Yes just removed the brackets today, sorry.nightfire10 wrote: ↑Sat Jun 13, 2020 9:42 pmAre you going to use the rear diffuser chris?ChrisHolmes wrote:A lot can change in 10 years and I am pretty sure that Tony would also have broken the car had I not purchased it.
The Racing Brake 4 pot Calipers 2 piece discs, TEIN Mono Sports coil overs currently live on fitted to RR54 and I still have the front splitter rear diffuser & grill, RB Full REV 8 exhaust, a newly reconditioned Pettit supercharger kit sitting in the garage. Plus the balanced street ported engine, RB Braided oil cooler lines, RB lightened flywheel, Exedy Stg 1 clutch so 2021 should be a fun year after a busy winter under my new car port which arrives next week.
- ChrisHolmes
- Has thanked: 5611 times
- Been thanked: 2570 times
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- mi60o0
- Has thanked: 92 times
- Been thanked: 322 times
Chris look at George favorite photoChrisHolmes wrote: ↑Sat Jun 13, 2020 10:53 pmYes just removed the brackets today, sorry.nightfire10 wrote: ↑Sat Jun 13, 2020 9:42 pmAre you going to use the rear diffuser chris?ChrisHolmes wrote: A lot can change in 10 years and I am pretty sure that Tony would also have broken the car had I not purchased it.
- These users thanked the author mi60o0 for the post (total 2):
- GreySilver Beast (Sat Jun 13, 2020 11:54 pm) • ChrisHolmes (Sun Jun 14, 2020 8:46 am)
BatRex 192 stock
- PaulAV
- Has thanked: 117 times
So after splurging some money on the rex I collected my pulleys and sump from Ryan rotary performance today, fitted the pulleys (although tensioner is still awaiting bearing) managed to get the alternator pulley off without the use of an ugga dugga, ground 2 flats on the pulley, gripped it with mole grips and hit socket a few times with a hammer, whilst in there I notice the current tensioner bearing, although not rough, it is on its downwards slope, as is the water pump bearing, its not leaking but there is a bit of play and you can actual spin the pulley and momentum keeps it spinning a little, a sure sign of wear, as a good bearing actually has a resistance to spinning. So orders a new water pump from ecp
Led side lights, purple Led interior & puddle lights, custom stainless steel grills, Ryan rotary performance coils & sohn, high spec rear drop links, HME engine rebuild at 50k, Borla exhaust, racing beat revi intake including scoop, quick shifter, alloy filler cap, pz alloys, suspension & spoiler, japspeed toe arms & hardrace camber arms.
- Been thanked: 3 times
Not 100% turned out how I would have liked but finished modifying this front bumper to put onto my RX-8 the next time weather permits.
- PaulAV
I went for the rear rx8 badge in my grill
- ChrisHolmes
Updated oil pressure relief valve too when the sump is swapped!PaulAV wrote: ↑Sun Jun 14, 2020 6:13 pmSo after splurging some money on the rex I collected my pulleys and sump from Ryan rotary performance today, fitted the pulleys (although tensioner is still awaiting bearing) managed to get the alternator pulley off without the use of an ugga dugga, ground 2 flats on the pulley, gripped it with mole grips and hit socket a few times with a hammer, whilst in there I notice the current tensioner bearing, although not rough, it is on its downwards slope, as is the water pump bearing, its not leaking but there is a bit of play and you can actual spin the pulley and momentum keeps it spinning a little, a sure sign of wear, as a good bearing actually has a resistance to spinning. So orders a new water pump from ecp
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- v-rex
- Has thanked: 519 times
- Been thanked: 193 times
So purpley. One of the things I've been recommended since my rebuild is purple coolant. No idea what it does but I instantly thought of your car when it was mentioned!
- PaulAV
Yes the uprated oil pressure regulator is going in once the sump is out. Was discussing it with Carl this morning. Wouldn't mind a thermal pellet upgrade, but I'm not that brave,ChrisHolmes wrote: ↑Sun Jun 14, 2020 6:49 pmUpdated oil pressure relief valve too when the sump is swapped!PaulAV wrote: ↑Sun Jun 14, 2020 6:13 pmSo after splurging some money on the rex I collected my pulleys and sump from Ryan rotary performance today, fitted the pulleys (although tensioner is still awaiting bearing) managed to get the alternator pulley off without the use of an ugga dugga, ground 2 flats on the pulley, gripped it with mole grips and hit socket a few times with a hammer, whilst in there I notice the current tensioner bearing, although not rough, it is on its downwards slope, as is the water pump bearing, its not leaking but there is a bit of play and you can actual spin the pulley and momentum keeps it spinning a little, a sure sign of wear, as a good bearing actually has a resistance to spinning. So orders a new water pump from ecp
- New Duke
- Has thanked: 793 times
- Been thanked: 712 times
Put my track wheels and 1144 pads back on yesterday ready for Snetterton on Wednesday. I found the rear calipers were seized and spent a while trying to remove them, at one point even trying a club hammer to (gently) knock them free.
Then remembered I'd left the handbrake on!
Thought I was past those simple errors. More fool me!
