Phil Bate
Has thanked: 36 times
Been thanked: 169 times
Post by Phil Bate » Tue May 02, 2017 5:01 pm
I find rotating the coils on the mounting plate makes for a neater installation:
nightfire10
Has thanked: 1106 times
Been thanked: 503 times
Post by nightfire10 » Tue May 02, 2017 6:05 pm
Sonic KaBoomii wrote::lol:
Those coils were a bloody nightmare. I need to try and find some pics now I'm sat infront of a proper computer and not trying to do it on my phone; I've got one adapter plug hanging infront of the engine hoist eye, one stuck under it, and the other two jammed in under the elephant trunk
http://www.rx8ownersclub.co.uk/forum/vi ... ls#p717597
Sonic KaBoomii
Post by Sonic KaBoomii » Tue May 02, 2017 6:55 pm
Phil Bate wrote:I find rotating the coils on the mounting plate makes for a neater installation:
[attachment=0]WP_20150326_00_08_13_Pro.jpg[/attachment
That's nice. I need to try that!
Mine look like the ones in the link above (at least)
I took attach to engine ground a bit literally and stuck it on the alternator hinge bolt. Don't suppose it'll do any harm
Rick - Follow my trackday misadventures at Sonic KaBoom trackday diaries
Has thanked: 526 times
Been thanked: 808 times
Post by 13Black » Tue May 02, 2017 7:22 pm
Don't the Revs kits say attach to battery negative?
Might not do any harm, but can't beat straight to battery.
Mark R3
Post by Mark R3 » Tue May 02, 2017 8:23 pm
Stuck a more appropriate plate on :)
These users thanked the author Mark R3 for the post (total 2):
wgimenes (Tue May 02, 2017 8:24 pm) • Nintendologist (Sat May 06, 2017 8:36 am)
binghamf6
Been thanked: 25 times
Post by binghamf6 » Tue May 02, 2017 10:06 pm
Here is the boot lid fitted to the car.
Shane..
HID's + LED'S , Custom Gauge Pod , Piano Black Center Console , Later Interior , Bonnet Struts , Catch Tank
Poly Bushed Front End , Meister R Zeta S coil overs , Braided brake lines , Sohn And 2T Tank
RE-Amemiya short shifter, Show 'N' Go Front No. Plate , R3 Style starter motor.
Racing Beat Silenced de-cat and Rev 8 Cat back , Lambo Doors
Rebuilt and Ported at Hayward rotary
Phil Bate
Post by Phil Bate » Wed May 03, 2017 12:00 am
13Black wrote:Might not do any harm, but can't beat straight to battery.
Real world differences are probably immeasurable, but grounding to the engine block as close to the spark plugs as possible is technically best. I ground mine to the knock sensor bolt.
In fact, just to be over the top, I split the ground cable into front and rear and terminated on each housing accordingly. But I'm weird like that :roll:
Has thanked: 266 times
Been thanked: 582 times
Post by Dr. FrankenRex » Wed May 03, 2017 8:46 am
MOT at 12 today... :S
V8 Power
Has thanked: 193 times
Been thanked: 414 times
Post by V8 Power » Wed May 03, 2017 9:08 am
Good luck
Dr. FrankenRex (Wed May 03, 2017 10:08 am)
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
RRP Coils MSD leads
johnbb99
Has thanked: 340 times
Been thanked: 46 times
Post by johnbb99 » Wed May 03, 2017 10:07 am
Phil
Once you have a connection to car metalwork, as you say the differences will be infintesimal, but making two connections will decrease the chance of a poor connection. So; not so weird, I'd say. :)
(Hmmm, thinks: I wonder if that 'one and a spare' attitude is adopted by the military and aerospace industries...)
Post by 13Black » Wed May 03, 2017 10:12 am
With light aircraft you often run two magnetos (simple mechanical ignition systems) so I wouldn't be surprised. D1170 ignition kit anyone?
Ainmhidh
Has thanked: 467 times
Been thanked: 390 times
Post by Ainmhidh » Wed May 03, 2017 10:17 am
johnbb99 wrote: ...
There are a number of military aircraft where the critical systems have triple or even quadruple redundancy - if you have 2 sensors reading the same and 1 reading differently then the system ignores the 1. With 4 it goes with the matching 3 or if 2 fail they are unlikely to fail to the same value as each other so it goes with the 2 that do match. At least, that's the theory!
Phil Bate
Post by Phil Bate » Wed May 03, 2017 10:53 am
Rather than redundancy, my splitting the grounds is more about giving each rotor-pair of coils the most direct connection to the spark plug. Apart from at the ring connector(s) the grounds are otherwise electrically separate, so if you were looking to reduce the chance of failure you would probably want to cross-bond the ground terminals at the coil end too. That however, would be bordering ridiculous :)
13Black wrote:D1170 ignition kit anyone?
:-k :idea: :)
Azimuth
Has thanked: 75 times
Been thanked: 19 times
Post by Azimuth » Wed May 03, 2017 11:34 am
Ainmhidh wrote:
johnbb99 wrote: ...
There are a number of military aircraft where the critical systems have triple or even quadruple redundancy!
