PaulAV
Has thanked: 173 times
Been thanked: 523 times
Post by PaulAV »
I will have to let you know as I haven't done much driving since fitting, it is however quite civilised compared to the Borla. It would be quieter still without the racing beat exhaust manifold, but I don't want to be too quiet
rotatopotato (Sun Jan 17, 2021 11:03 am)
nightfire10
Has thanked: 741 times
Been thanked: 283 times
Post by nightfire10 »
PaulAV wrote:I will have to let you know as I haven't done much driving since fitting, it is however quite civilised compared to the Borla. It would be quieter still without the racing beat exhaust manifold, but I don't want to be too quiet
Borla and rrp 200cell sounds great ImageImagequite loud
PaulAV
Post by PaulAV »
nightfire10 wrote:
Sun Jan 17, 2021 11:04 am
A little too loud (the sound went up a bit with the racing beat exhaust manifold) it did sound good in tunnels and such, but every day it was just a little bit much
nightfire10
Sound level OK for combe and brand's
PaulAV
Post by PaulAV »
Mine is my daily driver, I would of been fine with the setup of the RRP hand come along, but it could be a little annoying day in and day out.
nightfire10
PaulAV wrote:Mine is my daily driver, I would of been fine with the setup of the RRP hand come along, but it could be a little annoying day in and day out.
Apart from when I'm working using the van my car gets used other than that
30405
Has thanked: 750 times
Been thanked: 175 times
Post by 30405 »
Used the civic to jump start the 8 and charged the battery on way to do the weekly shop.
These users thanked the author 30405 for the post:
Pippypip (Sun Jan 17, 2021 3:54 pm)
Nanotrox
Media Team
Media Team
Has thanked: 170 times
Been thanked: 115 times
Post by Nanotrox »
Went to get pizza from pizza hut in the car tonight and turning of the street there's a drain / manhole cover that's come loose in the middle of the road that I didn't know about and sounded like it hit the underside of the car it was really loud, no damage / leaks tho when I got out and checked so I'm hoping the noise was it going back in rather than smacking the underside of the car
Lightened and balanced rotors
Pettit Catback
Exedy Clutch
CC Ultra Lightweight Flywheel
CC Counterweight
Tein S.Tech Lowering Springs
Racing Beat Ram Air Intake
Footwell LEDs
Pippypip
Has thanked: 116 times
Been thanked: 78 times
Post by Pippypip »
Nanotrox wrote:Went to get pizza from pizza hut in the car tonight and turning of the street there's a drain / manhole cover that's come loose in the middle of the road that I didn't know about and sounded like it hit the underside of the car it was really loud, no damage / leaks tho when I got out and checked so I'm hoping the noise was it going back in rather than smacking the underside of the car
Should have gone to domino’s insteadImage
These users thanked the author Pippypip for the post:
GreySilver Beast (Sun Jan 17, 2021 9:30 pm)
79398
Post by 79398 »
Smothered all the nuts I could find front and back under the car with WD40 prior to suspension adjustments on Wednesday.
Oil and filter change but didn't have enough length on the connection wires to finish the installation of the oil and water temp gauges, ordered extensions.
Could be worse 👍😎
Has thanked: 2572 times
Been thanked: 940 times
Post by ChrisHolmes »
Proactive wrote:
Sun Jan 17, 2021 9:48 pm
Could be worse 👍😎
Did you spray the top of the front lower arm rear adjusting bolt? Those are the biggest issue, especially the drivers side one.
79398
Post by 79398 »
"Did you spray the top of the front lower arm rear adjusting bolt? Those are the biggest issue, especially the drivers side one."
My lad assures me he has, I will do it again tomorrow, just pumped up the tyres, god do they lose pressure or the digital pumps at the Garages vary widely
SmuttyHutty
Colour: Nordic Green
Has thanked: 252 times
Been thanked: 206 times
Post by SmuttyHutty »
Proactive wrote:
Mon Jan 18, 2021 4:00 pm
....god do they lose pressure or the digital pumps at the Garages vary widely
I have two digital pumps and two digital tyre pressure gauges and can get 4 different readings at times. I now overinflate with a pump and then deflate to a point where both digital gauges kind of agree it is 32psi.
v-rex
Has thanked: 515 times
Been thanked: 172 times
Post by v-rex »
I found pressure gauges at garages are wildly out and even a digital pressure inflator will be off by the time it heats up on the 4th wheel.
