Page 854 of 1181
Posted: Tue Oct 01, 2019 9:41 pm
by Neilparry
No rx8s at Spa today
But Mazda Was supporting a very nice red MPS 6
Posted: Tue Oct 01, 2019 9:43 pm
by Honkytonk
Was it running that fancy new range extender Wankel?!?!?!
BigPete has sorted me a bracket for first class tomorrow, thanks BigPete!
Posted: Wed Oct 02, 2019 5:20 pm
by v-rex
Got an Exedy clutch installed today by Luke MRS, and whilst we were doing that noticed the cat was on it's way out. So located and put on a new cat as well !!
Posted: Wed Oct 02, 2019 7:36 pm
by Madman0405
Started logging fuel to calculate MPG
Posted: Wed Oct 02, 2019 7:37 pm
by nightfire10
Wouldn't even bother with an 8 just enjoy it!
Posted: Wed Oct 02, 2019 7:42 pm
by Ollie
Tried giving the inside of the windscreen a clean to see if I could get rid of the annoying marks it had on it when it misted up.. Hopefully its worked! Shall find out tomorrow I imagine. Also dusted off everything... Just waiting for some alright weather to wash and hoover it out before it goes storage mode sometime soon for winter.
Im considering getting a dehumidifer for inside the car and probably a solar battery drip of some description but I have no clue what to get. (The cars going to be outside but hopefully under a shelter I'll be building soon!) Probably put a cover on it as well.. Any suggestions for a cabin dehumidifer and a solar charger?
by Bigblueknight3k
Mine is cheaper than my Subaru v1 wrx lol thats a bouns
Posted: Wed Oct 02, 2019 7:52 pm
by v-rex
Yorindesarin wrote: ↑Wed Oct 02, 2019 7:42 pm
I had the AA solar charger which plugs into your OBD2 port, and gave me decent few years of service. But make sure you test the one way diode regularly. Think mine shorted out and I noticed it actually started to discharge the battery when not in the sun !!
Posted: Wed Oct 02, 2019 7:55 pm
by v-rex
I did use the charger locked inside the car though. With a cover on I guess you want some sort of external charger ?
Posted: Wed Oct 02, 2019 7:57 pm
by Ollie
Yeah possibly something I could put on the roof of the structure I'm going to make for the car if possible would be ideal!
Just had a look at the AA charger on amazon, seems to come with the ability to attach it directly to the battery which I presume means the solar panel is useable outside of the car?
Posted: Wed Oct 02, 2019 9:53 pm
by phoenix11
Madman0405 wrote: ↑Wed Oct 02, 2019 7:36 pm
Why?
Take it easy = sh*t
Hammer it = sh*t
Posted: Wed Oct 02, 2019 10:48 pm
by Devon_Fourie
Madman0405 wrote:Started logging fuel to calculate MPG
So have I but not to try be good but just a conversation against my boss’s Porsche and ex 350z
This was just my reading between 2 partial fuel ups. Using the app Fuelly
Posted: Thu Oct 03, 2019 12:30 am
by johnbb99
Made myself an idiot's guide to dipstick levels:-
Shamelessly stolen from Dave’s post in
viewtopic.php?f=25&t=50814&p=1201466&hi ... 1#p1201466 (you may need to scroll up a touch)
Posted: Thu Oct 03, 2019 5:05 am
by nightfire10
More of what I haven't done! My samsung 7 conenected to my elm obd11 no prob but not my new one hawawi p30pro anyone found this?
Cheers Steve
Posted: Thu Oct 03, 2019 5:12 am
by Ollie
Going to have to try cleaning the inside of the windscreen again.. Still has some smears on it probably made from the first attempt at cleaning it.
Posted: Thu Oct 03, 2019 11:27 am
by v-rex
Yorindesarin wrote: ↑Wed Oct 02, 2019 7:57 pm
I think it can, but in my case I specifically got it as I could keep it locked in the car and connect via the OBD2 port. In your case you might be better suited with another one which is more weatherproof ? Am pretty sure the AA one is designed to be inside the car, either on the dashboard or stuck to the windscreen.
