Metelyk
Has thanked: 55 times
Been thanked: 188 times
Post by Metelyk » Sat Apr 22, 2017 12:52 pm
WaferShaf wrote:Just watching the gadget show.. couple of RX8s on it!
First one was a remote controlled car that they were going to put in a blender!
And then they were testing cameras at a drift event at Santa Pod!
Drift car is Essex Rotary's. Aston is your man there for servicing your RX8. Top place!
Has thanked: 5273 times
Been thanked: 2399 times
Post by ChrisHolmes » Sat Apr 22, 2017 2:41 pm
I had my alloys fully stripped and painted c18 months ago and the corrosion is bubbling up again. Apparently it's to do with the way alloy seems to keep some of the corrosion stuff in the surface and you can never truly remove it all. I told the block that was rubbish and then got the gravel may have chipped the back edge of the spoke and let moisture in! Either way it's a no claim situation but as I have kerbed them a couple if times anyway it's a bit academic!
johnbb99 (Sat Apr 22, 2017 4:16 pm)
Bridge Ported 231
MazdaSpeed skirts
Short shifter
johnbb99
Has thanked: 340 times
Been thanked: 45 times
Post by johnbb99 » Sat Apr 22, 2017 9:10 pm
Did they refurb the whole rim or just the outside?
They didn't do the inside part [that's 'around' the hub I suppose you might say] just what you normally notice. But it''s the bit they did do that I'm disappointed about.
wgimenes
Has thanked: 118 times
Been thanked: 82 times
Post by wgimenes » Sat Apr 22, 2017 10:43 pm
Reloy, which discs are those?
*if you don't mind sharing
BTW, nice meeting you both at the AGM.
Reloy
Has thanked: 139 times
Been thanked: 217 times
Post by Reloy » Sun Apr 23, 2017 8:43 am
They're Evora from Brake Depot, and as was mentioned earlier by Dan, bought for the look of it more than anything else :D and they're fairly reasonably priced, well I think so.
These users thanked the author Reloy for the post (total 2):
wgimenes (Sun Apr 23, 2017 11:26 am) • Dr. FrankenRex (Thu Apr 27, 2017 2:05 pm)
Rex II
Rhino Rack
Rex I (gone but not forgotten)
Rotary Revs Rebuild, Oil Temp/Pressure Guages, Uprated Starter, K&N air filter, Eibach Pro Kit Springs, Bilstein B8 Shocks, RR D585 Coils, Magnecor Leads, Aero Kit
Ashley1989
Post by Ashley1989 » Sun Apr 23, 2017 10:08 am
Kicked it. Piece of #%*#
These users thanked the author Ashley1989 for the post:
kopite72 (Sun Apr 23, 2017 12:40 pm)
Slightly crusty 2004 Velocity Red purchased on 15th April 2017.
Planned work - Sills repaired both sides, D585 coils, Magnecor Leads, NGK Spark Plugs, Bosh Battery, Uprated Starter Motor, New Discs and Pads all to be fitted!
Anyone want to buy a slightly used, 27 year old kidney to fund all of this??!!!!
Has thanked: 457 times
Been thanked: 1830 times
Post by warpc0il » Sun Apr 23, 2017 12:33 pm
Domestic abuse [-X
Sent from my GT-I9195 using Tapatalk
exiled--viking
Has thanked: 180 times
Been thanked: 324 times
Post by exiled--viking » Sun Apr 23, 2017 3:27 pm
^^ DO this on a regular basis ;) pedo abuse on an 11 year old RX~8
WAS THE WINNER OF THE 2015 EUROPEAN ROTOR STOCK BEST RX~8 in Show ( Won me 40 trophy"s the Beast is Now Sold A New Beast To Be Built SOON :banghead: ) new car MX5 Now Called the SHARK 8)
joney
Has thanked: 23 times
Been thanked: 54 times
Post by joney » Mon Apr 24, 2017 6:27 pm
Just given her some polyurethane filled engine mounts, thanks to Andy ment I could do all the filling curing and painting last week
If its not broke I'm sure I can find a reason to take it apart :thumright:
To Do: ?
Want:Ms kit
johnbb99
Post by johnbb99 » Mon Apr 24, 2017 9:35 pm
This piece of metal is bolted over the rear offside lamp cluster, behind the boot trim.
Should I have a corresponding one on the nearside, too?
Thanks.
