tony8xr
Re: Engine Survey
Post by tony8xr »
not rebuilt yet and at 25000m
Andy1969
Re: Engine Survey
Post by Andy1969 »
BB 56 PZ - 1 Previous Owner No Rebuild (bought off Nutty Chappy in Feb 2015) with 22K Comp was 7.7 on across both rotors..
Now on 28K, been under about 4ft of the River Irwell and still starts on the button hot or cold and idles perfectly (who says these engines are fragile :D)
Also have a WB 231 54 on 60K Engine was rebuilt by Rotary Revs in 2012 with a Streetport @ 48K
07/2011 - 2015 55 BB 192 - RIP :(
02/2015 - Present : 56 BB PZ - Currently Breaking!
David H
Re: Engine Survey
Post by David H »
61K & no evidence of a rebuild. No compression test but Nutty Chappy confirms it's still pulling well.
Previous owner said it was mainly used for motorway driving. :shock:
53 Lightning Yellow 231, RR rebuilt/street ported + Sunroof + SatNav + Aero Kit + Toyo Sport S/S decat + PZ suspension + galvanised sills + full respray + DRLs + LED interiors
hobbiniho
Forum Guest
Forum Guest
RX-8: Import
Re: Engine Survey
Post by hobbiniho »
53 reg jap import with 38k no rebuild
SteveTroman
Re: Engine Survey
Post by SteveTroman »
2005, 85,000 No rebuild, compression done 3 months ago all in the 7s.
wjb
Re: Engine Survey
Post by wjb »
'06 PZ
78,000 miles
Comp test last month in 6's
No rebuild, yet :)
Ex - Galaxy Grey Mazda RX8 PZ
Current - BMW X5 & baby YZF
Like I told my last wife, I says, "Honey, I never drive faster than I can see, besides that, it's all in the reflexes."
Rx8-Col.
Colour: Metropolitan Grey
Re: Engine Survey
Post by Rx8-Col. »
41k 58' plate. No rebuild as yet. Although she doesn't get out much :lol:
Mazda Rx-8 40th Anniversary Metropolitan Grey #230/400
Fitted parts:
RB Revi intake, RB Scoop, RB Rev8 exhaust,Cusco Strut brace, D585 Coils, Magnecor Leads, Aero Kit, Bonnet lifts, MadTaz remap 8)
leemcmini
Re: Engine Survey
Post by leemcmini »
56 pz 68k no rebuild
davidh
Re: Engine Survey
Post by davidh »
Response now changed -
71k miles - Rear stationary gear bearing failure :(
Now rebuilt by Rotary Revs and collecting it on Monday :)
These users thanked the author davidh for the post:
And (Sat Oct 01, 2016 8:19 am)
06-192|Street Ported|Strakes|Red Calipers and decals|Lockwood grilles|Lowered 3/4 plate|Petit Radio Knob|Sessantas 245/40|AuxMod|Nexus7|K&N panel|40th Anni spoiler|HIDs|LED sidelights|RB RamAir|Re-Amemiya shifter|Illuminated knob|Rear Grilles|Alu Fuel lid|Aero kit|DRLs|F&R DashCams|EBC Ultimax and redstuff|D585 Coils|Eibach springs|Braided brake and clutch lines|Sohn kit|Toyo decat and catback
Has thanked: 186 times
Been thanked: 548 times
Re: Engine Survey
Post by Dr. FrankenRex »
Added another vote for no rebuild yet as my last RX got to 90k and got rebuilt, but now I've got a non-rebuilt R3 :)
v8rumbler
Forum Guest
Forum Guest
Re: Engine Survey
Post by v8rumbler »
2004 39k no rebuild
Velocity Red 231
Harrymonk
Has thanked: 13 times
Re: Engine Survey
Post by Harrymonk »
I can't technically vote as I took a punt on a car with little history.
It has apparently had a rebuild/different engine and is currently at 91k, but I don't know when or how many times it has had work.
Garydeery
Re: Engine Survey
Post by Garydeery »
87.000 same engine still going strong for a 04 reg