I recorded big chunks of the audio manual for the EH-101. I got so sick of the words Duplex and Redundancy!
ediit - oops it wasn't duplex but a far sillier sounding word. Which I've now forgotten, or wiped from my memory.
Phil Bate
Post by Phil Bate » Wed May 03, 2017 12:00 pm
These users thanked the author Phil Bate for the post (total 2):
johnbb99 (Wed May 03, 2017 1:29 pm) • Azimuth (Wed May 03, 2017 6:57 pm)
Post by Dr. FrankenRex » Wed May 03, 2017 1:48 pm
She passed with flying colours! Only advisory was the front brake pads, which'll be going when the new calipers go on anyways 8)
These users thanked the author Dr. FrankenRex for the post (total 4):
wgimenes (Wed May 03, 2017 1:49 pm) • Wozza (Wed May 03, 2017 4:01 pm) • New Duke (Wed May 03, 2017 5:29 pm) • Nintendologist (Sat May 06, 2017 8:38 am)
WaferShaf
Has thanked: 20 times
Been thanked: 27 times
Post by WaferShaf » Wed May 03, 2017 7:45 pm
I went to check if my newly purchased Alpine underseat sub would fit.. under seat..
..It would not
- Shaf - :mrgreen:
RX-8 PZ ProDrive Edition [008/800] (lowered 15mm, Bilstein dampers, Eibach springs), 2006 Galaxy Grey
Completed: D585-R CoilsNGK Iridium plugs & Magnecor leadsN3R3 starterSohn adapterCruise controlCalliper refurbBonnet liftersClimair deflectorsCabin LEDs2Din Metra kit
To do/Wish List: ●Mini map●20mm spacers F&R●Discs●DVR F&R●Body kit●Respray??
Has thanked: 457 times
Been thanked: 1839 times
Post by warpc0il » Wed May 03, 2017 9:46 pm
I have my "underseat" sub neatly installed in the ski hatch.
nightfire10
Post by nightfire10 » Wed May 03, 2017 9:52 pm
warpc0il wrote:I have my "underseat" sub neatly installed in the ski hatch.
Neat job
WaferShaf
Re: RE: Re: What have you done to your RX-8 today????
Post by WaferShaf » Thu May 04, 2017 12:14 am
Yeah I think I saw your install in a related thread, it looks awesome. I think I'm gonna copy the sh*t outta that!
I even checked but the alpine doesn't fit and also has the port facing the wrong way. Gonna see if I can return it and hunt for whatever it was you used! Did it fit in the enclosed ski hatch box or did you have to open the back?
How does it sound in the cabin? Do you get much rattle vibrations from the plastic housing of the ski hatch?
- Shaf - :mrgreen:
Post by warpc0il » Thu May 04, 2017 9:30 am
Mine's a Ripspeed PSR-135A, which I don't think they make any more.
They do come up on ebay and Gumtree, like this one
https://www.gumtree.com/p/in-car-audio- ... 1214951502
The first one I bought was flaky having been left in a damp car but I only paid a tenner for it, with the complete loom.
The second I got for 99p plus a fiver postage, as it didn't come with the loom, though the unit was mint.
Somewhere along the line I picked up another one complete for couple of quid off Gumtree. Mint looking but not working.
The main issue with used ones is the jack socket for the remote control wire, which can get knocked or pulled sideways, so the contacts don't.
The socket is pcb mounted a very awkward to replace. I was going to resurrect both the spare units with cable-mounted sockets on short tails wired to the board, reinforced with some strain relief. The idea being to keep one as a spare and sell on the other. However, it's yet another job on my todo list.
The main reason i chose these units is that they have RCA and speaker-level inputs. Most subs only have RCA and there's no output on the OEM head unit. The speaker-level input isn't that great either as Bose used 2ohm speakers (rather than the usual 4 or 8ohm) so the impedance doesn't match.
I ended-up with an RCA adapter box with adjustable inputs.
just don't bother trying to follow the instructions
Regarding the sub the, width was perfect making it a snug fit, just added some foam behind to hold it tight to the front of the box. Nothing rattles though the whole rear seat pounds if I really turn the volume up. The sub has it's own volume control, which effectively goes from "a bit richer", thru "a pounding bassline" up to "WFT!"
WaferShaf (Fri May 05, 2017 12:53 pm)
Been thanked: 786 times
Post by PeteH » Thu May 04, 2017 11:22 am
Those instructions are priceless! :lol: :lol: :lol:
WaferShaf
Post by WaferShaf » Thu May 04, 2017 12:10 pm
Haha thanks bud, yeah the instructions are a thing of beauty!
- Shaf - :mrgreen:
Has thanked: 833 times
Been thanked: 854 times
Post by Shagrington » Thu May 04, 2017 6:28 pm
:scratch: I don't get it - all the instructions I have ever read for anything electrical I've ever bought make as much sense to me. :crazy: :-s
wgimenes
Has thanked: 118 times
Been thanked: 82 times
Post by wgimenes » Thu May 04, 2017 6:31 pm
LOL Dave. Well done on translating those instructions from (what it seems to be) Klingon to English ;-)
Return to “RX-8 Discussion”