Been thanked: 786 times
Post by PeteH » Mon Apr 24, 2017 9:52 pm
Nope. Apparently it's a theft prevention measure, to stop access to the boot opening mechanism.
johnbb99 (Tue Apr 25, 2017 10:06 pm)
Wozza
RX-8: Nemesis
Colour: Stormy Blue
Has thanked: 67 times
Been thanked: 48 times
Post by Wozza » Mon Apr 24, 2017 9:56 pm
:whathesaid:
There to reinforce the lock/mechanism.
These users thanked the author Wozza for the post:
2007 Stormy Blue Nemisis
Standard apart from Recaro child seat :D and a few bits of Alcantara plus some other bits and bob's.
Iainp
Post by Iainp » Tue Apr 25, 2017 4:53 pm
Finally got the wheels in primer.
These users thanked the author Iainp for the post:
RRXX--88 (Wed Apr 26, 2017 10:09 am)
johnbb99
Post by johnbb99 » Tue Apr 25, 2017 10:13 pm
OIC. Thanks.
I can relax again... :)
RRXX--88
Forum Guest
Forum Guest
Post by RRXX--88 » Wed Apr 26, 2017 10:05 am
Over the weekend changed the rear brake discs (Pagid brand) and pads (Brembo). Also changed the rear coil springs (Sachs brand) as the offside rear had broken! The coils were awkward to say the least but a spring compressor helped in situ. At least it's done :)
GReddy magnetic drain plug
Shell Helix HX7 10W-40 engine oil
Castrol Power 1 Racing 2T premix
NGK Laser Iridium plugs, Magnecor blue 8mm Electrosports leads, Mazda N3H1-18-100C coils
Meyle front left and right anti roll bar drop link rods
Mazda FL22 long life engine coolant
Rear Pagid brake rotors and Brembo pads
Rear Sachs suspension coils
sKenDread
Has thanked: 226 times
Been thanked: 168 times
Post by sKenDread » Wed Apr 26, 2017 9:45 pm
ABS and traction control we stuck on this morning. Tried the reset procedure, nope... Didn't work.
Drove to work like a nanny. Asked a mate to tell if my brake lights were working... Nope neither were.
Drove home after work, changed the offside light, tested and yay. I'm happy
Sent from my Nexus 5X using Tapatalk
Kia-ora!
RRP Performance Ignition Coil System MKII | RRP Mini Map | RRP COFS | Powerflow Twin Exhaust
Original engine 80k
Azimuth
Has thanked: 75 times
Been thanked: 19 times
Post by Azimuth » Thu Apr 27, 2017 1:29 pm
Fixed a couple of stone chips with a Mazda touch-up kit. Hoping it looks better when it's dried!
Also did a ridiculous power drift up the road with the DSC off. Slightly overcooked it! DSC back on. :)
gareth_1912
Forum Guest
Forum Guest
Post by gareth_1912 » Fri Apr 28, 2017 9:19 pm
Image hi I'm new here only had my rx8 3 weeks today I refurbed my alloys and changed the colour to anthricite :)
johnbb99
Post by johnbb99 » Fri Apr 28, 2017 10:22 pm
Hi and welcome. Nice wheels!
Has thanked: 832 times
Been thanked: 853 times
Post by Shagrington » Fri Apr 28, 2017 10:34 pm
Hi and :welcome: gareth_1912. Silver definitely looks better with darker wheels. 8) Next thing you need is protective grilles for the oil coolers and radiator etc if you don't already have them (Lockwood's, Racing Beat or Zunsport do them and club members get a discount from all 3) and strakes. :thumright:
SeeJay
Has thanked: 172 times
Been thanked: 365 times
Post by SeeJay » Fri Apr 28, 2017 11:16 pm
By all means hold fire on them there strakes.. ;)
Post by warpc0il » Fri Apr 28, 2017 11:23 pm
Van Helsing wrote:By all means hold fire on them there stakes..
:twisted:
johnbb99
Post by johnbb99 » Fri Apr 28, 2017 11:31 pm
So is it considered a serious [potential] problem, that the oil coolers and radiators are unprotected, as standard?
Azimuth
Post by Azimuth » Sat Apr 29, 2017 12:35 am
johnbb99 wrote:So is it considered a serious [potential] problem, that the oil coolers and radiators are unprotected, as standard?
How lucky are you in general? ;)
johnbb99
Post by johnbb99 » Sat Apr 29, 2017 12:46 am
# I can walk under ladders#
No, not really. When I hit a pheasant - not that fast - it broke the bit that holds the fog light, so no.
It's like that is it?
Return to “RX-8 Discussion”
