Weight Saving
Re: Weight Saving
They fit over the smaller front discs that the yanks get as standard, along with softer suspension...
- Has thanked: 25 times
- Been thanked: 96 times
Re: Weight Saving
The 18s are just under 10kg by my scales iirc. I'll weigh one this afternoon to verify
- Been thanked: 9 times
Re: Weight Saving
Just to keep this going.
Rear wheelarch liners (pair) 2.0kg
Steering wheel (incl. airbag) 2.8kg (my race wheel+boss is 1.6kg)
Under-boot heat shield 1.2kg
Bonnet catch + opening mechanism 0.6kg
Charcoal canister + bracket 1.3kg
I've removed 218kg so far
Re: Weight Saving
What [urlw=http://www.exrx.net/Kinesiology/Segments.html]body parts[/urlw] could you do without?
- Has thanked: 6 times
Re: Weight Saving
there's about 10kg just above my belt line I could do with losingwarpc0il wrote:What [urlw=http://www.exrx.net/Kinesiology/Segments.html]body parts[/urlw] could you do without?
Hillclimb/Sprint car thread.
It's not a car, it's an incline assault vehicle
231: BHR coil conversion, Pettit Racing front ARB, updated drop links, Axial Flow Short Shifter, EBC Red Stuff pads. Eibach springs. K&N panel filter, Maxsport RB5 225/40R18 (track). Unknown brand ditchfinders (road). So far....
VIDEOS HERE OF EVENTS
Re: Weight Saving
Question any weight measurements for exhaust system from manifold out?
Trying to see which is lighter compared to Toyo/Scorpion/Petite racing etc
Current
M3 E92
OLD Car
Half-Bridge Engine
Lightened Fly + Clutch
Whiteline ARB's + Droplinks
Brake Upgrade 4 pot front
AEM Intake
D969 Coils
YellowSpeed Suspension
Dwell timers adjusted
Short Shifter
Braided Brake + Clutch Lines
M3 E92
OLD Car
Half-Bridge Engine
AEM Intake
D969 Coils
Short Shifter
Re: Weight Saving
OEM cat section 11.0kg
Toyo decat 4.9kg
OEM cat back silencer section 18.5kg
Racing Beat single exit silencer 11.6kg
13kg saving
Toyo decat 4.9kg
13kg saving
Re: Weight Saving
wow cheers, with these and car seats...I can eat more cake
Current
M3 E92
OLD Car
Half-Bridge Engine
AEM Intake
D969 Coils
Short Shifter
M3 E92
OLD Car
Half-Bridge Engine
AEM Intake
D969 Coils
Short Shifter
Re: Weight Saving
Nope, that is 100% the stock 18" wheels.warpc0il wrote:So that would for the 16" or 17" versions, as the Yanks didn't get 18" stock wheels.Elektix wrote: These opening figures are from the yanks to get us going. I have converted them to KG.
Stock wheels - 10kg a piece!
The yanks got them as an option; but more than likely I was just adding my knowledge for that particular item.
I see this thread has picked up well! When I get to a laptop I will update the first post with all the figures we have accrued. Or if an admin has some free time they could put all the details into my first post
- Been thanked: 4 times
Re: Weight Saving
I will weigh my Hotchkiss ARB's which are stiffer and hollow. Would be interesting to see the weight differential between, stock, RB, and these.
●2004 Custom Blue ● Full Body kit and Carbon Fibre Mazdaspeed style Spoiler
● Polybush Full Kit● XYZ Coilovers● Hotchkis Front ARB's
● Pettit ANP Remap and EFIDUDE Logger●D514A Coil Packs Setup
● K&N Panel Filter● Racing Beat CAT Back Exhaust● ToyoSport HiFlo CAT
●Dimpled and Grooved Discs●EBC Yellowstuff pads●HEL Brake/Clutch Lines
●XXR 550 Wheels 8.75J ET36●Nankang NS2-R●R3 Differential
Re: Weight Saving
Liam22 wrote:Finally got all of the adhesive soundproofing out. Horrible job.
8.5kg, comprising:
- LHS floorpan, 2 pieces (as photo)
- RHS floorpan, 2 pieces
- Boot floor, 4 peices
Liam,
I'm currently working my way through this job at the moment. I'm amazed how much weight there is in this stuff alone!
The quickest way I have found to remove it is, get some freeze spray or dry ice. Put it on the insulation for a few seconds then immediately hit it with a hammer. Shatters it and makes it come away in big chunks.
I've done my boot now, and looking to do the front but before I start the front, did it make the car sound any 'tinnier' or excessively noisier? I've noticed the boot now sounds a bit cheaper almost with the metal being thin. But nothing I really notice with the carpet back down. I just don't want to make it excessively loud and uncomfortable inside as I'm aiming to keep this a streetable car.
