Yesterday fitted the remainder of interior LEDs (kept forgetting to put decent screw driver in car for the sunglasses holder) and did the rear number plate lights...
Kit I got was slightly wrong as had cigar shaped bulb but needed the same as the rest of the interior. Luckily had a couple spare due to door projectors. Roll on winter for the illuminations
- Has thanked: 173 times
- Been thanked: 523 times
Fitted Ryan rotary engine mounts, took an hour, not bad consideration I had to top the oil up in my hydraulic jack first, well it is nearly 30 years old, see how these fell in the way to North Wales later.
Spellcheck eh?PaulAV wrote:Fitted Ryan rotary engine mounts, took an hour, not bad consideration I had to top the oil up in my hydraulic jack first, well it is nearly 30 years old, see how these fell in the way to North Wales later.
- RX-8: Evolve
- Has thanked: 30 times
- Been thanked: 27 times
They're just clips. You can take them out and tbh could just use a nut and bolt either side. Few more detailed photos here: https://www.rx8ownersclub.co.uk/forum/v ... 5#p1046119johnbb99 wrote: ↑Sun Sep 15, 2019 10:18 pmI've been cleaning up my replacement oil coolers as they may be needed and found one of the fixings was so badly corroded that I sheared the bolt trying to unthread it.
And in detail:
Are these clips (that rusty bit, with a nut welded on underneath) a standard part that I might find elsewhere or be able to buy?
- These users thanked the author zippyonline for the post:
- johnbb99 (Tue Sep 17, 2019 11:35 pm)
- Been thanked: 283 times
Received the flywheel today from Scott at RRP... Should have my car back at the end of the week.
- Has thanked: 22 times
Got new MOT
finalised my tablet with track ball.
installed shaved side air vents.
finished with my personal debate whether to run or not run vacuum in PCV and going to run rock it baby ! looking for decent PCV valve.
and more ! ....
and more ! ....
- Has thanked: 316 times
- Been thanked: 53 times
FINALLY got round to completing the installation of my SOHN oil level warning light. I chose to have a separate light for the the two stroke tank but that leaves the problem of where to put it.
This is my solution: And this is how how it will appear to me as I drive: I am happy I'll spot that as soon as it comes on.
As that bit of plastic is pointing down at your knees I had to make up an angle block to mount the lamp in.
It was crafted from solid oak .... not exactly a traditional Mazda material!
Picked up a pad retaining spring plate and Caliper deal kit from Racing Brake in LA. I had to place the order online last night and then when I arrived to collect today I was told I couldn’t collect until they sent me advice that the order was ready for collection which could take two days! To cut a long story short after about 20 minutes I was presented with a bag containing the spring and the seals. Got in the car and looked at the seals in the bag and thought “4 pot calipers x 2 = 8 pistons with two seals each, why are there only 8 seals in the bag? Knock on the door, no reply, go round the side to the open loading bay, no one about, back round the front knock again still no response, back round the side and found the guy, manager I think who served me and said I think I need more seals, mumble, mumble response, he went into the warehouse and came out with 8 more seals, no apology for the error he just said “this happens when call at short notice”
So that’s USD112 for 16 little rubber rings. Fair does though I was given the pad retaining spring plate for free.
- Has thanked: 19 times
- Been thanked: 18 times
Out with the old...
In with the new...
All 4 old ones had these burn marks on them. Is that the sign that they are pretty much done?
In with the new...
- These users thanked the author Devon_Fourie for the post:
- Honkytonk (Thu Sep 19, 2019 1:47 pm)
Thumbnail sized grey marks just show where they've got hot, which is normal.
Breakdown is often associated with small white spots, sometimes with a tiny black dot in the centre.
I'm not seeing any of those in the photo (phone screen) so it looks like you replaced them it time.
Much better to replace before failure.
Cool thanks, I’m just getting everything around the engine replaced and upgraded because I am planning my rebuild early next year and want to give the engine the best possible start in life next is a sohn/cof system.
Have look here https://www.carbuildersolutions.com/zippyonline wrote: ↑Tue Sep 17, 2019 1:53 pmThey're just clips. You can take them out and tbh could just use a nut and bolt either side. Few more detailed photos here: https://www.rx8ownersclub.co.uk/forum/v ... 5#p1046119johnbb99 wrote: ↑Sun Sep 15, 2019 10:18 pmI've been cleaning up my replacement oil coolers as they may be needed and found one of the fixings was so badly corroded that I sheared the bolt trying to unthread it.
