WaferShaf
Has thanked: 20 times
Been thanked: 27 times
Post by WaferShaf » Thu May 04, 2017 8:42 pm
I haven't reached the stage that the instructions will be needed yet(!!), but swapped the 150w Alpine for a 300w InPhase with smaller dimensions. Made a few little cuts to the storage box to 'help' it fit and it's held nicely in place. Also added a preliminary port in the front face which I'll sort out after a test of the sub :)
These users thanked the author WaferShaf for the post:
pstables (Fri May 05, 2017 11:03 am)
- Shaf - :mrgreen:
RX-8 PZ ProDrive Edition [008/800] (lowered 15mm, Bilstein dampers, Eibach springs), 2006 Galaxy Grey
Completed: D585-R CoilsNGK Iridium plugs & Magnecor leadsN3R3 starterSohn adapterCruise controlCalliper refurbBonnet liftersClimair deflectorsCabin LEDs2Din Metra kit
To do/Wish List: ●Mini map●20mm spacers F&R●Discs●DVR F&R●Body kit●Respray??
Has thanked: 457 times
Been thanked: 1830 times
Post by warpc0il » Thu May 04, 2017 8:48 pm
Getting there Shaf :thumright:
WaferShaf
Re: RE: Re: What have you done to your RX-8 today????
Post by WaferShaf » Thu May 04, 2017 9:17 pm
warpc0il wrote:Getting there Shaf :thumright:
Thanks man, looking forward to some bass!
I'll send a 'thank you' thumbs up thing for your first post when I get on the laptop. Don't seem able to do it in Tapatalk(?).
- Shaf - :mrgreen:
pstables
Has thanked: 6 times
Post by pstables » Fri May 05, 2017 11:05 am
WaferShaf wrote:I haven't reached the stage that the instructions will be needed yet(!!), but swapped the 150w Alpine for a 300w InPhase with smaller dimensions. Made a few little cuts to the storage box to 'help' it fit and it's held nicely in place. Also added a preliminary port in the front face which I'll sort out after a test of the sub :)
That's pretty neat, I had an active sub in the old Rex but never got round to refitting in the new one, it also took up a good chunk of boot space.
Anyone have the subwoofer wiring to hand, IIRC I spliced into the speaker outputs last time...
Paul
Winning Blue 230 from 1/3/2004-16/5/2008
Crystal White R3 from 1/11/2013 (Toy)
Skoda Octavia vRS (Family car)
WaferShaf
Post by WaferShaf » Fri May 05, 2017 11:45 am
I like this option as it isn't taking up any cabin or boot space :)
I don't have a diagram, but if I've got it all sorted in my head, you'll have a fused power (red or yellow), ground (black), remote (blue), all going to sub, then 2 pairs speaker wire (left & right) taken from the rear parcel shelf speakers to the hi-low converter and then a pair of RCA's from the converter to the sub, think that's all?
- Shaf - :mrgreen:
Post by warpc0il » Fri May 05, 2017 12:50 pm
I took power from back of the cigarette lighter socket, as I didn't want to overload the supply to the rear amps.
Actually run a two core cable, with the 2nd connected from the cigarette lighter light to a couple of tiny blue leds mounted just inside the hole for the sub.
Just for added bling
Sent from my GT-I9195 using Tapatalk
WaferShaf
Post by WaferShaf » Fri May 05, 2017 12:58 pm
warpc0il wrote:I took power from back of the cigarette lighter socket, as I didn't want to overload the supply to the rear amps.
I'll go straight to the battery for power I think..
For your feeds from the 6x9's, do you splice before or after the amp to add the HI-low converter??
- Shaf - :mrgreen:
Post by warpc0il » Fri May 05, 2017 4:04 pm
speakers outputs of the amp
WaferShaf (Fri May 05, 2017 4:23 pm)
WaferShaf
Post by WaferShaf » Fri May 05, 2017 4:44 pm
warpc0il wrote:speakers outputs of the amp
So the same 'amped up' signal that the car speakers receive goes to the converter and then the amp?
Why not just use the signal before the amp, and then not need a converter or have I got that all arse over tit?!
- Shaf - :mrgreen:
Post by warpc0il » Fri May 05, 2017 4:50 pm
The signal between the head unit and the amp is Bose proprietary and impedance matched, it's not an RCA output, unlike most off-the shelf stuff. T'ing in at this point would upset the system.
The converter box is designed to T-in at the back of the speakers and accepts speaker-level input without adding (significant) load.
WaferShaf
Post by WaferShaf » Fri May 05, 2017 5:00 pm
warpc0il wrote:The signal between the head unit and the amp is Bose proprietary and impedance matched, it's not an RCA output, unlike most off-the shelf stuff. T'ing in at this point would upset the system.
Nice Image Image
I knew there was a good reason, but I can only retain so much of the info I read when looking into this stuff! Image
- Shaf - :mrgreen:
Sonic KaBoomii
Post by Sonic KaBoomii » Fri May 05, 2017 11:22 pm
John (Cabriolet), Leon & I got the cars dirty at Oulton Park Rally/Drift circuit
Last edited by Sonic KaBoomii on Sat May 06, 2017 4:08 pm, edited 1 time in total.
