Page 984 of 1181
Posted: Tue Jan 12, 2021 9:12 pm
by SmuttyHutty
mrspiller wrote:
Tue Jan 12, 2021 9:10 pm
SmuttyHutty wrote:Thank you - I'll hunt it out
Someone willl link you up
It’s a neat job
Just found it - thank you. Using card as a template for the mount is a good idea. I'll take a look at my engine bay in the morning and think his solution is inspired.
Posted: Tue Jan 12, 2021 9:13 pm
by mrspiller
It’s a neat job
A the PDF pattern on there ?
Posted: Tue Jan 12, 2021 9:17 pm
by SmuttyHutty
I didn't see it. It would be specific to the model of 2 stroke tank he used which is understandable. viewtopic.php?f=204&t=50241&p=704096&hilit=tank#p704096
I'm not sure if I have cited the thread correctly...
Posted: Tue Jan 12, 2021 9:26 pm
by qwakers
aye thats the ap50 tank and the design of mount i used.
Posted: Tue Jan 12, 2021 9:34 pm
by TriggerFish
This is interesting! I'd often wondered what was to stop people just mounting their own tank, but now I see (and further searching after reading this) suggests it's actually pretty common. I guess there's never going to be a way to avoid buying an adaptor plate for the pump itself though
It's a bit involved, but this is a neat solution! https://www.rx8club.com/series-i-do-you ... ox-213640/
Posted: Tue Jan 12, 2021 9:35 pm
by mrspiller
Job done
I have PDF if you need it
Posted: Tue Jan 12, 2021 10:03 pm
by Neilparry
I have one ready to fit I’m not now using.
I’ve fitted a low level float into it
Posted: Tue Jan 12, 2021 10:19 pm
by warpc0il
The US Sohn tank solutions that replace the washer bottle don't normally cater for the extra outlet needed for our 231's, as they didn't get HID lights as standard on any of their models, so it's not that common.
Obviously not an issue for a UK 192 either.
Posted: Wed Jan 13, 2021 8:33 am
by rotatopotato
The guy making the kit I used (that really common one with the evil M logo on the plate) caters to RHD 231s with the extra pump for the headlights. I had to be sure to specify mine as a RHD 192 due to that.
Posted: Wed Jan 13, 2021 11:26 pm
by sztriki
Got the car to the garage today to get the coolant leak checked. One of the clips rusted away, got that replaced and sorted. Happy days.
Starting to do my research on my rebuild and going to send some feelers out. Planning it for March, thinking of HME and TPS mainly.
Posted: Wed Jan 13, 2021 11:58 pm
by untakenname
SmuttyHutty wrote:
Tue Jan 12, 2021 8:18 pm
I am currently playing with ideas for a SOHN/COF tank and don't want to lose the huge windscreen washer tank. My first thought was one type of motorcycle 2 stoke tank but the one I got was too wide at the bottom. I've had a good look at the 192 engine bay and the only decent place I can see to place one is (which looking from the front of the car) the back left corner to the left of the brake master cylinder.
An ideal container would be cylindrical and there are a couple of decent spots where straps could be fitted or, possibly, holes drilled and self-tapping and washered screws can be used. It's not as if the tank is going to be regularly taken out.
I am waiting for a Yamaha PW50 tank to arrive (£10), but it holds only 350ml and so I am looking into the option of having two of them and joining the outlet with a simple hose and T-bar set up. If there isn't space, the other option is for the DT125R oil bottle (£17) at 900ml but I cannot find the exact dimensions of this.
I am probably going to spend more on failed attempts than buying the kit from the USA and having it sent over, but I want to try and find a solution and whizz up to BigPete and create a path that others are free to follow.
My other issue is that the RRP COF needs a hose with ID of 10mm and these 2 stroke tanks have tubes with ID of 5mm. I know I can get step up connectors but that is an ugly solution unless I can hide the connector somehow.
I used a moped tank (from a Piaggio iirc) and an adaptor to step up to the sohn device, holds around 800ml has a built in level sensor and fits in by the brake booster.
