- ChrisHolmes
- Has thanked: 5596 times
- Been thanked: 2563 times
Are the pads an easy sliding fit into the calipers. Sometimes there is paint or a flashing burr from when the backings were made that requires grinding off. If your sliders are free but the pad is sticking then check to make sure your pistons are not seizing in their bores.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- shroom
- Has thanked: 57 times
- Been thanked: 473 times
Yeah I did take a bit off the pad but its amazing what a couple of months sitting around not being used does to stuff like that.ChrisHolmes wrote:Are the pads an easy sliding fit into the calipers. Sometimes there is paint or a flashing burr from when the backings were made that requires grinding off. If your sliders are free but the pad is sticking then check to make sure your pistons are not seizing in their bores.
- Has thanked: 340 times
- Been thanked: 46 times
Managed to release the nasty little nuts (supplied with my tyre pressure monitor system) that had corroded onto my tyre valves. That's not a good situation to be in if any of your tyres lose pressure, obviously.
Replaced them with the stainless steel ones I ordered recently. I will make sure I keep a suitable spanner in the car!
- V8 Power
- Has thanked: 234 times
- Been thanked: 487 times
That’s a great price, how did you get the discount?
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
MSD leads
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
- PaulAV
- Has thanked: 115 times
- Been thanked: 319 times
Forum discount with ebc, saved me £150 last year on a full set of pads and grooved disc's
- V8 Power
That’s excellent, I’ll give it a go
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
- mi60o0
- Has thanked: 93 times
- Been thanked: 322 times
Today I done something on my rex my wife told me I'm nuts and crazy and she won't drive it with the bench on the boot
She say I shall put sticker ultimate di*k on it not impressed Mrs
- These users thanked the author mi60o0 for the post (total 2):
- ChrisHolmes (Sat Feb 22, 2020 9:30 pm) • untakenname (Sun Feb 23, 2020 12:13 am)
BatRex 192 stock
- V8 Power
I have tried both the discount codes listed on here for EBC and neither are accepted, is there another one?
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
- ChrisHolmes
I do love your Mrs!
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- mrspiller
- Has thanked: 179 times
- Been thanked: 481 times
I had give them a ring , I spoke to Simon or e mailV8 Power wrote:I have tried both the discount codes listed on here for EBC and neither are accepted, is there another one?
Sales @ebcbrakesdirect .com they will give you the discount
The saving covered over a years membership
- Ranjan
- Has thanked: 70 times
- Been thanked: 854 times
Strange, it worked perfect for me on Thursday, used the second code Chris suggested and they took off more than the 15%
Ranjan.
Ranjan.
- V8 Power
Which code was that, I tried both on the benefits & discounts thread?
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
- Ranjan
Also, make sure you use the ebcbrakedirect dot com as there are two other EBC brake sites that may cause confusion.
Ranjan.
Ranjan.
- V8 Power
I was on the wrong site!
All good now
Thank you
Graham
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
- warpc0il
- Has thanked: 490 times
- Been thanked: 1999 times
- Contact:
- nightfire10
- Has thanked: 1190 times
- Been thanked: 552 times
After looking to stop the racing beat duel resonated decat smell i decided to go with a RRP 200cell cat, and rather than pay £499 i sold mine for £500 (scrap)with postage covered with no messing around,all he required after transfering the money was a photo after cutting the tail off the cat was a photo to show it was still full,happy days will be picking up the 200cell from the agm.
if anyone wants his link let me know
To do install sohn tank bracket made but still need to get time to install,caliper painting
- Goobie
- Has thanked: 39 times
- Been thanked: 361 times
- Contact:
Dam, that is good. Was it really that simple? Feel free to send me over the details.nightfire10 wrote: ↑Sun Feb 23, 2020 1:08 pmAfter looking to stop the racing beat duel resonated decat smell i decided to go with a RRP 200cell cat, and rather than pay £499 i sold mine for £500 (scrap)with postage covered with no messing around,all he required after transfering the money was a photo after cutting the tail off the cat was a photo to show it was still full,happy days will be picking up the 200cell from the agm.
- nightfire10 (Sun Feb 23, 2020 6:11 pm)
- sKenDread
- Has thanked: 227 times
- Been thanked: 168 times
- Contact:
New brakes fitted, checked tyre tread all round is good. Lubed steering wheel u joint and dropped another 7mm.
Oh and in the pissing rain. Only when I'm putting the last wheel back on, it fines up
Kia-ora!
RRP Performance Ignition Coil System MKII | RRP Mini Map | RRP COFS | Powerflow Twin Exhaust
Original engine 80k
- PaulAV
Had the opposite to those weather conditions last week Kenny, was changing the exhaust over (it has a split and was due an mot) worked on the car, got the old one off and it started to drizzle, went in for a brew, we had rain and hail, came out to fit spare and it was glorious sunshine.
Who's got a Hotline to the Deity In Charge, then?
- ChrisHolmes
Ready for next weekend I checked all fluids and loaded the track wheels & tyres, 2x20ltr Jerry Cans, crate of spare fluids, crate of wipes, cloths etc; spare new disc pads, tools, chocks, but no room for the trolley jack which is too flipping heavy to transport around anyway!
- Vj4sothername (Mon Feb 24, 2020 9:29 pm)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- Has thanked: 538 times
- Been thanked: 779 times
I don't want to overload you any more,but did you put your rivnut gun in? rob.
- ChrisHolmes
Surprisingly I did!
- goodeggbob (Mon Feb 24, 2020 9:36 pm)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- 13Black
- Has thanked: 533 times
- Been thanked: 814 times
- Contact:
Dave! Good to see you're still about and enjoying the car
I hope that yourself and the wife are keeping well
- Yorindesarin
- Been thanked: 375 times
Took a bit of time to properly inspect my spare set of callipers. Removed slide pins and such. Cleaned them up with brake cleaner and put everything back together. For some reason the drivers front calliper is still a tad sticky compared to the other very free moving slide pins. Going to guess theres a build up of old grease in the bores that needs properly cleaned out. Sadly don't have anything to do that with so I just put them back together for now. Also think I need new slide pins all round as well before I put them on the car.
Also side note, thats not a bottle of oil. I stole some brake cleaner from my mechanic and thats the only bottle that was kicking about at the time.
The Red 8:
Racing beat Revi, Tein street basis z coilovers, RRP Mk2 Coils (and one Mk3), Stock catback, Cruise Control (Zoom Zoom).
For whats pending... See here: viewtopic.php?f=104&t=81689
