Am I right in thinking that you cut right through any remaining cable and protective tube so you had loose ends on which to thread the tube from the Range?Honkytonk wrote: ↑Wed Oct 16, 2019 7:00 pm
You're right about the cable tube, but I found a section of flexible heat-shrinkable ribbbed plastic hose in my local The Range's aquarium section to cover it with, then heated and hot glued the ends to form a seal. It's not quite OEM but it's close enough...
- Has thanked: 316 times
- Been thanked: 53 times
- Been thanked: 2080 times
Low-temperature solder joint with heat shrink?
https://www.ebay.co.uk/itm/100Pcs-Water ... 3360878363
Have you ever used or seen them 'in the flesh' Dave?warpc0il wrote: ↑Thu Oct 17, 2019 12:22 amLow-temperature solder joint with heat shrink?
Yup, used them a few times.
The wire ends need to be bright clean and I dip in flux paste first, just to be sure.
- johnbb99 (Thu Oct 17, 2019 12:36 am)
When a website is that short on detail I tend to get a bit worried.
- Has thanked: 121 times
- Been thanked: 202 times
No, I split the tube addition down the middle (like a subway sandwich) and then when it heat shrunk it closed the gap, which I made sure of with a little extra hot glue (for the bodgiest of jobs)
I'll try and find what I used next time I'm in there. If you Google corrugated heat shrink you should see the type of stuff I'm talking about.
- johnbb99 (Thu Oct 17, 2019 9:06 am)
- Has thanked: 22 times
I am totally satisfied with rear speakers swap
Worth every penny
It’s 15 min job I used jbl p963
Two engine disassembled one 231 other street
Ported. I literally surprised by amount of shaved
Port. I was thinking they shaping better! Also I
Discover ugly truth about coloured engines as
The color splash oils injectors and cause oil leaks
Hence damaging engine and so on...
Worth every penny
- Has thanked: 2567 times
Close up photos of the ports will help us understand what you are referring to
Received a message today that Dean in LA has located a pair of orange front side marker lenses for me. Power to forums and Facebook for bring people together.
- warpc0il (Thu Oct 17, 2019 10:58 pm)
- Has thanked: 68 times
- Been thanked: 131 times
Wish I known you needed some I sure I got some in my mod box I check it out for you Let you know at the weekend they should fit the ATH bumper the ones from USA you find that they will NEED SOME OF THE PLASTIC AT THE REAR trimming off to give you a good fitChrisHolmes wrote: ↑Thu Oct 17, 2019 10:51 pmReceived a message today that Dean in LA has located a pair of orange front side marker lenses for me. Power to forums and Facebook for bring people together.
- These users thanked the author exiled--viking for the post:
- ChrisHolmes (Fri Oct 18, 2019 12:25 pm)
- Been thanked: 50 times
Nearly finished stripping the RX out.
Just a few more bits to remove.
Then it’s off to RX8 heaven
RedCorn Collecting Monday hopefully..
- Has thanked: 750 times
- Been thanked: 175 times
Replacement engine in and running!
Fluids changed so I'm starting from fresh. Just a coolant light on the dash now
Also found a new spot for my number plate. Just the undertray and wheel dressings to go.
- Been thanked: 323 times
Not sure if I’m telling you what you already know John but the coolant light is a very common thing , most just unplug the sensor and check the level periodically.
- 30405 (Fri Oct 18, 2019 9:57 pm)
Yeah i've been googling around. I'm just sad as it wasn't an issue before.Nickp47 wrote:Not sure if I’m telling you what you already know John but the coolant light is a very common thing , most just unplug the sensor and check the level periodically.
aha didnt take pic as my hands were dirty.ChrisHolmes wrote: ↑Thu Oct 17, 2019 6:59 pmClose up photos of the ports will help us understand what you are referring to
will make pc or try to find it online
finally manage to correct pcv system to full active
I used mx5 pcv valve + 0.5mm long restrictor
air goes to bottom of factory catch (filler tube is factory oil catch can) via oil deep stick whole and coming out filler neck to
2ndry after market catch, then to pcv valve+restrictor then to Y pipe, finally two 3mm pipe to each main rotor port.
pros
all air are meter air from map sensor so no false fuel trim
air circulate actively to clean any moist and/or oil vapour
drain of system after all ssv and other valves so no carbon/ dirty/ sticky valve
addition lube for rotors
low pressure in sump reduce oil leaks, improve oil return to sump !?
cheap retro fit
cons
negative effect on octane
taking off deep stick
pros
cheap retro fit
cons
- Been thanked: 57 times
Gone back to my standard wheels and fitted a full set of pagid road pads
- These users thanked the author Lemon for the post:
- ChrisHolmes (Sat Oct 19, 2019 6:22 pm)
Thanks, Stu
Mad as anything
Mad as anything
- Has thanked: 93 times
- Been thanked: 165 times
Will be interesting to see how you get on with the Pagids Stu
- Lemon (Sat Oct 19, 2019 4:24 pm)
the rear pads on the car were pagids anyway and the fronts were 1144's but i've gone back to a road pad for when i'm not on track as i'm not liking the "pause" you get on the 1144's when they are cold.
i'll keep you posted once they are bedded in, but i't will be a few weeks as i'm using the parents cars as my dailies whist they are away.
Thanks, Stu
Mad as anything
Mad as anything
- Has thanked: 38 times
- Been thanked: 116 times
LEXUS LS430 4.3 v8 family car
Done exhaust and work wheels
- Has thanked: 301 times
- Been thanked: 253 times
Converted to KGF & 250 rpm
1st pic
First Chamber [6.9,8.5] : 6.2
Second Chamber [6.9,8.5] : 6.27
Third Chamber [6.9,8.5] : 6.2
Chambers Difference [<1.5] : 0.07
2nd pic
First Chamber [6.9,8.5] : 6.52
Second Chamber [6.9,8.5] : 6.45
Third Chamber [6.9,8.5] : 5.95
Chambers Difference [<1.5] : 0.56
Rotors Difference [<1.0] : 0.24
I move it away I will make new test
- MARKTHOMASBRAND (Sat Oct 19, 2019 5:36 pm)
Did you not like those results
- nightfire10 (Sat Oct 19, 2019 6:52 pm)
Is spinning alot faster than the last test is wierd