So another vote for overinflating as well and then I use this deflate to correct pressure. No idea vs digital what's more accurate but this is easy enough.
30405 (Mon Jan 18, 2021 7:35 pm)
30405
Post by 30405 »
v-rex wrote:I found pressure gauges at garages are wildly out and even a digital pressure inflator will be off by the time it heats up on the 4th wheel.
Ment to ask where you got that at Donington.
v-rex
Post by v-rex »
Only negative I'll say is the case it comes in is flimsy and I've had to repurchase it once because the spring pushing the needle back broke. This is still after a few years of use and it may have been me being overzealous with the reset button.
Overall a lovely bit of kit imo and hopefully won't need to purchase again, but if I do I have no qualms in buying it again.
bigpete8
Has thanked: 150 times
Been thanked: 162 times
Post by bigpete8 »
Managed a short drive to the childminders and back. (My sisters to pick the youngest up)
Previously rx8 sat on my drive for couple of weeks waiting for me to replace sticking caliper which still hasn't happened. Risked it as only round the corner and drove enough to get the engine warm. But not the brakes!
New starter motor still holding up well, starts are much quicker.
SmuttyHutty
Mine are going to be weekends only for the next month or so. I am tempted to SORN them both, but I need the PZ taxed so I can get it resprayed. The 192 hasn't got any major works for three more weeks when the yellow calipers come back. I might buy another car cover and battery conditioner and put them both to bed.
HarSc
Has thanked: 569 times
Been thanked: 525 times
Post by HarSc »
SmuttyHutty wrote:
Tue Jan 19, 2021 11:06 am
What car cover do you get for yours? Been debating it myself but there are so many out there I have no idea what to get :shock: :lol:
Some guy from oooop north ;) | Harry | Membership Secretary | Media Team
- My Main RX-8 R3 [MHZ 3800] thread here
- My Project Banana [GL04 MXU] thread here
- My Mazda 2 DE daily thread here
- My engine disassembly shenanigans here
Has thanked: 444 times
Been thanked: 2087 times
You have to be sooo careful with using covers outdoors.
Our paint is very soft and any wind movement can cause the cover to wear/score the paint.
Obviously worse if there's any grit trapped between but I've seen nasty damage even on a clean car.
Moisture can also get trapped making rusting worse and even lifting/blooming the clearcoat on some panels.
If you can't get the car inside a garage then a carport or even against a high fence/wall to keep off the worst of the weather, is better than a fitted cover, that and a good coat of wax for the paint.
ChrisHolmes (Tue Jan 19, 2021 2:10 pm)
nightfire10
Mine ImageImageImage
SmuttyHutty (Tue Jan 19, 2021 3:31 pm)
Good luck with that. It would be great in a dry dusty garage but you wouldn't catch me putting my car under one in NI weather.
nightfire10
Such a good fit it doesn't move even if windy
Used it when I had to go into sheilding for 4 months
SmuttyHutty
I cannot remember where I bought the current one, but I am happy with it. Probably ebay or some other online store.
Firstly, it covers the car:
Secondly, it has a front and a back (which does make a difference to the fit):
Thirdly, it has ties on each corner so I tie it to the wheels:
Fourthly, but hard to show in a pic is the central strap with a clip that goes underneath to stop billowing:
It is a pest to get under the car but I have a broom handle which I use to dip the underground oil tank so I loop it round the end of that and poke it under the car.
Fifth(ly?), it has a fluffy cotton underside:
It is a heavyweight construction and once tied down doesn't move. I always dry the car fully before putting it on (chamois leather earlier) and I only waxed it a couple of months ago so the paint is protected. When I take it off I fold it back on itself and roll it up and place it in a holdall in the garage to stop grit and the like getting on it.
I just picked up something similar from ebay: https://www.ebay.co.uk/itm/Heavy-Duty-W ... 2749.l2649 and I will see if it has similar features. It is a close match, or so it seems online.
But I've had no problems with the current one and no signs of any harm coming to the car after last winter under cover. Far less harm than having the cats climb all over the car!
mrspiller
Has thanked: 114 times
Been thanked: 158 times
Post by mrspiller »
Unless it was a very snug fit with a cloth or chamois inner I’d be very worried that when windy it could scratch the paint slightly
