Page 917 of 986
Posted: Fri Jun 19, 2020 11:18 pm
by untakenname
I use a moped tank as well, fits in pretty well with the engine bay.
This is the cheapest FL22 fluid I've found though it's not made by Mazda, used it in both of my RX8's.
https://www.ravenol-direct.uk/ravenol-h ... trate.html
Posted: Fri Jun 19, 2020 11:20 pm
by PaulAV
So I got a bargain for mazda fl22 at £20 for 5 litres
Posted: Sat Jun 20, 2020 4:13 am
by Yorindesarin
I am. However I decided that I'd like the engine bay to look a bit neater plus I need somewhere for an actual oil catch can at some point so. This also makes it a bit more of an actual project.
Posted: Sat Jun 20, 2020 8:13 am
by Markl17
Washed the car this morning as I am going to a small car meet at a local cafe,it seems like a life time ago since the last one it will be a good chance to catch up with a lot of people I have not seen for a long time,drink some coffee and look at cars.
Maybe normal life is on its way back.
Mark
Posted: Sat Jun 20, 2020 8:33 am
by v-rex
Markl17 wrote: ↑Sat Jun 20, 2020 8:13 am
Mark
Let's hope! I think it's all heading in the right direction. Let's hope we get an Indian summer so we can also enjoy some of the sun we've missed during lockdown....
Posted: Sat Jun 20, 2020 1:00 pm
by johnbb99
Washed the car this morning as I am going to a small car meet ,....
Mainly fiestas and polos?
(Sorry)
Posted: Sat Jun 20, 2020 1:07 pm
by PaulAV
^^^ smart, bubble and kei cars
Posted: Sat Jun 20, 2020 5:25 pm
by Dave2112
Well after my exploits last weekend changing the coolant hoses, I was coming back up my street after a drive out today and as I pulled up, I saw steam billowing out from the bonnet and my temp gauge shot up and warning light on
immediately switched off and could see coolant pissing out below
Let it cool a bit and started exploring. Found it, the usual suspect on the radiator. Although I didn’t replace that hose I must have weakened it when removing/replacing the expansion tank. Glad it happened 20 yards from my door and not on track or miles from home!!! Luckily I have a Koyo on my silver breaker which was only about a year old when I took her off the road.
Posted: Sat Jun 20, 2020 5:27 pm
by Vj4sothername
Dave2112 wrote:Well after my exploits last weekend changing the coolant hoses, I was coming back up my street after a drive out today and as I pulled up, I saw steam billowing out from the bonnet and my temp gauge shot up and warning light on
MOD saved you a right headache!
Posted: Sat Jun 20, 2020 7:04 pm
by ChrisHolmes
Luck RX8 style!
Posted: Sat Jun 20, 2020 7:42 pm
by Dave2112
Yeah that would have been a laugh if it happened at Abingdon. Thank you MOD
Posted: Sat Jun 20, 2020 8:16 pm
by Dove66
Drove to Big Pete’s in Boston for a service.
Posted: Sat Jun 20, 2020 8:54 pm
by exiled--viking
Posted: Sun Jun 21, 2020 1:00 am
by geofftl1000r
Thought I'd have a go at fitting the RRP decat I bought quite some time ago. The Toyo pipe, on the car when I bought it, must be smaller as the doughnut seal wouldn't fit. New one on order so hope that fits,
Decided to fit the braided clutch line instead. Bit of a fluff to bleed but all done and yet more blue in the engine bay. I need to replace that little tube that goes from the brake fluid reservoir to the clutch master cylinder. Hadn't noticed it until now so it has to go!
Posted: Sun Jun 21, 2020 6:24 am
by nightfire10
geofftl1000r wrote:Thought I'd have a go at fitting the RRP decat I bought quite some time ago. The Toyo pipe, on the car when I bought it, must be smaller as the doughnut seal wouldn't fit. New one on order so hope that fits,
On my rrp 200cell cat I had to stretch the doughnut to fit and it was a new one
Posted: Sun Jun 21, 2020 7:58 am
by mi60o0
Drive it home first drive since last September.
My power steering went away that was funny 70miles.
Also 3 miles in to the driving randomly miss fire some time solid engine light flash and then completely went away but no loss of power or hesitate.
Today will check for a vacum leak unplug leads etc contact cleaner plug everything in again.
Coils and plugs covered 6k miles from new they are 1year and half old but still hope they are okay other wise bloody oem coils.
Posted: Sun Jun 21, 2020 10:16 am
by warpc0il
The power steering and other issues could all be caused by a loose battery connection or corroded earth.
Posted: Sun Jun 21, 2020 10:19 am
by mrspiller
What’s it made from ?
Posted: Sun Jun 21, 2020 10:31 am
by exiled--viking
Aluminium all parts off eBay less than £10.00 to make but around 40 hours work just fitting it now
Sent from my iPad
Posted: Sun Jun 21, 2020 10:42 am
by mrspiller
exiled--viking wrote:Aluminium all parts off eBay less than £10.00 to make but around 40 hours work just fitting it now
Sent from my iPad
Very impressive
Posted: Sun Jun 21, 2020 10:51 am
by mi60o0
warpc0il wrote: ↑Sun Jun 21, 2020 10:16 am
I had power steering when I start the car then left right no problem get around the pond and boom no power steering.
Miss fire sorted unplug all leads plugged again no more miss fire I done 10 spirited miles no Singh of it.
I never lose power even yesterday.
Dave what you recommend to check about the power steering i done the 2 connectors above the radiator they are clean and like new I spray some contact cleaner but still not joy
Posted: Sun Jun 21, 2020 10:59 am
by warpc0il
Have you checked the PS fuse (and its holder) on the battery positive terminal?
Posted: Sun Jun 21, 2020 11:00 am
by mi60o0
warpc0il wrote: ↑Sun Jun 21, 2020 10:59 am
Seems fine I think I have spare one I will give it a go
Posted: Mon Jun 22, 2020 10:50 am
by PaulAV
Job for today, coolant pump replacement, whilst changing my pulleys I noticed a bit of play in the pump bearings, although it wasn't weeping there was play both axial and lateral, plus if you spun the pump it would freewheel, I would recommend anyone that is working on either the pulleys or the belts, give the coolant pump a wiggle to check.
Posted: Mon Jun 22, 2020 1:57 pm
by Honkytonk
P0420 code appeared and was cleared. I'm going to blame the decat unless it pops up again in which case I may need to swap my sensor for the spare 'good' one I have in the shed off my old cat and rule that out. I may have also been a bit more generous with the premix than normal last time I filled up, so the sensor may just be unhappy about that which should go away in ~250ish miles (<200 if I'm enjoying myself).
I should really give it a compression test as well, as it was unhappy starting from hot the other day, although it hasn't done the same since. Think happy thoughts...