These users thanked the author Sonic KaBoomii for the post:
Nintendologist (Sat May 06, 2017 8:39 am)
Rick - Follow my trackday misadventures at Sonic KaBoom trackday diaries
johnbb99
Has thanked: 340 times
Been thanked: 45 times
Post by johnbb99 » Sat May 06, 2017 12:44 am
Eeeewwwwwww!
Nintendologist
Colour: Phantom Blue
Has thanked: 64 times
Been thanked: 39 times
Post by Nintendologist » Sat May 06, 2017 8:41 am
ChrisHolmes wrote:Finished fitting the Lambo hinges...
Chris - can I ask - how easy is it for a man of your vertical disposition to now get into your car? :D
Nov 2007 - May 2010: Galaxy Grey PZ (Parking sensors, Cruise control)
October 2015 - : Phantom Blue Evolve (D585 coils/Magnecor leads, Galtress 'Halo' LED headlights, resprayed alloys, hoop spoiler, Lockwood grilles all round, dropped numberplate, 13 Black ECU mini map, custom Nexus install, 20mm H&R spacers, Cobrasport cat back exhaust)
Nintendologist
Post by Nintendologist » Sat May 06, 2017 8:43 am
binghamf6 wrote:Here is the boot lid fitted to the car.
I like that contrasted black on silver spoiler, Shane :thumleft:
These users thanked the author Nintendologist for the post:
binghamf6 (Sat May 06, 2017 1:42 pm)
Post by warpc0il » Sat May 06, 2017 10:48 am
Sonic KaBoomii wrote:John (Cabriolet), Leon & I got the cars dirty at Oulton Park
But you're meant to drive around the track, not just around the dusty carpark #-o
nightfire10
Has thanked: 1096 times
Been thanked: 501 times
Post by nightfire10 » Sat May 06, 2017 1:22 pm
:rofl: :race: Tried my lidle oil pump out on sean moore's car works very well just don't do it whilst oil is hot lol curls pipe up ,lucky it's long enough to cut back the curly wurlys
Has thanked: 5273 times
Been thanked: 2399 times
Post by ChrisHolmes » Sat May 06, 2017 4:02 pm
Simples, the door opens to the normal angle or you can push it upwards any time before that.
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Neilparry
Has thanked: 28 times
Been thanked: 282 times
Post by Neilparry » Sat May 06, 2017 6:53 pm
Been busy this week painted the rear bumper and rear spoiler refitted the bumper made a template and then fitted the rear spoiler washed and polished and loving the look of the spoiler.
The 8.5mm magnecor leads came Friday from Ben at RRevs so went about fitting the new NKG plugs leads and fitting my D585's coils after fabricating a mounting bracket copying of mrspillers original ones.
So a very productive week.
Sold my z3 on Monday so I've freed up an insurance policy so it's taxed and insured for me to take to get the suspension alignment done. I'm like a little kid in a sweetshop Image
:wash:
Goobie
Has thanked: 34 times
Been thanked: 311 times
Post by Goobie » Sat May 06, 2017 8:37 pm
Started stripping most of my interior...
wgimenes
Has thanked: 118 times
Been thanked: 82 times
Post by wgimenes » Sat May 06, 2017 9:15 pm
New rear discs and pads, near side rear spring and drop link courtesy of Josh, JB and Lewis @ LC Rotary. Thanks for the laughs and great service.
Got home, put the Cataclean in the tank with just below 1/4 tank, drove down to Guildford in 3rd gear running between 7K and 8K. Filled up and went for a drive down to Churt. Dinner and nice drive back via the Surrey Downs.
What a great day.
Chris the Sheep
Has thanked: 39 times
Post by Chris the Sheep » Sat May 06, 2017 9:20 pm
I like that spoiler Neil, reminds me of the one on the older Honda Accord Type R.
Chris
Racing Brake 4 Pot Calipers | Slotted Front/Rear Discs | Braided Brake Lines | D585 Coils | 18in Stuttgart Alloys + Bridgestone Blizzak Winter Tyres | R3 Alloys + Bridgestone RE050A Tyres | Racing Beat Braided Cooler Hoses | Tinted Windows
Neilparry
Post by Neilparry » Sat May 06, 2017 9:35 pm
Thanks Chris it's a integra typeR dc2 spoiler. A bargain off eBay new replica from Ireland £29 delivered
I thought it suited the shape of the 8 and it is Japanese after all. Good fit too
:wash:
gareth_1912
Forum Guest
Forum Guest
Post by gareth_1912 » Tue May 09, 2017 11:06 pm
Today I started with my first premix
tmk
RX-8: Import
Has thanked: 11 times
Been thanked: 84 times
Post by tmk » Wed May 10, 2017 3:08 pm
finally got it back.. after 5 months!
These users thanked the author tmk for the post:
Nintendologist (Sat May 27, 2017 7:36 am)
RX-8 (2011/PearlWhite) RE Amemiya Redom AType2.0 ECU+Super Intake Box+SportsCat,RMagic TunedMuffler TitanCut,5.125 Final,Tein MonoSport w/EDFC,WedsSport SA55mMGM 18x9.0J,Neova AD08R 245/40/R18,Dixcel SD+IDI GT2 brakes,AutoExe MemberBraceSet, Bride GIAS Carbon,HPI 4pt,MOMO,TRUST InfoTouch+LEG83005,YupiteruGWR53sd,Carrozzeria http://www.rx8ownersclub.co.uk/forum/vi ... 04&t=55428
Return to “RX-8 Discussion”
