Page 629 of 1181
Posted: Mon Jun 12, 2017 5:21 pm
by Brooksyvon89
PeteH wrote:Brooksyvon89 wrote:
That's my baby! (I designed a lot of the suspension for it, so if you don't like the way it rides and handles it's my fault
It's a monster! Ploughs through and over anything!!!
Posted: Mon Jun 12, 2017 5:27 pm
by PeteH
(I know it's off topic, but hey, I may never get the opportunity to post this picture again)
This is a secret night time drive of a pre-production Freelander, before the car was released to the public
Posted: Mon Jun 12, 2017 8:51 pm
by New Duke
PeteH wrote:(I know it's off topic, but hey, I may never get the opportunity to post this picture again)
That's very cool Pete, wish my dad could have seen that.
We had one of the first batch of Freelanders, and many fun holidays conquering anything the alps would throw at it. IMO it was the only all-terrain vehicle in its class that was truly off-road capable. Ours sadly had the dreaded 1.8 Rover K Series engine though, which had to be rebuilt twice.
At the same time my parents also had an early MGF
also with the K Series engine (which my mum has just begrudgingly decided to scrap after slowly losing a battle of 20 years of various engine issues). At 100k miles that was on it's
third engine!
Such a shame as everything else about those cars, to me at least, was perfect and defined so much of my childhood.
So I always
at the RENESIS' poor reputation for reliability... it's all relative and there are much worse out there!
(Sorry for the off-topic
Posted: Mon Jun 12, 2017 10:00 pm
by northerner69
went de cat!
Posted: Tue Jun 13, 2017 12:43 pm
by untakenname
warpc0il wrote:Opening the rear light units isn't that much of a problem, as a few people have found, using a fine saw blade in an oscillating multi-tool or a Dremal.
The challenge is to create an edge that can be glued back together without the joint showing.
There are plenty of used ones around to practice on.
A decent thin cutting disc I found to be best, went through a couple before I got the knack.
I started a thread about opening the lights a while back, will update it over lunch with the end results.
Edit: uploaded here
http://www.rx8ownersclub.co.uk/forum/vi ... 6#p1094092
Posted: Fri Jun 16, 2017 10:41 am
by Harrymonk
I know this sort of thing is marmite, but after trying films and fly-eye paper decided a light tint was in order as its the look I like, with upgraded bulbs there is sufficient light coming through.
Tint Applied:
Laquered, bit of orange peel:
Sanded and rubbing compound with some elbow grease:
Just enough of a tint for me:
Hoping the weather holds to get them on the car after making some upgraded foam/rubber seals..
Posted: Fri Jun 16, 2017 12:15 pm
by PaulAV
Swapped out APV motor, had constant cel error code 2008, was a bit of a pain to swap, but now have intermittent cel 2008, so I have an improvement but not as good as I would of wished for, apv itself turned without issue and magnet was at the 1 o'clock position, so think there may be a damaged pin or something or the magnet is going weak.
Posted: Fri Jun 16, 2017 12:28 pm
by wgimenes
Created a new mod: sun visor extensions
Posted: Fri Jun 16, 2017 10:41 pm
by thomo8568
Gave it a wash and test fitted my oil cooler grills.
I've already covered the oil coolers with mesh but didn't like that they didn't match. So cut up an old center grill. Not bad for a first attempt.
Posted: Fri Jun 16, 2017 10:52 pm
by ChrisHolmes
wgimenes wrote:Created a new mod: sun visor extensions
Wow! That is incredible. Wozza will be quaking in his boots if he sees this!
Are you taking orders?
Posted: Fri Jun 16, 2017 10:57 pm
by wgimenes
LOL, Chris.
My first attempt.
The idea needs refining :-)
Posted: Fri Jun 16, 2017 11:16 pm
by Brooksyvon89
Did a full wash, decontamination, polish and resin coating:
Posted: Fri Jun 16, 2017 11:18 pm
by brix79
Dayum, that looks like it's made of mirror!
Need to get those shrouds back to black though.
Posted: Fri Jun 16, 2017 11:26 pm
by PeteH
Brooksyvon89 wrote:Did a full wash, decontamination, polish and resin coating
It does look amazing.