- nightfire10 (Mon Jun 15, 2020 11:19 am)
- V8 Power
- Has thanked: 235 times
- Been thanked: 490 times
Most of us have done things like that Haydn but we tend to keep it quiet
- GreySilver Beast (Mon Jun 15, 2020 4:36 pm)
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
MSD leads
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
- PaulAV
There's a big difference between doing something and admitting you did something
- ChrisHolmes
Are you just fitting the 1144 Pads for track and then running standard pads the rest of the time? I wouldn’t recommend this as the disc surface becomes “conditioned” during the bedding in process of the new pads. Swapping already bedded in, conditioned, pads for other compound bedded in pads may not provide you with optimal braking performance.New Duke wrote: ↑Mon Jun 15, 2020 10:51 amPut my track wheels and 1144 pads back on yesterday ready for Snetterton on Wednesday. I found the rear calipers were seized and spent a while trying to remove them, at one point even trying a club hammer to (gently) knock them free.
Then remembered I'd left the handbrake on!![]()
No doubt you had not experienced any issues or you wouldn’t be do this but thought I would mention it anyway.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- nightfire10
- Has thanked: 1192 times
- Been thanked: 552 times
Started fitting the 20mm spacers, had to cut 10mm ish off the studs, done one side other tomorrow probably, liking how they fill the arch now.
Sent from my VOG-L29 using Tapatalk- These users thanked the author nightfire10 for the post (total 2):
- ChrisHolmes (Mon Jun 15, 2020 3:23 pm) • GreySilver Beast (Mon Jun 15, 2020 4:38 pm)
To do install sohn tank bracket made but still need to get time to install,caliper painting
- mrspiller
- Has thanked: 181 times
- Been thanked: 482 times
Looks much better
- nightfire10 (Mon Jun 15, 2020 4:41 pm)
- New Duke
Thanks Chris. I wouldn't normally swap pads frequently. Normally the 1144s would stay on the car, but at Xmas I had a premonition that for some reason there might be a 7 month wait between track events. So I stuck a set of cheaper pads on to save using up the 1144s on trips 'to buy essentials officer'. Fresh 1144s went on the front (the second set of the ones you kindly supplied) and I'm reusing the rears. They'll stay on the car until they wear out which at this rate won't be long. I'm going to need more of them very soon.... hint hintChrisHolmes wrote: ↑Mon Jun 15, 2020 1:16 pmAre you just fitting the 1144 Pads for track and then running standard pads the rest of the time? I wouldn’t recommend this as the disc surface becomes “conditioned” during the bedding in process of the new pads. Swapping already bedded in, conditioned, pads for other compound bedded in pads may not provide you with optimal braking performance.New Duke wrote: ↑Mon Jun 15, 2020 10:51 amPut my track wheels and 1144 pads back on yesterday ready for Snetterton on Wednesday. I found the rear calipers were seized and spent a while trying to remove them, at one point even trying a club hammer to (gently) knock them free.
- ChrisHolmes (Mon Jun 15, 2020 10:15 pm)
- Vj4sothername
- Has thanked: 1478 times
- Been thanked: 343 times
This makes me tempted to pull the spacers off my civic and see if they fit.nightfire10 wrote:Started fitting the 20mm spacers, had to cut 10mm ish off the studs, done one side other tomorrow probably, liking how they fill the arch now.Sent from my VOG-L29 using Tapatalk
Both are 5x114.3 but I think hub hole has to be wider for the RX8.
S1 - 231 - brilliant black
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
- nightfire10
When torqueing up the spacers I tightened them to what seems more than the wheel torque but no click, it clicks tightening the wheel nuts?
- ChrisHolmes
What type of studs are in the spacers. Same design as the wheel studs with a rear flange or just screwed in from the front face if the latter then the torque is less.
I just reread your post and the above is blx and cannot apply to your scenario!
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- New Duke
Got carried away prepping for track day tomorrow. Wanted to mitigate the weight I've put on during the lockdown. Looking for what else I can easily take out.
- GreySilver Beast (Tue Jun 16, 2020 7:40 pm)
- nightfire10
Wheel nut torque 113mn?
- warpc0il
- Has thanked: 492 times
- Been thanked: 2013 times
- Contact:
The original Workshop Manual spec for the wheel nuts was 88-118 Nm but this was revised as part of Service Bulletin No: 02-002/04 to 147 Nm, for the 18" alloys, along with ensuring that there's no grease on the faces of the wheel or hub.
- nightfire10 (Wed Jun 17, 2020 1:18 pm)
- New Duke
Ordered a new set of carpet matts from Mazda. The price has more than doubled since I last bought some in 2017. Today it cost £45 plus VAT
- PaulAV
Think when I brought a set (12 years ago) they were around £50 maybe more. On a plus side, today I purchased both drive belts and 5 litres of fl22 for £70 from mazda (I believe the fl22 alone can be around £40)
- warpc0il
- Contact:
As with all car manufacturers, the retail parts prices are reviewed (every month for Mazda) based on stock levels and perceived demand.
Some of the larger dealer chains also buy-in products like mats from aftermarket sources, complete with Mazda branding, and sell for whatever they like.
- Nickp47
- Has thanked: 126 times
- Been thanked: 260 times
Sounds about right, I rang my local for a price on FL22 the other day, they quoted around £45 + VAT