Can't seem to find a decent shot of the engine bay but you can see it at at the top of the bay
Posted: Thu Jan 14, 2021 6:36 am
by PaulAV
My rebuild was carried out by Hurley's, quick turn around and I'm currently on just over 40,000 miles on this rebuild(I did have a bearing spin on original rebuild, but they sorted it under warranty, at that point the engine had covered 10,000 miles and was 20 months into thier 2 year warranty)
Posted: Thu Jan 14, 2021 3:55 pm
by Pippypip
So after my low level issue I have been very lazy as I haven’t had to drive the car. So I thought today I would try to solve it and to my surprise my engine block had a lot of oil where the sandwich plate was for my sensors. So I took off the filter which had zero oil in it.... so I guess the oil leak might explain the light now
Posted: Thu Jan 14, 2021 6:28 pm
by v-rex
One vote for TPS from me. 3500 miles on my streetport from them and loving the engine so far.
Posted: Thu Jan 14, 2021 9:34 pm
by Pippypip
First lens cut for the new lights. Gotta give a big thanks to John for the advice and the courage to go ahead and cut them Image
Posted: Thu Jan 14, 2021 10:00 pm
by 30405
Pippypip wrote:First lens cut for the new lights. Gotta give a big thanks to John for the advice and the courage to go ahead and cut them Image
I forgot to say. The gray circle is held in with 2 clip tabs, one top one bottom. I found the best way was to punch out the reflector from the bulb hole to get to them.
Posted: Thu Jan 14, 2021 10:32 pm
by Pippypip
So I have now done both the lights and completely disassembled one now.
I think I will do two separate write ups for it, one for the tear down for anyone who wants to make custom lights and then one for the actual build and wiring.
Posted: Fri Jan 15, 2021 1:13 am
by Pippypip
So after 2 hours of messing about and soldering I have finally ended up with this....
The way that I have had to wire it is strange as it’s a circle and I need the middle section to be on wires to go out of the light and down to the standard fog light connection.
Posted: Fri Jan 15, 2021 2:32 pm
by PaulAV
Just did the cx5 washer jets upgrade for anyone that's interested the part numbers are kd45-67-510 and kd53-67-510 only issue is the entry is from directly underneath, rx8 are from the side, but you can reroute the pipes and you don't need to cut anything, these jets won't block in a hurry
Posted: Fri Jan 15, 2021 8:26 pm
by Pippypip
So I just tested the fog light part of my new rear lights and found out 2 of my led arrays don’t work which is incredibly annoying as I don’t have a bench tester here which means to make sure everything works I have to go down to my car and make sure it works off of the car
Posted: Fri Jan 15, 2021 10:03 pm
by 79398
Booked her in to have 4 wheel alignment, and set suspension up for fast road and lift her up about 10mm.
Sick of scraping over white lines😳
Going to Tuned in Llay.
Will post the improvements, only worry is their ability to free the camber adjusters.
Oil and filter change on Sunday, well overdue.
Posted: Sat Jan 16, 2021 9:24 am
by mrspiller
79398 wrote:Booked her in to have 4 wheel alignment, and set suspension up for fast road and lift her up about 10mm.
Sick of scraping over white linesImage
Cover them in releasing oil a few times if they haven’t been adjusted in years
Posted: Sat Jan 16, 2021 9:30 am
by SmuttyHutty
Can't remember which member recommended this to me:
Innotec Deblock XS Oil  Penetrating Oil  500ml  DeBlock  Rust Dissolver https://ebay.us/LiqWMB
Posted: Sat Jan 16, 2021 6:01 pm
by PaulAV
Fitted RRP exhaust today (was Chris's) it's certainly quieter than the Borla that it replaced. Need to adjust my driving habits again
Posted: Sun Jan 17, 2021 10:47 am
by rotatopotato
What's it like for drone at 70mph?
Ive got a gutted stock cat and a toyosport, looking at going for the RRP cat + cat back.