Posted: Thu Oct 03, 2019 11:32 am
by v-rex
nightfire10 wrote: ↑Thu Oct 03, 2019 5:05 am
Cheers Steve
When I switched phones my new one was playing up with my OBD2 device. It is some chinese elm thing which worked fine when I had my nexus 5, and seemed to work ok with my wife's samsung 9. I have a samsung a3. In the end I went to the bluetooth cache and cleaned it and now it all works fine with the Torque app. I suspect it has some old settings from my old phone or something.
Followed something like this below to do it.
https://help.elitehrv.com/article/135-c ... he-android
Posted: Thu Oct 03, 2019 4:59 pm
by Ollie
Inside my windscreen is definitely somewhat worse than before but also clears way faster... Think Ill give cleaning it another go tonight... First got to hoover the floor mats!
Posted: Thu Oct 03, 2019 5:36 pm
by warpc0il
Be careful with the hoover under the seats, this is the most common cause of problems with the airbag system, as they're connectors underneath that don't like being knocked about.
Posted: Thu Oct 03, 2019 6:17 pm
by Madman0405
phoenix11 wrote: ↑Wed Oct 02, 2019 9:53 pm
Why?
Take it easy = sh*t
Hammer it = sh*t
HAHA!
Thought i would see if doing oil filters and coolant change makes much of a difference.
Posted: Thu Oct 03, 2019 6:18 pm
by Ollie
Last I looked under the seats weren't too bad. I don't take many parcel shelf passengers.
So I should be alright just cleaning up the drivers and passengers footwell. But I'll keep an eye out if I do go under the seats a bit more.
Posted: Thu Oct 03, 2019 6:55 pm
by New Duke
Yorindesarin wrote: ↑Thu Oct 03, 2019 4:59 pm
Try four of these first before you go plugging in a solar thingy and leaving a powered dehumidifier in the car for long periods. Especially if you car lives outside (whether under a shelter or not). These bags can soak up loads if you place them in various places around the car and are easy to reset.
https://www.amazon.co.uk/dp/B00I3VKBJS/ ... LDbTTT3A4E
I use a powered dehumidifier and they're great, but it's a big one in the garage where my 8 sleeps. The same one as casey has and Warpc0il had.
I'm not sure what the climate is like up where you are. But if you think the floor mats might be at all damp/mouldy then before locking it up for winter it might be worth just binning the mats. A new set is only £20 from any dealer. Locking in any damp/mould will end in tears.
What did you use on inside of the windscreen? Any glass cleaner like Windolene or Autoglym Fast Glass should degrease it in one go. Applied to a dry microfibre cloth or kitchen towel (not applied direct to the windscreen) then followed up with a dry wipe. If it's still fogging up then you've got serious damp and shouldn't leave it closed over winter... or just moved around the grease on the first clean attempt.
Can't remember if you said you've already replaced the pollen filter? That may well help.
Definitely don't put a cover over the car unless it's
bone dry and sparkling clean first. And ensure it's a thick, fleece-lined and breathable, tethered cover. Should cost about £150-£200. Otherwise you'll do more harm than good and have an expensive headache to deal with come spring.
Apologies if you already knew all that.
Posted: Thu Oct 03, 2019 7:37 pm
by Ollie
New Duke wrote: ↑Thu Oct 03, 2019 6:55 pm
Cheers for the advice. I think I just managed to move the grease around and take some off last time I tried cleaning it! I used Maguiers Glass cleaner whatever its called, applied to a dry microfibre cloth and then dry wiped off. Haven't changed the pollen filter it was on my list of things to get done might do that before putting it away.
I think my mats are free from damp. And Ill grab some of those dehumidifier bags tomorrow. The climates cold and wet like most of the UK, but more extreme on the coldness!
I may skip the cover since the shelter Ill be building will hopefully be enough to keep the worst of the weather off!
My biggest worry aside from obvious condensation/damp inside the car is the battery going flat since its not that old of a battery... Hence the want of a solar trickle charger.
Posted: Thu Oct 03, 2019 10:16 pm
by warpc0il
I too have had a solar charger go bad and actually flatten the battery beyond recovery.
viewtopic.php?p=1223550#p1223550
Posted: Fri Oct 04, 2019 8:05 am
by Ollie
Yeah I think I remember reading that Dave. But if it's not a solar charger I'm not sure what else to do really.