And in detail:
- johnbb99 (Thu Sep 19, 2019 1:40 pm)
- Has thanked: 121 times
- Been thanked: 202 times
Swapped out the old key for a newly cut one in the 'new' switchblade I got from ebay ready for a FORScan session tomorrow. Bit trickier than I originally thought as the pin holding the blade in place is a bit smaller than any of my punches, but a Torx bit from my tiny screwdriver set did the job lovely.
- 30405 (Fri Sep 20, 2019 9:13 pm)
- RX-8: Nemesis
- Been thanked: 3 times
Bought mine as a non runner. Needed the clutch doing. Just got it all bolted together and moving under it’s own steam again
Only took about 4 months
Did the 6 month oil and filter change. Nice smooth oil out with no bits in. And tied up some loose gearbox wiring. Also tried to find the source of the rattle when I go over bumps. I've been hunting it for a while, and had thought strapping up the loose manifold heat shield would sort it. Still couldn't locate the cause of that rattle, everything feels tight down there.
- Has thanked: 35 times
- Been thanked: 73 times
My car is going for ct,next Saturday so had it on the lift this morning to put the cat back on the car,I gave it a good look over while I was under there and all looks good so should be a pass .
- These users thanked the author Markl17 for the post:
- nightfire10 (Sat Sep 21, 2019 10:59 am)
Is that your lift mark?Markl17 wrote:My car is going for ct,next Saturday so had it on the lift this morning to put the cat back on the car,I gave it a good look over while I was under there and all looks good so should be a pass .
No it is a friends but I think I am going to buy one as I have the room and they are not very expensive and makes life so much easier,I am getting a bit to old to crawling around on the garage floor.
- nightfire10 (Sat Sep 21, 2019 11:06 am)
Results inbound once I get home.
- 30405 (Sat Sep 21, 2019 12:38 pm)
Got an update from my mechanic. Clutch and flywheel are in car drives forward/back. Hasn't been able to test drive it yet since I wanted a back box with two tips put on. He had a bit of an issue seperating the back box from the mid pipe... Tried heating it up to basically white hot... Corrossion just refused to break! He's going to figure some fab work out and get everything back together for tomorrow then test drive it. He said the bite point on the clutch pedals quite low... Wondering if someones messed with the pedal adjustment at some point. Anyone got any thoughts as to what else that could be?
- Has thanked: 23 times
- Been thanked: 14 times
Compression test on the 231 with good results so I am a happy bunny. Used some new eBay bodywork clips to fill in some gaps, not so impressed with those though. Can any body tell me what this connector in the FLS wheel well is for as it doesn’t seem to have a friend on my car?
Do your front fog lights work? No idea otherwise
Brilliant Black PZ, Strakes, red calipers with logo.
- Has thanked: 114 times
- Been thanked: 158 times
My bite point was low to start after changing everything over . It seems to have settled back after a short driveYorindesarin wrote:Got an update from my mechanic. Clutch and flywheel are in car drives forward/back. Hasn't been able to test drive it yet since I wanted a back box with two tips put on. He had a bit of an issue seperating the back box from the mid pipe... Tried heating it up to basically white hot... Corrossion just refused to break! He's going to figure some fab work out and get everything back together for tomorrow then test drive it. He said the bite point on the clutch pedals quite low... Wondering if someones messed with the pedal adjustment at some point. Anyone got any thoughts as to what else that could be?
Alright cool. I figured it might just need some time to settle. Going to check the free play in the pedal incase that's been adjusted at some point.
- Colour: Aluminium Silver
- Has thanked: 9 times
- Been thanked: 33 times
Attempted to fit the new wheel liner after it got ripped.......took off the remaining of the old wheel liner and discovered the new one doesn't fit ( It did say on the ebay listing it was for an R3)
Search begins for another liner.
Also cleaned up the headlights a bit as had bit of yellowing and fade around the edges.....came up quite well for a quick job!
*Update on the 'crazy ex tinder date car keying - Police are absolutely useless! 5 weeks on they finally collected the CCTV footage but apparently the file format isn't compatible with the police computer so may 'take a while' to access it (god help us all).
I called the officer 16 times, and messaged 8 times since then and not heard anything back, currently on hold to 101 for 2hours 18 minutes and counting..... TOP TIP Don't be a victim of crime in South Yorkshire