I'm expecting with the carpets back in place it shouldn't be too bad?
- Has thanked: 66 times
Re: Weight Saving
What kind of things has everyone removed or replaced to save weight but also maintain the function of the car? I think the carbon boot lid is a good one.
RX8 R3 Aurora Blue Mica
Re: Weight Saving
Take a look through the previous posts, the list is reasonable comprehensive.
What one person defines as functional, another person may not. My car has no seat belts, airbags or rear seats. But it has full carbon buckets and harness'.
- Has thanked: 18 times
- Been thanked: 78 times
Re: Weight Saving
Does it weigh much less than the stock lid though, best thing to do to save weight with. Out lid is to just use the skin and use bonnet pins to hold it in placedelta0 wrote:What kind of things has everyone removed or replaced to save weight but also maintain the function of the car? I think the carbon boot lid is a good one.
2007 Galaxy grey 231.
Re: Weight Saving
Roughly half the weight (4kg) from what I've seen.Eddie_r32 wrote:Does it weigh much less than the stock lid though, best thing to do to save weight with. Out lid is to just use the skin and use bonnet pins to hold it in placedelta0 wrote:What kind of things has everyone removed or replaced to save weight but also maintain the function of the car? I think the carbon boot lid is a good one.
- Has thanked: 27 times
- Been thanked: 52 times
Re: Weight Saving
I've got a carbon bootlid, and it is substantially lighter when you open and close it - the standard one is really rather heavy. However, I didn't do that to save weight, more because I was sick of them rusting. If I was really worried about 4kg I'd do more by going to the gym more often and never calling in at KFC!
Re: Weight Saving
Rust was the main reason I would do it too. As soon as the issue occurs I would change it to a CF one.Vian wrote:I've got a carbon bootlid, and it is substantially lighter when you open and close it - the standard one is really rather heavy. However, I didn't do that to save weight, more because I was sick of them rusting. If I was really worried about 4kg I'd do more by going to the gym more often and never calling in at KFC!
Re: Weight Saving
Hi guys In building a rallycar Here in Denmark I've just weighed the entire wiring and all the computers that's about 60
Kilo on betting I can get it down to about 15 with aftermarket ecu and new wiring to the lights and couple of other things.
Sound proofing inside the car is 10 kg
This is a great thread keep it coming.
By the way the aircon radiator inside the car takes about 1,5 hour to remove and it only weighs 0,3 kg so I don't recommend that HAha
Re: Weight Saving
That's all good info. Thanks Sa22rally. And welcome to the club. Please feel free to introduce yourself in the Hello.. I'm new here section: http://www.rx8ownersclub.co.uk/forum/viewforum.php?f=35Sa22rally wrote:Hi guys In building a rallycar Here in Denmark I've just weighed the entire wiring and all the computers that's about 60
And we'd all love to hear more about your car. Pictures and a build thread would be splendid.
Re: Weight Saving
Sa22rally and
Re: Weight Saving
Thanks guys I will be making a build thread at some point but I'm fitting the cage right now it's a very slow progress the weight is actually what I'm most excited about. Right now I'm awaiting a big order from demon tweets it's like Christmas
Sadly i don't know how to post pics here I I would have posted a few
Re: Weight Saving
You can add links to photo sites like Photobucket - scroll down in this thread http://www.rx8ownersclub.co.uk/forum/vi ... =2&t=35968 to see how.
Re: Weight Saving
Some more numbers:
Radio head unit: 2.92kg
Lip spoiler: 1.24kg
Hoop spoiler: 1.5kg (I know, it's not much more!)
Ghetto decat: 9.5kg (1.5kg less than full cat)
Air box base, lid and filter: 2.81kg
Air box undertray: 1.00kg
Polystyrene behind front bumper: 0.17kg
vFAD: 0.88kg
Headlamp washer system compete: 1.25kg (+0.2kg fluid)
Alarm: 0.23kg
The air box got replaced with REVi, which was much lighter, but I forgot to weigh it.
Lip spoiler: 1.24kg
vFAD: 0.88kg
Alarm: 0.23kg
- Has thanked: 68 times
- Been thanked: 131 times
Re: Weight Saving
Last edited by exiled--viking on Sun Feb 05, 2017 4:00 pm, edited 1 time in total.
- Has thanked: 15 times
- Been thanked: 13 times
Re: Weight Saving
Put in a supercharger
Paul
RR Platinum Rebuild, Lightened Rotors and a Half Bridge, plus many other mods.
Check out http://www.rx8ownersclub.co.uk/forum/vi ... 04&t=66822