(But, so does your drive! #Filter....
Posted: Sat Jun 17, 2017 5:44 pm
by Brooksyvon89
PeteH wrote:Brooksyvon89 wrote:Did a full wash, decontamination, polish and resin coating
I just happen to have a picture perfect front-of-the-house...
Busted lol
It is super clean though
Posted: Sat Jun 17, 2017 7:41 pm
by Scartlead
Brooksyvon89 wrote:Did a full wash, decontamination, polish and resin coating:IMG_0369.JPG
Looks really well, though do I sniff a little photoshop effetcs ?
Posted: Sat Jun 17, 2017 9:09 pm
by exiled--viking
This Is Only A Mock Up Of the Defuser Fitting......So Made the Mounting brackets today and did a trial Run Of the Rear Defuser still a long way to go but I think there going to be enough rear down force on the lower wings the defuser is not just for show and when completed will be finished of in a Carbon effect hydro Dip....
Also went with the double staggered wing as there is enough air flow for this modding the rear bumper was 4 X 3/4 slots need to be cut but hardly noticeable....!
Thank for taking the time to Look....!
[url=
http://s32.photobucket.com/user/Tonyspi ... .jpeg.html
As you can see the Defuser is mostly under the rear bumper & not protruding or extending the length of the body ...Also there no need to have it under the exhausts as they have there own air scoops
[url=
mock up brackets made but some adjustments to be done, all the aluminium to be coated black nuts and bolts also need to be done in Orange .... this is only a Mock up the finished effect will look a little different .
[url=
Posted: Sun Jun 18, 2017 4:56 pm
by gareth_1912
Not done anything today but ordered tein springs and drilled and grooved mtec discs and pads should be here Thursday
Got a nice picture at castle Combe yesterday whilst I was at the rally school
Posted: Sun Jun 18, 2017 5:41 pm
by Dove66
thomo8568 wrote:Gave it a wash and test fitted my oil cooler grills.
I've already covered the oil coolers with mesh but didn't like that they didn't match. So cut up an old center grill. Not bad for a first attempt.20170616_202937.jpg
They look really good. I thought it looked like the centre grille before I read the text. I wonder if anyone else has done it that way.
Posted: Sun Jun 18, 2017 5:43 pm
by Dove66
Harrymonk wrote:I know this sort of thing is marmite, but after trying films and fly-eye paper decided a light tint was in order as its the look I like, with upgraded bulbs there is sufficient light coming through.
Tint Applied:
They look great. Mine are Covex covered but these look oem.
Posted: Sun Jun 18, 2017 9:24 pm
by Reloy
Removed all the seagull crap from the roof, bonnet, boot, windows and both sides of the car. Never ever park your car overnight on Aberystwyth seafront. Great night though so it was worth it :-)
Sent from my VFD 600 using Tapatalk
Posted: Sun Jun 18, 2017 9:38 pm
by Salesy
After 6 months in storage i decided it was due a deep clean ready for some summer use.
Full snow foam x 2, Meguires compound, Megs clear coat polish and finally a coat of carnauba wax. Silicone all black plastics and clean glass inside and out.
Sweating my nuts off for 4 hrs.
https://www.flickr.com/photos/134115384@N07/35350484906
https://www.flickr.com/photos/134115384@N07/35350483166
https://www.flickr.com/photos/134115384@N07/35223209692
Posted: Mon Jun 19, 2017 7:21 am
by Nintendologist
Links don't seem to work?
Posted: Mon Jun 19, 2017 9:04 am
by Dr. FrankenRex
Mmm... Brakings...
Posted: Mon Jun 19, 2017 9:33 am
by Harrymonk
Dove66 wrote:Harrymonk wrote:I know this sort of thing is marmite, but after trying films and fly-eye paper decided a light tint was in order as its the look I like, with upgraded bulbs there is sufficient light coming through.
Thanks, I did try the covex style film but just couldn't get it to sit right...
They do look factory, which is what I was after, less chance of being stopped if it looks manufacturer, but also enough red is visible, we will see.
